The Office Worker's Portable Solar Oven by z0rb
Featured
In keeping with the grand tradition of creating ways to warm my lunch at work with readily available office supplies, I present for your review, dear reader The Office Worker's Portable Solar Oven.
Step 1: The Situation
Due to circumstances beyond my control, my cubicle at work is close to both the break room and a small loading area on the second floor. Because of this I usually have a wall of boxes filled with copier paper situated somewhere behind me. Aside from this being a nuisance when it comes to concentrating on my job it also affords me the opportunity to scavenge as many copier boxes that a man can get his hands on.
This is a perfect situation to improve upon my earlier solar cooking ideas.
See here: http://www.instructables.com/id/Dashboard-Chilli/
carl87gt says: Aug 16, 2012. 10:48 AM
Fantastic instructable! I wonder if you would get more heat by painting the interior black to absorb light and heat to the box would work better than using foil. You still see people (thankfully not in my neighborhood) using foil on home windows to reflect light and heat away. You could use an outside hood (outside the main box) covered in foil to direct the light in (like a satalitte dish focusing on a smaller point) and use black paint on the inner box to absorb the heat.
I may have to try this and report back my results.
z0rb (author) says: Aug 17, 2012. 4:13 AM
I think it all depends on where you want the heat to go and what you want it to heat. It was my intention to bounce the light around inside the box and have it ultimately hit a black target that would absorb the heat.
In retrospect I see several areas for improvement of the model I presented here. But in reality I wanted to limit myself to what I have available around the office and of course I wanted to have fun.
Thanks for reading
yanksguy says: Nov 29, 2010. 10:31 PM
Fantastic Instructable! Thanks for all the pics, the well explained directions, the quantification, and most importantly, for your time.
I would like to echo what Haw1horne said: Heating plastic is a bad idea unless it is designed for heating. You may not see or taste the outgassed products, but they are there. Other sites also say that if you can't use glass then the baking bags will work. I think a layer on the inside of the cover sealed with a cardboard edge, and another layer on the outside of the cover also sealed. Of course, pull tight to reduce diffraction.
An aside to the previous; careful what paint you use. Some are not safe to be heated. Look for those labeled as non-toxic stove paint.
A glass top would help keep the lid sealed because of its additional weight. If you go with the turkey bag window route, I'm thinking paperclip and rubber band anchoring system around the outside would keep things tight and allow for less heat loss. My guess is this is where your heat loss came from.
An angled lid lined with foil (aluminum, tin, lead, mylar, whatever) would catch more light and protect the works when all finished and folded down.
I'll start my oven tomorrow. Again, fantastic job with this and thank you so much for your time and effort.
shostakovich says: Jan 2, 2010. 8:23 PM
Great...
have a nice day
elescape says: Dec 8, 2009. 8:21 PM
I found a typo, "rapped" should be "wrapped".
_Scratch_ says: Nov 11, 2009. 2:29 PM
if the insulation is to keep the heat in, i would suggest the paper shreds AND, a  layer of mylar emergency blanket cut accordingly to fit the walls. because it reflects heat it is a good material to use for this, you can get them for like 7bucks online.
syed najam javed says: Nov 10, 2009. 9:40 AM
this really is great thinking and i think that we should also try and develop more because  in this era we have to give much importance to solardevices as they're cheap and best
ddmg says: Oct 12, 2009. 10:06 AM
 in the end, does this oven work ?
TRIPLEC says: Oct 10, 2009. 9:00 PM
you, sir, are EXTREMELY good at making instructables. you were able to show how to make an oven (although you didnt really provide enough detail, but im sure the pictures are good enough for someone to tell what to do) andyou even did the math for us to show how hot it gets and all the important things the oven does. i salute you  =]]
StrangeRover says: Sep 30, 2009. 3:01 PM
Aluminum foil. Tin foil was around when our grandparents were children. :)
hammer9876 says: Oct 10, 2009. 5:50 PM
When I was a young whippersnapper.... My 1955 encyclopedia lists the three most common uses for lead: lead solder, lead paint, and lead foil. Ha!
I always call aluminum foil "tin foil" though, just like my father always called the refrigerator the "ice box."
Good lunch warmer, Z0rb. We get lots of sun here. It will work well.
ranmawolf says: Oct 9, 2009. 6:11 PM
True! haha - although for information's sake (in case there was ever any kind of specific need for *tin* foil as opposed to aluminum), they actually still make tin foil these days - you can find it at florists shops that carry it. It's often preferred over aluminum at such places for some reason or other.
dings says: Oct 8, 2009. 7:04 AM
Or even Aluminium if you don't hail from the US. Just thought of it after reading the syllables comment below :)
peacenique says: Oct 8, 2009. 5:50 AM
It's quicker to say 'tin foil'; then you have three extra syllables to spend on something more important!
z0rb (author) says: Oct 3, 2009. 6:05 AM
Everyone is a critic :P
ranmawolf says: Oct 9, 2009. 6:12 PM
Hehe - yep o_~
boneyo says: Oct 1, 2009. 7:52 PM
FYI the term aluminium foil is not the common terminology in every part of the world
sugarandfat says: Oct 10, 2009. 1:08 PM
It's not quite the same principle, and meant for slightly different application, but have a look at this:
http://solarflower.blogspot.com/2009_09_01_archive.html#6825927391729345306
It's a compound parabolic concentrator. If you scaled it up a bit, insulated it and put your food in a black container at the focus it would act as an oven.
