3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Near-Perfect Tent: Design and Build a Recycled Tent
Step 7Making Side Doors II
  • C:\Documents and Settings\Owner\My Documents\My Pictures\2007_04_06\IMG_2634.JPG
  • C:\Documents and Settings\Owner\My Documents\My Pictures\2007_04_06\IMG_2646.JPG
  • C:\Documents and Settings\Owner\My Documents\My Pictures\2007_04_06\IMG_2637.JPG
  • C:\Documents and Settings\Owner\My Documents\My Pictures\2007_04_06\IMG_2624.JPG
  • C:\Documents and Settings\Owner\My Documents\My Pictures\2007_04_06\IMG_2647.JPG
  • C:\Documents and Settings\Owner\My Documents\My Pictures\2007_04_06\IMG_2649.JPG
  • C:\Documents and Settings\Owner\My Documents\My Pictures\2007_04_06\IMG_2651.JPG
1. Making the screen side doors and sewing them on is easy. But I want to be perfectly clear on this step. Either
a.) measure your doors and transfer those measurements to the screen material and cut them out, or
b.) after you cut the doors out, lay the material flat, then lay the screen over top of it and trace the door shape onto the screen. Cut out the screen, leaving a little extra (1/2") all around.
2. Sew one edge of the zipped-shut zippers to the door(s), then sew the other edge to the tent. Both the cloth and screen doors' zippers will end up being sewn to the door frame-edge together. You could pin the solid and screen doors' zippers together and sew them to the frame edge at the same time, but I found it easier to do them individually, and I suspect you will too.
Once both the screen and the solid doors have their zippers sewn on, zip them shut and sew the hinge end of the screen door to the hinge end of the opaque door.
This might sound complicated, but it's not--as you'll see once you're doing it, and by looking at the phhotos.
3.) I added a couple of tie-back strings at this point. just cut some line of some sort and sew it on to your liking. I reinforced mine with some scrap material. My photo shows one way to do this.
4.) Since the floor comes up about 3" from the ground, the bottoms of the doors will eventually be sewn to it when you assemble the tent. For now, just get the wall panels sewn up as discussed above, leaving the zippers of the screen and solid doors pinned together along their bottom edge. You'll sew them to the upturned side-pieces of the tent floor last.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
43
Author:bentm
just some fella
