Introduction: The One-Minute Screwdriver
Have you ever done a diy project, and forgot that very special tool, or lost the screwdriver, flat or Phillips head? Then this is the project for you! It only takes 1 minute of your time (or less!) and makes a useful backup screwdriver if you ever need one.
Step 1: The Parts
What you will need (left to right):
  • An eraser cap
  • A syringe cap (If you don't have access to one, then you can use anything similar to one, that is made from a soft, flexible plastic, and that you can dispose of...)
  • Some screwdriver heads
Step 2: The Assembly
To start, make a small hole by pushing the pointed head of the SMALL screwdriver head into the top of the syringe cap, or what ever you are using. Then use a larger screwdriver head to enlarge the hole big enough so you can fit the back of the head snugly, but not too big so it will slip. Now put the screwdriver head into the hole...
Step 3: The Assembly: Part 2
So You've got your screwdriver part done, now what you need to do is to prevent the screwdriver from falling out from behind, Solution: Put in the eraser cap into the syringe cap. and make sure it fits snuggly.
Step 4: Finished!
Congratulations! You've just made... A screwdriver! In under 1 minute!
