The Poor Man's Adjustable Bed Device
39,550
88
22
Posted
Introduction: The Poor Man's Adjustable Bed Device
This is my Instructable on how to make "The Poor Man's Adjustable Bed Device"  for a twin size bed. (Updated, see last step)
(Comments Appreciated!) :D
Materials you'll need:
1. Two plywood boards aprox. (35" x 31" x 0.5")
2. One plywood board  aprox. (34" x 16.75" x 0.25")
3. Four strips of plywood aprox (34" x 1.5" x 0.25")
4. Thirty-six 0.45" finishing nails
5. Four hinges (with screws)
6. Six 0.5" screws with bolts
7. Six small plastic washers
8. White glue or wood glue
9. Two sheets of sandpaper (one medium one fine)
10. Paint, stain, transparent lacquer or varnish
Tools I used:
1. Jigsaw
2. Drill
3. Rotary Tool
4. Sander
5. Drill bits
6. Tape measure
7. Hammer
8. Screw driver
Step 1: Sanding
Using a sander, sand all the panels with the medium sandpaper then with the fine sandpaper.
Be sure to round off all the edges and corners. Since this will be used on a bed, you don't want any sharp edges or corners.
Note: The more time you spend on this step, the nicer the end-product will be. :)
Step 2: Install First Set of Hinges
Measure 7" and make a mark from the long edge of one of the boards and do the same on the opposite end.
Place one of the hinges on the edge of the board and trace around it with a pencil.
Do the same at the other end. (Note: The long edge represents the width of the bed it's to be used on. In this case it's a twin bed.)
Next, if you have a router or rotary tool, carve out the area where the hinge will go just enough to make it flush or almost flush. (This is purely asthetic, so you can omit this part).
Next, place the hinge in the carved-out hole and mark the center of each screw-hole with your pencil, then with a drill-bit, (thinner than the screws you'll be using), make starter-holes for the screws. Try not to drill all the way through to the other side of the board.
If your hinge screws are longer than the thickness of the board, (like mine were), cut them as necessary or find shorter screws.
Install the screws on both of the hinges. Close the hinges and place the other board on top and align all the edges as best as you can.
Next, while the board is on top of the other one, mark the placement of the hinges of the top board with your pencil.
Now, "open" the top board as if it were a book and as if the hinges were attached to it. Open the hinges and align them with the markings you made. Make sure the boards are as close as the hinges allow and then trace around each hinge with your pencil.
Next, perform the same procedure as above to make the hinges flush or just pre-drill the holes and install the screws.
Step 3: Install Second Set of Hinges
As before... on one of the boards, (choose the one that looks the nicest on the bottom side as this will be the main top board), measure 7" from the edge on each side and 13.5" from the edge, (where the two boards meet), and  place a hinge and align it as square as possible. (I used my remaning board as a square to get them just right)
Once you have them just where you want them, trace around them with your pencil and mark the middle of each hole as well. Next, open the hinge so it's laying flat and also mark around the edges of the middle pin that holds the hinge together. Now, move the hinge aside and using the edge of the hinge as a ruler, draw two lines where the pin is located so that you end up with a small rectangle.
Next, using your rotary tool, carve-out the rectangle just enough to allow the hinge to sit flush (see second photo). Do the same with the other hinge.
Next, pre-drill the holes and install screws as shown.
Step 4: Install Stand
With your recently installed hinges in the closed position, place your last board on top of the hinges (as shown in first picture).
Align board with the other boards so that it's in the most square position possible.
Next, mark the edges of the board where the hinges will go.
Now, (as before), "open" the top board as if it were a book and algin the hinges to the markings you made and mark the center of each hole.
(Since this board is very thin, you will be using the 0.5" screws, washers and nuts here.)
Next, drill-out the holes using a drill-bit slightly larger than the thickness of the screws.
Now, attach the board to the hinges by placing the board bewteen the hinges (very important)  NOT as shown in the first picture. Insert each screw from the hinge side first, then the board. Add a plasic washers then the nuts.
If you did this correctly, when the hinge is in the "closed" position, the nuts should touch the other hinge. (See second photo)
Step 5: Install the Stops
Thoroughly sand all four strips of plywood untill smooth.
Take one strip and apply some glue on one side.
Next, place and center the strip almost to the edge of the opposite board, (the one without the stand & hinges), as shown in first picure.
