The PotLock
752
12
Published
Introduction: The PotLock
About: radom diy projects
this is a 3 digit combination lock with potentiometers, logic gates and differential comparators
Step 1: Connection Diagram and Parts
i use (take a look at the links)
    2x lm339: https://www.win-source.net/en/search?q=lm339
    1x 74HC02: https://www.win-source.net/en/search?q=74HC02
    1x 74HC10: https://www.win-source.net/en/search?q=74HC10
    6 resistors 10k
    6 potentiometers 100k
    the voltage is 5v DC
    Step 2: How Its Works
    with the Differential Comparators you can compare different voltages
    look the diagram for the connections
    if the lm339 output 0 is on
    so i use NOR gates,i connect the outputs from comparators to the NOR inputs
    and the 3 outputs from the NOR gates to the inputs of a triple NAND gate
    when the left potentiometers are at the same position with the right potentiometers
    the output is 0 (ON)
    (LOOK THE TRUTH TABLE)
    Step 3: Leds
    if you want to see how the circuit works use leds at lm3391,74HC021,74HC10 outputs like the picture
    Step 4: The Combination
    print the numeric pads for the potentiometers for easiest setting of the combination
    Step 5: End
    you can use it just for education or you can lock something like box with a magnetic lock, add at the output a
    PNP transistor with a relay or a N-Channel mosfet to control bigger loads than one led...
    follow and subscribe if you want
    THANKS
      • Clocks Contest
        Clocks Contest
      • Oil Contest
        Oil Contest
      • Creative Misuse Contest
      2 Discussions
      gm280
      7 months ago
      Interesting project. And you made it without an Arduino. That in itself is refreshing to see.
      thanks a lot!
      My first arduino board, the arduino leonardo broken at the first week so i try to learn about PICs. Arduino is very good but we cant use arduino everywhere and we mast not forget the clasic electronics
