I have developed a new method of applying rustoleum as an automotive paint that is, in my opinion, vastly superior to applying it by roller. A method I have come to term The Poor Mans Paint Job. This method of paint at home application relies very much so on the methods seen in other online auto paint how-to's, but uses a different paint application technique in order to lessen the amount of sanding involved. This method uses a high density foam brush as opposed to those other methods, resulting in a lot less sanding to finish the job.
I have seen plenty of people paint their car at home with a foam roller brush, with good results. BUT, it takes a lot of sanding work to get it right. I have also seen people use a sprayer with Rustoleum providing excellent results as well, but then you get into dealing with the overspray, needing a sprayer and somewhere to do it.
If the Poor Mans Paint Job is performed correctly, it will help to lessen the amount of sanding involved with an at home auto paint job like this. Oh, there will be some sanding involved, but we will try to keep it to a minimum. Of course, if you are not happy with the finish without a final sand and polish, just prepare for that scenario ahead of time. Make sure to lay down enough coats throughout the procedure to be able to sand at the end if you like. However, I am a lazy SOB and would like to not have to sand too much.
You too? Here's how!
DISCLAIMER: I am in no way responsible for the results of this project when tried at home by you. This is what I did, and this is how it came out. Am I happy, yes! However, I can in no way provide any assurance that your attempt at this will turn out as well or be as satisfying. Please also see step 5, "downsides and drawbacks" before making your decision to try this at home.
Obviously, it worked well enough for me. I cannot guarantee that it will work this well for you. Please, try this at your own risk. BUT, feel free to contact me with any questions or concerns.
Step 1: Supplies
Item Quantity Total Cost
Rustoleum high gloss white paint - 3 Quarts = $23.61
Odorless mineral spirits - 3 Quarts = $17.97
Primer spray paint - 1 Can = $4.99
4" High density foam brushes - 7 ea. = $5.67
2" High density foam brushes - 7 ea. = $3.95
Paint trays - 3 ea. = $3.21
Sandpaper - 2 packs = $9.50
Painter's tape - 1 Roll = $5.84
Total: $74.74
I would say that two or three quarts of paint is all that you will need. Two will do a small car, three your average size car. If you are going to tackle an SUV or large truck, you might need four or even more to finish the job. I laid down six coats on the car and seven on my body kit, bumpers and hood with three quarts. Make sure to use high density foam brushes as they will hold the paint very well and help to eliminate residual brush strokes. As with any project, be sure to purchase everything you will need and have it handy once you begin.
Step 2: Prep Work
First, wash the car and all pieces to be painted real well to remove any loose dirt. (Pic 1)
Next, remove anything from the car that you can, this will help avoid the possibility of getting paint on things you don't want it on. This is to include headlights, tail lights, trim pieces and more depending on the car. (Pic 2) I took off my bumpers and side mirrors as well. The bumpers because they have a few "style indents" in them that I wanted to be able to paint in a horizontal manner as opposed to vertically while mounted to the car. The side mirrors I painted as well so having them off of the car made that a lot easier. I also removed my body kit pieces as not to drip on them while I painted the car itself. I guess what you need to remove will be personal preference depending on your painting style and needs. Once everything is removed, you can really get to work.
Everything that is going to be painted needs to be wet sanded with 600 grit sand paper. This will help to further remove any impurities from the paint's surface giving you a clean slate to work with. Move down to 400 grit if you have a problem area. Make sure to use a sand paper designed for wet use. Once the sanding is complete you will need to look for any spots where the paint has chipped off or the sanding has exposed some of your base metal. If you find any, spray them with a quick coat of the spray primer. This will help make sure you have a nice even looking finished product. It will also help to ensure the finished paint resists cracking and peeling from the damage to the old paint. Of course, if you have any body work you need done, now would be the time to do it. (Pic 3)
Any trim pieces that do not easily remove you can tape up with the painter's tape. Make sure to double check your tape job before you begin. You do not want to be in the middle of painting and realize you did not tape something up! (Pic 4)
Step 3: Paint!
