Step 10Assembling the Controller's Frame
Install the large compression spring between the two boards. I accomplished this by putting in a pair of small wood screws with washers under their heads most of the way into the boards on the spots where I wanted the spring to attach to. I then slipped the bases of the spring under the washers in such a way that it wasn't in danger of jumping out when fully depressed. I found that I only needed one spring on one corner of the board to give it the amount of give that I was looking for, however you may want to experiment with multiple springs or alternate spring placement.
As a final touch, use some sand paper to sand down the top corner of the board so that you can comfortably rest and slide your palm along it.
Add Comment
