Step 3Install the ignitor
Drill a hole in the 3" pipe for the metal lead from the ignitor to fit, mount the ignitor using screws provided, you can slop some glue around the hole to make sure there wont be a gap where the flames will shoot out and burn your arm......
In order to create the arc (spark) to ignite the gas, there needs to be a metal contact between the lead from the ignitor and the metal chasis of the ignitor.
If you mounted the ignitor with bolts into the pipe, bend the metal lead to be within 1/4" of the bolt to make a spark,
I however put another screw in from the other side, but had to run a piece of wire from it to the metal chasis.
Both methods will work.
simply split the lighter, remove the ignitor, drill a hole in the pipe, put the ignitor in, test the ignitor, and seal the hole with epoxy. its cheaper and its easier for those of you out there who dont know how to modify an electrical circuit