Now, you need to determine how you are going to go about painting the car. It is wise to paint each coat in the same manner to make sure you do not lose track of where you have laid paint already. Plus this makes things go a little smoother all in all. Here is a quick breakdown of how I went about painting my car: Started with the top of the car, passenger side then moved to the driver's side - passenger side of the hood - then the driver's side of the hood - back to the passenger fender - passenger side of the car until I got to the door - up the small strip of door across the top of the door and back down the the rear fender's top - back to the front of the side of the car all the way back to the rear of the passenger side - trunk lid and spoiler - driver's side rear fender till the door - up the door trim again to the front of the car - back to the rear of the driver's side and forward to the fender - driver's fender and done! Essentially it was a clockwise circle around the car starting at the passenger side of the hood. Except once I was done with one side of the hood or the roof, I jumped to the other side to finish. Keep in mind that this is what worked out best for me and my car. There are deep body lines between the roof and the rest of the car making it easy for me to paint it as a "separate piece".
As I begin to explain the painting technique, you will see why it is important to keep applying paint to the car in some sort of order. Letting one area dry with an edge left undone and then coming back to it will only create paint lines in your final product. Your only break points should be at the edge of the car's body. Like between the fender and door, or the door and the roof.
Now we are ready to apply paint. Pour some of your well mixed paint into a paint tray and let's get started. For large areas of the car I used a 4" brush to apply the paint. For large, even flat spots such as the hood or the trunk you will want to get a lot of paint on the brush. I usually dipped the brush into the paint until the angled tip of the brush was completely submerged. Now simply start to paint it onto the car. The key here is in the technique. Proper use of the brush is what helps to eliminate any brush strokes or orange peel. First, lay on some paint, pretty thick, to an area. Always make sure to paint one decent sized area at a time. Spread the paint out a bit to cover the area you are working on. Now, that you have a good base to work with, simply run the brush over the area you have well spread paint. Just use the weight of the brush itself and slowly glide over the paint making sure to always stroke in the same direction. This final smooth roll over the paint is what helps to eliminate any weird drying patterns. Moving on to the next section make sure to spread a little bit of new paint over the edge of the area you just painted to ensure smooth even coverage. As you move through the project, make sure to take a look back frequently to areas you have just painted to look for any drips or sagging areas. If spotted, simply give them a quick brush over. Lay down three coats of paint this way allowing at least 6 hours of dry time between coats. (Pics 1 & 2)
Here is a link to a video of me laying down some paint to help illustrate the technique. It is not the best video, but it should help you grasp the process better.[http://smg.photobucket.com/albums/v326/StylussKid/Paint%20Project/?action=view�t=MOV06158-1.flv Paint Application Technique]
Once you have 3 layers of paint down bust out the hose and the sandpaper. Give everything a good wet sand session again at 600 grit. Keep in mind that you are not trying to create a completely smooth surface again, but to take out any major bumps and to rough up the paint some. If you see areas with a bit of dripping, sagging or any other mess, just sand them down accordingly. This is your chance to correct any imperfections in your paint job as well. If you are happy with the way the 3rd coat looks as it stands and there are no drips or imperfections... feel free to skip the sanding.
Now that your base has been put on and you have given it a decent sand we can start on the final few coats. I say few because the amount of coats will vary on a few factors. Did you need excessive sanding due to a problem area? Are you changing colors? Are you happy with the look after 2 coats? Well, that would be a good place to start... at two coats. Then move to three if need be. Four if you really must. If you pass four coats after your first session of sanding, you will want to give another quick sanding session to the paint before moving on. This time move up a bit in paper grit though. 800 or 1000 will do. (Pics 3 & 4)
At this point you should be done! The paint will have its own gloss to it as it is natural to the Rustoleum paint. Feel free to wax the paint to help bring out some extra shine. I would wait one full day before washing or waxing the paint though to be safe. The Rustoleum can says it dries in 24 hours, but since we have diluted it so much it will dry a lot quicker. I had about 12 hours between coats. But if you are doing this in warm weather, you should easily be able to get 2 coats on the car in one day with an early start. Once you have laid on all of the coats you want to and are happy with the final result, let the paint dry for at least 12 hours. I finished the final coat at about 6:00pm and began putting the car back together the next morning at 10:00am.
If you are not happy with the look, continue to sand the paint progressively increasing the paper grit. Start at about 800 or 1000 and move to 1500, then even 2000 or 2500. Once the paint is totally sanded smooth, polish the car with a power spin buffer and the gleam will come back but be smooth as butter. You can refer to the 50 Dollar Paint Job for more in depth information about the sanded finish technique. I am happy with how it looks wihtout the sanding, so I stopped here.
Step 4: Final Result
Step 5: Downsides and Drawbacks
I have been told that the paint will chalk, chip and fade all within a year. I have also been told that if you want to seek a professional paint job after having performed this paint job on your car, you will need to have all of the Rustoleum stripped off completely before the new paint can be applied.