The angle range will give you about 4 hours without having to reposition and the degree of concentration is about 10 times when it's pointed directly at the sun, down to about 6 two hours either side.
I spent quite a bit of time with a cad package, this is the most efficient design I could come up with.
And use reflective mylar, you can get it cheap from hydroponics stores and is about 50% more reflective than tinfoil.
HobbyistX says: Oct 8, 2009. 4:41 AM
 I probably don't have to warn you that that temperature range is the one they incubate petri dishes in.  :D
ranmawolf says: Oct 9, 2009. 6:14 PM
Oh-HO! GOOD POINT! ahahahaha
Instead of cooking food, it might accelerate microbial growth! ICK! lol
ranmawolf says: Oct 8, 2009. 6:38 AM
I wonder how much hotter it would've gotten in there, if say, instead of the trash bag plastic, you used one of those cheap, acrylic/plastic, 8.5x11" Fresnel lens thingies - they don't jjust focus light, but heat as well... I think I'll try that at some point between instrumennt projects.
Dude, I really gotta say (in somewhat paraphrased agreeance wth fishhead445 had to say), I thoroughly enjoyed this entry! Clear, concise, highly informative, well documented data, and witty as alll freakin' hell! THANX! ^_^
HAIL!!!! ^_~
headphoned says: Oct 8, 2009. 10:33 AM
I think you'll find that lenses DO just focus light. The heat is created as a result of that light, so obviously by focusing the light to a smaller area > higher intensity > greater heat. However, the advantages of that increase in light intensity would be restricted to the focal point, I think, as it's the same amount of total light going through the window/lens.
The real trick here, I suspect, is maximising insulation on all sides and the area of the window, while minimising total volume. Afterall, the more air inside, the more air to heat up.
TheOneTrueStickman says: Oct 9, 2009. 5:55 PM
You can only make it so small, though, before you're not collecting enough light to make the efficiency worth it. Wouldn't a more finely-tuned reflection chamber help more? Most solar ovens I've seen use a parabolic surface to not only collect sunlight, but also focus it on the object to be heated. I haven't seen one that's just  a reflective box before.  (Not that I know much about solar ovens or have researched or anything...) Is there a reason that wasn't done here, I wonder?
I wonder how much light gets lost from diffusion by the trash bag, too. Probably not much, but it would be interesting to compare it with glass. (There's gotta be a broken flatbed scanner around the office somewhere...)
ranmawolf says: Oct 8, 2009. 9:44 PM
Yes, true - and as a result, it does focus heat as well as light... a bit of an "accidental quality" perhaps, but yeah. Seems you and both I agree on this, it's just that I'm just saying things kinda weird here hehe ^_~
But yeah, what with the way a Fresnel lens focuses light into a concentrated beam (much as lighthouses do), so does the heat concentrate, as well. Like with one of those Fresnel lens panels that can be gotten through Edmund Scientifics that can melt asphalt, for instance. As far as a focal point, with a Fresnel lens, it's a beam (again, like with lighthouse lenses, which are of the Fresnel type), so there's not much as far as spacial restrictions go, I would imagine. But I could be wrong. I'm no scientist lol
True that, on the insulation... but with a focused beam (as opposed to an apex/singular focal point) and spacially-throughout-heat-intensity, there *may* be a need for more heat resistant materials... hmmm... insulative fiberglass, perhaps? Like the kind one can find in one's attick? Maybe...
aaronjehall says: Oct 9, 2009. 1:28 AM
seems like you could just paint it white inside, instead of using tinfoil.  you could use white out...
desertdog says: Oct 8, 2009. 12:16 PM
Very well executed and explained.  I wish some of my friends who rely on data for experiments, that most of the time is not accurate in the real world, will take the time to read yours.
Mig Welder says: Oct 8, 2009. 6:12 AM
haha I built one of those welders too.
you should see if you can finish it. they're awesome! especially when they're cheap;)
z0rb (author) says: Oct 8, 2009. 7:14 AM
 Well unfortunately it would simply not have enough power to do the trick.
Mig Welder says: Oct 8, 2009. 6:20 AM
exactly what fishhead455 said!
hey that rhymes!
anca says: Oct 7, 2009. 1:19 PM
Fabulous. I especially love the math at the end.
