Step 2Prep Work
First, wash the car and all pieces to be painted real well to remove any loose dirt. (Pic 1)
Next, remove anything from the car that you can, this will help avoid the possibility of getting paint on things you don't want it on. This is to include headlights, tail lights, trim pieces and more depending on the car. (Pic 2) I took off my bumpers and side mirrors as well. The bumpers because they have a few "style indents" in them that I wanted to be able to paint in a horizontal manner as opposed to vertically while mounted to the car. The side mirrors I painted as well so having them off of the car made that a lot easier. I also removed my body kit pieces as not to drip on them while I painted the car itself. I guess what you need to remove will be personal preference depending on your painting style and needs. Once everything is removed, you can really get to work.
Everything that is going to be painted needs to be wet sanded with 600 grit sand paper. This will help to further remove any impurities from the paint's surface giving you a clean slate to work with. Move down to 400 grit if you have a problem area. Make sure to use a sand paper designed for wet use. Once the sanding is complete you will need to look for any spots where the paint has chipped off or the sanding has exposed some of your base metal. If you find any, spray them with a quick coat of the spray primer. This will help make sure you have a nice even looking finished product. It will also help to ensure the finished paint resists cracking and peeling from the damage to the old paint. Of course, if you have any body work you need done, now would be the time to do it. (Pic 3)
Any trim pieces that do not easily remove you can tape up with the painter's tape. Make sure to double check your tape job before you begin. You do not want to be in the middle of painting and realize you did not tape something up! (Pic 4)
We have a beater car that we want to improve the look.
1) Were you limited by the choice of colors from Rustoleum?
We were considering buying a professional series of Urethane BaseCoat/ClearCoat system, but was priced at between $240 (TCP Global) - $700 (PPG)
2) Do you need to topcoat with a clear coat? We live near the ocean and the salt air is causing the clear coat to peel on our current car. I suppose if you paint with a one-stage system, you don't need clear coat at all, so nothing to peel off? But doesn't the clear coat make things last longer?
I'm a pro painter of 40+ years...it's likely that the peeling clear coat on your car was a waterborne formula. They've got these to where they last 5 years and that's it.
Rust-O-Leum is paint I love to hate, but after seeing this Instructable, I've got to give kudos to the author. Tip: stay away from dark colors. Also, there are many high-gloss enamel paints with high pigment content that would also work. Rust-O-Leum is known to be brittle once dried, and stone-chips easily!
2. I am not a paint savvy person. All I know is that I have had Rustoleum on my car now for 2 Colorado winters... no issues. I do not have any sort of clear coat on my car. It is simply Rustoleum.
I bought a gallon and the matched the color for my when I removed the gas door from my car (cleaned it, polished it) All they did was scan it and they add the pigment. For my car is was 4 units of chroma yellow, 1 part blue and 1 part red. My car is an off white cream color and it matched fairly well.
I would love to see your car to see how that cream looks. could you post some photos or email them to me??
Does anyone have any opinions on having two tone" Is it a bit over the top in a sedan? I saw a 37 Oldsmobile done this way but the red was too red in my opinion Any comments or opinions would be greatly appreciated mmdowd@gmail.com
Also has anybody got any ideas on color schemes, I need to get the plan right
Also i am painting the vehicle yellow but want to add a few black stripes to it, can i just paint these right over the yellow rustoleum/mineral spirits paint without sanding or other prep work?
Anyhow, have fun and don't be afraid to be creative. I started out with Rustoleum and tried to shoot it with a paint gun (not smart). This brush-on method is a great idea. I started with a home-made shed and eventually built a custom body shop. I closed it 2 years ago, but hoping to start another one. Wanna see how extreme this can get? Check out my custom 1992 Lumina. I bought this car for $800. Look how overboard I went ---> http://carltonzone.com/blog/my-1992-lumina-project/
(yes, I am a Chip Foose Wannabe!)
Write back if you have any questions, I'd be glad to advise.
Carlton
As for the stripes... well, I have never done that so..... one would think you can paint them right over the yellow with no issue. If anything, just use some painters tape to mark off your lines and then paint'em up!
