The Poly-Cap
Published
Introduction: The Poly-Cap
About: Hey guys! This is Floppyman2! Feel free to check out my how-to projects! Hope you guys have fun and enjoy!
Hello guys! This is floppyman2. Today with a new invention, called the Poly-Cap, we are going to learn how to construct a simple cap that cools you down. To begin this we will need:
Wires 2x
Hot glue
A cap
A soldering iron
A DC Motor
A propellor
A Solar Panel
Step 1: Soldering the DC Motor to the Solar Panel
WHATEVER you do, never touch/hold the soldering iron by the metal. (This is what I did on my first try) ALWAYS hold the handle. First, hold your SIG wire and coat it with solder. (Use the tip of the soldering iron to spread the solder onto the end of the wire) Do the same with both sides of the GND wire. Then, using the soldering iron, press down the GND wire onto the back of the negative side of the solar panel. Do the same for the SIG wire, but on the positive side. Solder both the wires the same way onto the back of the DC motor.
Step 2: Hot-gluing the Circuit
After you have soldered, wait 5-10 minutes for it to cool down, and hot glue the dc motor onto the underside at the peak of your cap. Then hot glue solar panel to the top of your cap. WARNING: DO NOT GET GLUE ONTO SOLDER. Hot glue the propellor to the DC motor. You're all done! thanks for Reading! Enjoy!
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    why were you stupid enough to touch the metal!!??
