The Panther Pistol
915
Published
Introduction: The Panther Pistol
About: I love Knex.
This is my second instructable and this gun is pretty good. At point blank range with four postal rubberbands it shoots almost all the way through a shoebox. It probably shoots 30-35 feet. I give the credit for the trigger and the barrel design to Viccie.B1993. Please comment and Rate!!!
Kookoo for knex
P.S. I am not liable for any damages, injuries, or crazy things you might decide to do with it.
Step 1: Piece Count
Rods-
38 green rods
16 white rods
5 blue rods
4 yellow rods
Connectors-
35 yellow
2 red
4 blue 3d
11 gray clips
5 orange
2 blue clips
Step 2: Stabalizer Parts and Handle Parts
1. Make 11 of these, except on one don't use a white rod, use a blue rod.
2. Better view.
Step 3: Trigger Parts
1.Make one of these.
2. Make two of these.
3. Make one of these
Step 4: Barrel Parts
1. Make this five times, except on one use a blue rod instead of a white rod.
2. Better view.
Step 5: Handle Assembly
1. Use the handle parts we made in step two to create this (Don't use the blue rod handle part).
Step 6: Trigger
1.Assemble this with the trigger parts.
Step 7: Barrel
1.Assemble the barrel parts and put the blue one in front.
2.Take the stabilizer parts and hook them on to the barrel with the blue rod one in front.
Step 8: Assembly
1.Hook the trigger onto the barrel.
2.Hook the handle onto the trigger and in the middle of the gun.
Step 9: Adding Rubberbands, Ammo, and Firing
1. Put on however many rubberbands you want on.
2. Put the red connectors on.
3. Hook it on like so.
4. This is my distance ammo, you can use whatever you want as long as you hook it onto the red connector.
5. How you put it on.
Step 10: Finished!!!
Hope you enjoyed it! Private message me if you have any questions!
Kookoo for Knex
    • Make it Move Contest
    • Microcontroller Contest
    • Slow Cooker Challenge
    18 Comments
    Not to be too harsh, but I really didn't like this "pistol."
    Just taking a section of the Sipriani Rifle barrel and adding an awkward, uncomfortable handle doesn't improve it. For what it's trying to be, there are much better guns for the pieces, even with mags. At least it has a proper trigger.
    For everyone reading this, don't assume you're a K'nex gun maker simply because you found out that a few pieces and rubber bands can fire a small projectile. Make sure it is decent and original. Also, FOR THE LOVE OF GOD, NO BLOCK TRIGGERS!
    Sorry for the small rant, it doesn't completely go for you. 1.5*, though.
    yes, that is what I think and you can't deny it.
    MY TARGET PISTOL LOOKS NOTHING LIKE THAT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    It does except for the handle.
    Whatever. Either you got it from me or Viccie B. 1993, because that is the same barrel concept and trigger he uses.
    umm, ok, pretty simplistic, not a lot to it. 3.5*=above average
    you know what, ill just bump it up to 4* because it has a true trigger and i can build this one twice (not saying that i will tho, i have other knex projects)
    This is neat! Good Job!
    Pretty good, Prety good but, i think your add-ons to my Sipriani are better :/ Anyway, 4 stars.
    everyone rate it 0.5. not to be cruel to kookoo for knex but it's not that good.
    its okay, at least its not block trigger
    well i would have to admit that ill go rate it higher because it's not a block trigger, and for that im gonna give it 5/5 stars :D
    Are you using #64 elastics??? Are you using 4 of them? Because this gun is amazing regardless of what you say.
    If you don't like it that is fine, but some people might like it. That's just me. kookoo for knex
