3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Portal Door
The Portal Door
I will show you how to put portals on your door or wall.
Step 1The template
The template
You will need the template somewhere under this text. It is very big (7500 x 500 pixels), because it has to be printed on a very big paper (makes sense, huh?).
What it contains:
- 2 portals in orange and blue. They have a transparent background that has to be replaced with the pictures from step 2.
- 2 Portal logos. One is bigger than the other one, I cut the letters out and glued them under and over the portals, this looks a lot more professional ;)
- A nice picture of my favorite cube, the Companion one! I just don't like the feeling of wasting space, cut it out or throw it away, I don't mind.
The template is available for a white and a (dark) brown background, because the boundary of the portals are blurred. The picture down there shows what it looks like, but please don't use this, because it is way too small.
Here you can get the template in both colors:
http://www.2shared.com/file/i-X44T3D/portaldoor.html
149 comments
1-40 of 149next »
May 9, 2012. 7:56 PMMrRandomnez says:
Could you please email me the image because none of these links work?
May 9, 2012. 7:59 PMMrRandomnez says:
My email is mrrandomnez@hotmail.com
Apr 22, 2012. 10:30 PMstratisfire says:
i think it would be cool if you could somehow display video on the "portals" so you could have on upstairs and one downstairs and be able to see what is coming from the other camera.
Apr 3, 2012. 8:35 PMAtlas Portal 2 says:
can you send me the template my Email is: alcatraz2033@yahoo.com
Oct 28, 2011. 2:17 PMerowe says:
This is amazing. Could you upload the template again?
Oct 28, 2011. 6:56 AMbatonas says:
great idea but you should cut a hole in the door for more realism :D
Aug 6, 2011. 8:57 AMjjunod1 says:
What I did was sorta a play-off of think geeks portal shirt (here) http://www.thinkgeek.com/stuff/41/portal-tshirt.html and i kinda made a frame by printing it twice then i put a screen in them then sealed it
Jul 24, 2011. 2:03 PMandyxxpanda says:
it would be cooler if you hung one on the oposite side of the room
Jul 20, 2011. 2:28 PMchampionx5 says:
only thing fail about this is if u take the picture during theday then itll look fake at night
Jul 22, 2011. 12:47 PMfreakyqwerty says:
Need to have part of the door as glass...
Feb 25, 2011. 11:38 PMUpgradeTech says:
I'm sorry, but I've tried all the links in the comments and I cannot find the template anywhere. Could you repost it?
Jul 11, 2011. 7:20 PMJohnRulz says:
Not working either. Try a different file sharing site, or set up a torrent. Torrents are more reliable than file sharing sites, if you can get enough seeders. You could also set up something on an image sharing site. I am not sure how large the file is, but Flickr has the larges limit (to my knowledge) of 10 mb
Jun 29, 2011. 11:30 AMtinker234 says:
hey could i add a projecter and 2 cameras to make a projected image of each side if they change also be cool to have a hole so you could walk thourgh
Jun 27, 2011. 6:01 PMtinker234 says:
wow hey could cut a hole in the door to go thourgh
Jun 23, 2011. 2:56 PMblanchae says:
I wonder if it would better using a mirror instead of a picture?
Jun 23, 2011. 12:30 PMralphkidsguns says:
this was a triumph.
i'm making a note here, huge success!
AMAZING!
Jun 23, 2011. 11:03 AMjarnold3 says:
This was a triumph...
Jun 18, 2011. 2:44 AMmonkeys98 says:
could i make it bigger so that each portal can cover more of the door?
Jun 11, 2011. 10:14 AMreddog92396 says:
Hah ! Nice! You should have just cut a hole in the door! LOL that would have been funny I can see people's reactions
"Woah an actual portal!"
May 28, 2011. 12:09 PMnclarke says:
Should I use Paint Shop, or Paint Shop? Which do you think would be easier?
May 25, 2011. 1:53 PMHigley1089 says:
I made a much smaller version using paint.net a regular printer and a camera.
(i needed to make a small one anyway. My door isnt Flat)
Apr 21, 2011. 1:09 AMSTICKDUDESHOOTER says:
How do you do that im noob with photoshop
May 14, 2011. 4:59 PMnubabuba says:
you simply take the two photos, drag one onto the other, and resize, or remove any nonwanted areas.
May 12, 2011. 4:13 PMasarris says:
I like it just cant find paper that big, i took my dads old projector and a web cam and hooked it up together. Then i put one of your portal image on the other side and i had a portal that i can outside and they think its fake.
May 4, 2011. 4:54 PMThe nerdling says:
you could use two projectors and web cams then print the outline of the portal then project the inards of you room using the webby and projector into the outline and do the same with the other "portal"
May 12, 2011. 1:10 AMSTICKDUDESHOOTER says:
im confused
Jun 30, 2010. 3:35 PMdemonkiller111 says:
You know it might be easier to get a door with a round window in it and just paint the portal around it.
Jul 1, 2010. 8:07 AMThe_Auror says:
What's the point of having a door if anyone could see through it then? Yeah, I tought so...
Jul 8, 2010. 12:32 AMWhiteTigerTails says:
Just make it so that it can be closed.
May 4, 2011. 4:56 PMThe nerdling says:
you could make an iris like on cameras
Jul 1, 2010. 9:23 AMdemonkiller111 says:
hmm you do have a point there, :s
May 31, 2011. 7:02 PMThe nerdling says:
ok, i will talk about the portal on the outside, so the cameras see what is in the room ad the projector projects the image onto the door.
you doo the same with the other side
Apr 12, 2011. 4:22 AMSTICKDUDESHOOTER says:
umm can u upload the file to megaupload or atleast rapidshare cause filehost is dead
Apr 4, 2011. 6:42 PMDumchicken says:
you should of cut a hole in the door and put very clear glass on it so when someone
looks at it the'll see the backround change so the'll try and go in it but then WAM!
Mar 25, 2011. 6:01 PMSHIFT! says:
Wow, what a creative idea! I would love to hang one of these from my office and in the employee lounge, you know, to keep the subordinates in line.
Mar 25, 2011. 7:45 AMXfrim says:
HOW U GET THA CAMERA?
Aug 3, 2009. 5:04 PMMikyVengeance says:
Now You're Thinking With Portals :)
Nov 23, 2009. 12:57 PMDuct Tape Dude says:
definition of portal: a hole in the sky....thru which we can...fly.
Mar 21, 2011. 2:13 PMdombeef says:
Ha ha funny
1-40 of 149next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
78
Author:ddi7i4d(TransparentTees)
