This is the first how-to posted on the entire interweb that teaches the reader (you lucky guys) how to build a FULL-SIZED Cotton Candy Machine!!!
IMPORTANT NOTICE:
This instructable assumes you know how to use a lathe, tap and various other instruments prior to engaging construction. Even though I figured out how to operate the lathe at my school by myself, it might be more difficult for others.
http://www.mini-lathe.com/Default.htm is a pretty good source for basic lathing tutorials
The entire CAD assembly file is included on the intro, materials, and final steps (just for reference)
This is defined by my searching abilities. Considering that dragonx151 and I have searched the web for cotton candy plans (personally about 1 month's worth of hours), I'm pretty sure that this is the first.
Top_Piece.AD_ASM102 KB
Remove these ads by
Signing UpStep 1Materials / Necessities
Materials:
1- standard electric motor (preferably 1/4" motor shaft)
1- 3.25" X 6+" Aluminum extruded round bar (3.25" diameter)
2 - 1/2" bolts of any size diameter (smaller = better, but you need the tap for it)
2 - 1" bolts of any size diameter (need the tap for the right size)
1 - average toaster heating element
? - .25" diameter copper pipe (or crimping connectors for wiring)
1 - radio-controller "floppy" antenna
? - lots of miscellaneous screws, nuts, and bolts
1- 3" (dia) X .125" piece of wood
1- Light Switch Dimmer or Adjustable power supply ( needs to be able to handle high voltage and amperage output)
Teflon Tape
Conductive Tape
A large, plastic or metal, circular object (if you don't have one, make one)
Some wire mesh (usually used as gutter covering)
A Few Sheets of paper
Some tape
Some heavy gauge wire
A small bit of fast drying concrete
Tools:
Lathe
Tap
Electrician's pliers
Band/Hack saw (if using copper pipe)
Drill press (and the smallest drill bit you can find, at least 1/16" or smaller)
metal working clamps
Tin Snips
Alibre Design Express (free at www.alibre.com)
Top_Piece.AD_ASM102 KB| « Previous Step | Download PDFView All Steps | Next Step » |
Im not positive if thats what your looking for but i saw it and is only 19.95 so. Yeah.
GREAT INSTRUCTABLE!!!
Thank you so much for your kind words. It really means a lot to me when I get comments like that. I don't know if I'm as smart or productive as a college grad, but I won't deny that I'm innovative =P
You rock, SacTownSue. You rock!
If you have the resources, I highly suggest making your own machine - it will cut your costs by at least 80%. You could buy the machine from lots of sources online, but seriously - why spend over $100 (I think maybe even over $200) when you can build it for about $30?
Also, I'm working on a portable cotton candy gun, which in my opinion would be a best seller everywhere - who doesn't want cotton candy wherever they go, straight into their mouth?!
Hope that helps.