Mig Welder says: Oct 8, 2009. 6:18 AM
yeah same I love the math
M F says: Oct 7, 2009. 1:43 PM
you would have gotten much highter temperatures faster, if you had painted the inside black; instead of using reflective foil. Give it a try and give us the new data figures.
peacenique says: Oct 8, 2009. 6:17 AM
Ha!  Too funny.  Good to know someone was concerned enough to worry though.  I'd like to be his next-door neighbour!
Haw1horne says: Oct 7, 2009. 7:25 AM
Looks like you're having fun!
There's 3 complications with your implementation of the solar box oven (variation of the Kerr/Cole Oven patented in the 1980s)
One is the plastic glazing. If the oven did get hot enough, that sheet would very likely melt, warp, and/or outgas. This could be bad for your lunch! In any event, its probably not a food-safe grade of plastic if you found it around the work place. One work around is to use food-grade turkey bag plastic. Stretch it tight across a frame, and mount the frame in the lid.
Second is the plastic glazing. Yes, I know that sounds redundant. The biggest source of heat leaking is going to be out through that plastic. You can improve this by either using glass or lexan for the glazing, or by creating a double layer of food-grade plastic with a 1/4"  gap in between the layers.
Third, most box ovens made for climates outside the Tropics have an additional reflector to help boost the heat  up to cooking temperatures. Cookers that don't have the additional reflector are (1) Made for the tropics (2) Use double glazing (3) Use high-R polyisocyanurate insulation in the walls.
jatrophacostarica says: Oct 7, 2009. 7:04 AM
the grocery store has inexpensive oven bags- if you put your food container (painted black) inside the bag, then capture air around it and close off with a rubber-band, you get excellent insulation (and easy cleanup in the event of a spill).
also painting the interior black might help, as would raising your food container so that the light reflected off of the foil will hit all sides of the container
sleepydog says: Oct 4, 2009. 11:05 AM
Nice build! I'm impressed that you made this with all reclaimed materials (and time) from work. There's nothing like a little creative goofing off on the job to keep your mind fresh. Thanks for doing the math. It was a very professional touch and it makes others think about their project in terms of measurable success Keep up the good work..
cowscankill says: Sep 30, 2009. 2:37 PM
Very good math sir! A project I should look into, if I ever need it :P
z0rb (author) says: Oct 3, 2009. 6:06 AM
Well the math is actually pretty simple, and the concept only took a little research to find. I just laid it out. But thanks :)
cowscankill says: Oct 3, 2009. 7:08 PM
Ah well still, the average person wouldn't want to document math for the viewing of others, including me :)
keenahn says: Oct 2, 2009. 1:40 PM
What's the thermometer you used and how did you get the results into your computer? Thanks!
z0rb (author) says: Oct 3, 2009. 6:03 AM
Heh do not be fooled by the fancy graph. That is simply a standard digital cooking themometer. I recorded the temperatures every minute on a piece of paper and then entered them into Excel. However if you are interested in a meter that you can serially connect to your PC that will record temperature. Radio Shack has a data logging voltmeter for around 70 dollars.
l8nite says: Oct 2, 2009. 8:21 PM
cool idea and nicely done ible ! Now show us something cooked in it !!
ank0ku says: Oct 2, 2009. 2:03 PM
Well-documented instructables are few and far between. Excellent work! :D
handprints says: Oct 2, 2009. 9:30 AM
I feel like I could have gotten a MUCH better grade in my science classes a thousand years ago if I had you as a tutor!! Really good explanations!
esben2k says: Oct 2, 2009. 5:47 AM
At least you made it an interesting read :)
hishealer says: Sep 30, 2009. 2:31 PM
Congo Rats from me as well. Your math knowledge is impressive! Myself, I'll just keep playing with my little electric tea warmer and see what it can do. So far, keeping food warm and heating soup, tho slow.
Kiteman says: Sep 30, 2009. 1:43 PM
I have not seen a simple project approached so scientifically for quite a long time.
(That more than makes up for the occasional photo that seems to have been taken whilst running past...)
lemonie says: Sep 30, 2009. 12:41 PM
Have a look around here for solar-cookers, something parabolic would improve your collection. L
rimar2000 says: Sep 30, 2009. 7:20 AM
Very good project. Have you tried replacing the aluminized foil with black paper? Maybe that enhance the result...
PKM says: Sep 30, 2009. 9:50 AM
My thought as well. The silver would be great if it were reflecting sun onto the food, but as it is it looks like it might be reflecting quite a lot back out of the oven. You could try making angled sides to reflect sun onto the food, and a black back to absorb more heat and heat the inside more, but that is more dependent on orientation. Alternatively, just make the entire inside black and see if it will heat up better. Don't abandon the idea just yet!
fishhead455 says: Sep 30, 2009. 8:40 AM
FLATULATIONS-- That you have shown us a workable solar, um, cooker...is secondary. That you have articulated your idea while simultaneously integrating your high level of humor--along with a perfectly wonderful style of writing is premier entertainment. I salute you. (He makes a rigid, meaningful salute).
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