My rebuttle...? So what.
Even if the paint does chip, fade or crack within a year, I'll just throw another coat on and perhaps improve the prep work to help avoid it happenign again. Now that I have painted the entire car, I think I could paint one damaged area rather quickly... even the whole car again if needed. Plus Rick, the gentleman who did the $50 paint job write up, posted pictures of his car at 4 months, 8 months and a year after his paint job was complete. He shows no signs of anything past normal wear and tear on his paint. His car, just like mine, is a daily driver and is parked outside nightly. However, he did finish his paint job with some heavy sanding and a polish.
As for seeking a professional paint job after having performed this one, I dont think so. That was the purpose of doing this myself! To not have to pay someone else to do it! If you are thinking of getting a professional paint job on your car in the future after having done this to it, perhaps you should seek some knowledge from the paint shop first.
Again, is this a method you would use on a rare collector car? No.
On a professionally built show car? No.
Should you do this to the old beater VW Beetle you have out back? Sure!
What about the $500 car you just bought for your son or daughter? Perfect!!!
Please, read this write up in its entirety and ask any questions you may have before jumping into the project. I would reccommend trying this on a test piece such as an old fender or maybe even your lawn mower before attempting to paint your car with this method.
With all of that being said, please take a look at the picture below. As you can see the final result yielded some brush strokes. That is about as bad as any of the spots where you can see the brush strokes. A small price to pay for a $75.00 paint job!
Step 6: UPDATES!!!
http://www.stylusscustoms.com/poormanspaintjob.html
Visit Our Store »
Go Pro Today »
We have a beater car that we want to improve the look.
1) Were you limited by the choice of colors from Rustoleum?
We were considering buying a professional series of Urethane BaseCoat/ClearCoat system, but was priced at between $240 (TCP Global) - $700 (PPG)
2) Do you need to topcoat with a clear coat? We live near the ocean and the salt air is causing the clear coat to peel on our current car. I suppose if you paint with a one-stage system, you don't need clear coat at all, so nothing to peel off? But doesn't the clear coat make things last longer?
I'm a pro painter of 40+ years...it's likely that the peeling clear coat on your car was a waterborne formula. They've got these to where they last 5 years and that's it.
Rust-O-Leum is paint I love to hate, but after seeing this Instructable, I've got to give kudos to the author. Tip: stay away from dark colors. Also, there are many high-gloss enamel paints with high pigment content that would also work. Rust-O-Leum is known to be brittle once dried, and stone-chips easily!
The brittleness and proness to stone chipping convinced me to go with a professional formula.
2. I am not a paint savvy person. All I know is that I have had Rustoleum on my car now for 2 Colorado winters... no issues. I do not have any sort of clear coat on my car. It is simply Rustoleum.
I bought a gallon and the matched the color for my when I removed the gas door from my car (cleaned it, polished it) All they did was scan it and they add the pigment. For my car is was 4 units of chroma yellow, 1 part blue and 1 part red. My car is an off white cream color and it matched fairly well.
I would love to see your car to see how that cream looks. could you post some photos or email them to me??
Does anyone have any opinions on having two tone" Is it a bit over the top in a sedan? I saw a 37 Oldsmobile done this way but the red was too red in my opinion Any comments or opinions would be greatly appreciated mmdowd@gmail.com
Also has anybody got any ideas on color schemes, I need to get the plan right
although you do not indicate that in this particular method on this page that you you used a clear coat... do you have a cheap, effective, UV protection ideas of paint that i can get at a hardware store or something?
Also, with prepping the car, i have a few spots that definitely need some bondo topped with primer but there are spots where the paint has CLEARLY cracked pretty deep. how would you suggest buffing the cracks out so they dont show through? and do you only sand down to get the factory clear coat off or do you want to sand a little deeper but not to metal... Also, is there a method of sanding that doesnt require tons and tons of circular motions that quickly wear your hand out?
i also have a few more questions that i cant seem to find on google because i dont know what the parts are called, however, i will wait to ask before i over load you too much.
i have posted a few pix of my car now and the problems that i hope to fix . With bondo, should anything be applied to the cleaned up area prepped for bondo to help it adhere to the paint, body panels?
the pic of the thing that isnt actally my car is what i my goal is for a paint job. I also have a good feeling that with the metal specks, any minor flaws will blend it much easier and hide imperfections as oppose to one straight color.