Now, hammer-in one of the nails right in the middle of the strip. (try to not move the strip out of position when you do this. Also, be sure your nails are not too long. If they are, cut them so they don't come out the other side.)
Next, hammer-in a nail at about an inch from each end. Then do the middle between two nails and so forth until you have about 9 nails inserted. (see first photo)
Next, measure and mark  from the edge of the first strip about 2.65". (make two marks near each edge of the board)
Apply glue to the next strip of plywood and apply the strip at the markings you just made. Insert nails as with the first strip.
Repeat until you have all four strips installed. (See second photo)
Step 6: Testing Postitions
If you've reached this step, you're almost done!
Now that you've installed the stops you should be able to position the main board in five different positions. (including completely horizontal)
(See photos)
Step 7: Finishing Touches
Now, all that remains is to paint, stain, lacquer or varnish your very own "Poor Man's Adjustable Bed" (Pat. Pend.) ;)
Finally, you can see it in use in the 2nd photo. :)
As you can see in this particular application, there is a thin memory foam matress on top of the main mattress. Obviously, for this device to work, you'll have to use a flexible mattress that's not too thick.
After observing the 2nd photo, I realized that maybe I could have made it a bit shorter. When I went to measure there were a lot of pillows in the way and didn't realize that the bed was that far away from the wall.
So, if you decide that this might be too long for your situation, you might want to adjust the measurements as needed. But it's nothing that can't be "fixed" buy moving the bed away from the wall as in this situation.
Update #1:
Although this project proved to be very useful, it became obvious that lifting the top board from the "Flat position" was sometimes a bit difficult so I decided to add a couple of handles to solve this problem. If you decide to also add the handles, be sure to drill the holes all the way through and use screws and nuts... you don´t want the handle to suddenly come off unexpectedly! (see added photos)
Update #2:
After using the device for some time, it became clear that it needed another modification. On the edge where the hinges are located it required some sort of tapering to minimize the small "step" that could be felt while in use. I purchased some Rubber Wall Base Molding at Home Depot and attached it to the end on both sides with rubber cement and thumbtacks and added some filling using one of those pool spaghetti floating devices cut in half lengthwise. (see added photos)
    • Space Challenge
      Space Challenge
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    22 Comments
    Very nice,job and a public service as well,there are many elderly folks,and the sick needing hospital type beds,and this looks to be a very good substitute.I have Psoriatic Arthritis (Mutilans) and though I get around pretty well most of the time,the arthritis in my back keeps me awake often,Im going to make one for myself,it looks like just the ticket,thanks.
    Thank you very much for your comments. I'm so glad that you found this useful and hope yours turns out great! Please post a picture of your project if you can. :)
    Awesome! Really cool, when function, beauty and spirit meet in one project!
    Thank you for the great comment! :D
    I´m glad you liked it! :)
    It's really strange, i was just thinging about buying a foam wedge. With This GREAT instructable. I don't have to. I have all the material on to make this.
    GREAT instructable.
    Thank you
    Awesome! I'm glad you found it useful and hope it turns out great! :)
    Post a picture of your's if you can. :D
    My dad fell, breaking several ribs, and was not able to lie flat in bed without much pain. I made this device and he is now able to sleep in bed now. Thank you and God bless.
    I'm sorry about your dad but I'm happy that this Instructable was able to help him. God bless you both. ?
    So simple! Well done!
    I'm feeling silly. Some years (decades?) ago, I spent a lot of energy trying to figure out how to make a DIY mechanism or jig to elevate the head of a bed. My ideas were a lot more complex than this. Including using a hydraulic jack as the lifting device. If faced with this again, I'm grateful for a simpler design.
    For the person wondering about extending the design to a queen sized bed, may I suggest making each side of the bed raise separately rather than one wide platform? Just a thought.
    [ If two people are using the bed, then they may need to sleep at different elevations. Seems to me, having watched elderly family members who have gone through this, one of a couple having to move to a hospital type bed would be a wrench for long-time partners. It might be a comfort to be able to stay in the same bed, even if needing two different elevations. There might be an advantage also to a flat surface alongside a single occupant. ( Of course, splitting the bed down the length does mean using two sets of linens and two top mattress layers. ) ]
    Thank you for your nice comments! I'm glad you liked the design and I hope it comes on handy someday. :)
    I needed a quick solution for my father and this idea came to me and fortunately, it worked out really well.
