The Opa! Amp is an USB powered audio pre-amplifier based on a Burr-Brown OPA2227. With 0.00001% total harmonic distortion, it’s a high quality way to make your MP3 player louder when hooked up to your home or car stereo.
This project is suitable for beginners, you'll need a few soldering tools, but even if you've never soldered before, it's an easy build. You can etch your own board, make it on a protoboard, or pick up a kit from Gadget Gangster.
I made the Opa! Amp because I recently got a smartphone – it sounded great with headphones, but when I hooked it up to my stereo, I had to crank up the volume to hear it and there was distortion. Listening to spoken word stuff in the car was the worst. The Opa! Amp increases the audio level and fixes the problem without distortion.
The next few steps discuss the design and testing process. If you just want an awesome pre-amp, skip to Step 6: Making It.
Remove these ads by
Signing UpStep 1Understanding the Problem
I did some research and testing and the problem was easy to pinpoint: Your headphone jack is designed to drive headphones. The jack’s max output is 300mV RMS, which drives headphones just fine, but most Aux Inputs are expecting 1V RMS as the max level. So when your MP3 player is saying “Blast it”, your stereo interprets that as “keep it pretty quiet”.
You can mess with the equalizer on your phone or compress the dynamic range, but as long as the max output is 300mV, the volume increase will be minor. And at the max volume levels, you get distortion because both the stereo and MP3 player are operating at their maximum levels.
Thank you for the post.
Well I have tried making amps and it did worked fine, but i am no good at electronics and did not understand the diagram at all i would request you to, kindly simplify the circuit for people like me.
Thank you!!
I am adding an image of wat i tried from this website, this diagram made it easier for me to make it. I am coping the same image which i got in that post. I hope you will help with this regard. XYz
I=5V/(150*2) = 17mA to <1mA by using >1K divider and a cheap DC opa.
THD below 1% does nothing if you don't use dedicated PSU (no digital/smps stuff on rails). At least use CLC filter, w/ f0=<20Hz.
3V3 linear regulator would be also wise to use, w/ 2,2mF caps & low esr films & tantals (only on rails).
In the signal line use only film caps or HQ electrolytes.
cheers,
You can reduce current consumption by using high value resistors on the divider, I used 220's because that's what I have handy. Consumption isn't an issue here, unless you run it from batteries, but even 17mA will last pretty long with some AA's.
Also agree, the power supply quality can significantly diminish sound quality. I used bypassing to help it work with some nosier power supplies, but an inductor filter works well. Batteries are a great power supply, too.
Running a 3.3v single supply isn't an option with the Opa227, but there are rail-to-rail op amps where that can work.