Now i just have to wait until i have all the supplies and a few nice days since i dont even have access to a garage. but i can make some makeshift wind guards to keep dirt and bugs off... however, i think they wont be noticable. but my yard is surrounded around trees and this is a good time of the year to start seeing your car covered in pollen... so we'll see.
I figured I am painting a car with Rustoleum... How much work do I really need to put into this?
I've done much research on the questions i asked. However i have one more that i cant find anywhere on the internet and maybe you or someone else on here has an answer. Even though you didnt clear coat the car, if i were to clear coat with something like rustoleum auto body clear coat for extra protection for paint fading and scratches... would i want to cut it with mineral spirits as well for this application?
Thanks!
Need some advice and clarification
In view of difficulties in Australia of getting Rustolium and a restriction in colors
1 Could the same job be done with some other product an acrylic or an Enamel
2 There seems to some difference in opinion in prep. If existing paint is in fairly good condition would a light sand or cutting compound with electric lambswool cover suffice
Oh, and here's a tip. Do not paint your car garden furniture green. Everybody, and I mean everybody, recognises it, and everybody, absolutely everybody, even strangers walking past, comments "that looks like somebody painted it with garden furniture paint" and look smug just like they solved the Da Vinchi code.
Absolutely everybody.
Mike
Interesting to know if Galmet is the same
http://www.rustoleum.com.au/contact.asp
Thankyou I would like to look at your job. You say you have to get your "spray technique just so". The idea of my project is no spray, all with a 4" brush
Yeah, well, I have chosen this paint because it does a good job as protective paint - rust - and the car I am doing I want around in 20 years time. Its also a car that attracts a lot of attention and is endlessly being vandalised. So this way I can give it new shiney coat every three years or so and repairing replacing a panel is not such a big drama.
Remember you can buy a cheap compressor and spray gun these days for a handful of dollars - and even bad guns will do a better job than a brush. Even a hoover spray gun off a vacuum cleaner does a better job.
Oh! A spray booth? Go buy a 3 metre by 6 metre garden gazebo - and paint the car bit by bit. Use an old vacuum cleaner and a long hose to blow fresh air in your face while you work (still use face filter) - this also introduces clean filtered air into the work area.
I have a 1939 Buick sedan needs paint It is cream in original colour
I am wondering about paint descriptions or terminology. I am in Australia and have been advised to use an Acrylic paint
Would much appreciate any advice or comment
Cant contact them till after new year
I don't have the time to paint on one coat of black (the car is already black) and then wait a day for it to dry before applying the next coat. What happens if I put on 3 coats in one day, spaced about 4 or 6 hours apart?
The one skill I do bring to the job is I am a good sander. So I hope to get 3 coats on the car, rub it out, and then 3 more coats and sand it using 600 grit, and then the 3 different polishes I have (3 different grits) using the orbital buffer.
I'm hoping that by putting on a bunch of coats maybe a little too quickly, I can make up for it with good sanding/buffing/polishing.
The car is a "beater" (1997 2 door Civic EX with 180,000 miles) but I'd like to keep this car for 2 years. Also, if I do a decent job with the black, then I'd like to have some fun with it and put a stripe or two on it, as well as some flames coming off the front wheel wells.
Love the site. Thanks for your procedure.
BHD
I just bought my first car (I'm 17, got a '98 Mustang) and it could use a paint job.
I have been looking at methods of painting for some time and was going to just give in and buy an airbrush, until I saw this. It seems like exactly what I want!
I do have some questions, however, hopefully you (or someone here) can help:
Firstly, there is some minor body damage on the driver door, I'm going to fix it with bondo, but I was wondering if there was any special steps I needed to do for the bondo. Do I need to primer it like I would bare metal, or treat it like the rest of the car?
Second, I am planning on applying a custom vinyl graphic to the side of the car, it's self adhering and all that good stuff, but I was wondering if this paint would, maybe, not be able to hold the weight of the graphic. I know this is sort of a stupid question, but I just wanted to get your opinion about applying a graphic to this paint job.
Hope to have pics up as soon as I can complete this project! Thank you so much!
As for painting on bondo, I honestly have no idea.
I have an old car that needs a paint job and will try again and steal a page from your book. btw rustoleum looks good and holds up for a long time.
Thanks
Is it possible to paint the bumpers with this method too? My bumpers are plastic soft bumpers but they need new paint as well. Can I use the same method as stated in your writeup? Sand the paint off, then paint as normal?
