The Pee Battery
Introduction: The Pee Battery
Use your urine to make electricity! With the pee battery you can make enough energy to power a small electric motor. It is quite an easy project without the use of dangerous chemicals! All you need is
  1. an empty aluminum can (e.g. coke can),
  2. a piece of copper,
  3. vinegar,
  4. crocodile clips
  5. and urine
Following tools are handy for this instructable:
  • steel wool
  • can opener
  • electric drill
Step 1: Open the Can
  • Remove the top of the aluminum can. Use a can opener.
Step 2: Remove the Coating Inside the Can
  • Cans have a coating inside. You need to remove it.
  • The easiest way is to scrub it using steel wool.
  • By using an electric drill you can get this job done faster.
Step 3: Set the Battery Up
  • First, add urine to the can. The urine will act as electrolyte.
  • Second, add vinegar to the can. The vinegar will boost the voltage as it adds more acid to the electrolyte of this battery.
  • Third, put a piece of copper in the electrolyte. Connect it with a crocodile clip.
  • Finally, connect a second crocodile clip to the can. Make sure it touches the inside of the can.
Step 4: Power a Small Electric Motor!
  • The aluminum of the can is the cathode, which is the negative terminal.
  • The piece of copper is the anode, which is the positive terminal.
  • The urine in the can is the electrolyte.
  • Now chemical reactions inside the can create opposite charges on the copper and aluminium can, but the urine prevents the charge from flowing.
  • If you connect a motor to both crocodile clips, the charge flows through and powers the electric motor!
I hope you have enjoyed my instructable!
    • Epilog Challenge 9
      Epilog Challenge 9
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    can we use a light bulb instead of a electric motor?
    and how many voltage in the electrolytes solution?
    No its an alloy/copper battery with acid electrolyte
