This approach was considered through various testing and prototyping to try and increase the efficiency of the wind turbine.
NOTE****Test video at step six****
Remove these ads by
Signing UpStep 1Materials
MDF(Medium Density Fibreboard)
safety blade/scalpel
handsaw
PVA Glue 'polyvinyl acetate'(any preferable adhesive)
electric handdrill
PVC pipe(poly-vinyl chloride)
coupling(preferably oldham coupling or any good chosen connection)
Generator
U-pol(or some kind of filler)
multimeter and variable resistor
Adding some notations to the photos to help illustrate the text, or indicate what is being pictured would make it a great instructable.
I've been toying around with the idea of building a small wind turbine to keep up the power on a pair of 12 volt batteries. I don't need much power generated as the only draw on the batteries is for a camper trailer parked up on my land. So it's just lights, furnace fan, and the stove exhaust fan.
-I'm tired of pumping up my Coleman lantern (plus the smell, uneven light, and heat) so my main power draw is going to be from my reading at night (around 4 to 6 hours).
However I don't want to build a very large tower to get to the steady and stronger winds, as that leads me to other complications.
You've given me a new option. Thanks!!
- I wonder how it would work with a Savonius?
Whats important is the amount of power produced.
Using a varistor is interesting, but you're going to need to instrument the setup further with an ammeter so you can tell how much current is flowing. Multiply the potential difference across your load in volts by the current in amps and you'll get the power in watts.
At 17 volts 47 ohms you're putting through 0.36 amps for a total of just over 6 watts.
I'd think your goal would be to make that power number higher - whether its higher amps at lower voltage or higher voltage at lower amps isn't particularly important (though there will be interesting side effects that will alter the portion of the energy you can use as the load at higher amp rates)
When you say that by tweaking you got the voltage to go higher you're being very vague. Perhaps you could discuss what tweaking you did, how the blades and/or load were modified, and how the *power* output was changed by your tweaking.
Upload to youtube or share with:everyone...?
Cool though.
