3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Prism: A Laser Synth-Guitar
  • last photo ←
The Prism is, quite simply, the best laser guitar on the Internet. At least I think so. I hope that you take these instructions and not only make your own, but improve on my design!
I suppose I should clarify what the Prism is: It's a bit like a guitar with some synthesizer mashed in. It has aspects of a theremin and a laser harp thrown in to boot. In short, it's not like anything else, and you can use it to make some really neat sounds. Anything from cold Sine and harsh square waves to heavily distorted noise.
At its heart the Prism features a VCO (Voltage Controlled Oscillator), based around the very shiny XR2206 monolithic function generator. The octave range is selected by blocking one of four laser "strings," and the pitch is controlled by the position of the musician's hand on the fretboard. The musician has the option of selecting a sine, triangle or square wave. The sine and triangle waves can be skewed using a separate Skew control.
It also has two other controllable oscillators, one acting as an LFO (Low Frequency Oscillator) and the other acting as a Sync generator.
I designed the Prism to plug into any regular guitar amp, with no computer required. In fact, there is no programming involved at all in this project! It is just as portable as a regular guitar, and meant to be used at gigs or wherever else an "alternative" instrument is needed!
Here is a video showing the basic functions:
And here I demonstrate the on-board effects:
Visit the Sample page to hear me "jam!"
Step 1How It Works
How It Works
I searched the Internet for days looking for the perfect solution. At first I considered making the Prism a MIDI device, controlled by an Arduino (like the Laser Harp seen in MAKE Magazine). Ultimately, I decided to make it completely standalone, like a normal electric guitar, requiring a minimum of external equipment and compatible with everything.
That led me to research various (all-analog) oscillator possibilities. This time simplicity was key, since it all had to fit inside the body of the guitar. There are a number of single-chip voltage controlled oscillators out there, but the only one that is actually in production is the XR2206. This neat little device takes a control current or voltage and produces either a sine, triangle or square waveform that is proportional to that control. The control can be as simple as a potentiometer, or something more complex like the infrared range finder I used. During my search I happened upon a most excellent design by Thomas Henry. It had everything I needed to get started.
The Prism is based on Thomas' design, with a few modifications. I removed some of the control inputs, such as the exponential FM and voltage-controlled Skew. I then added my own custom-designed laser-controlled capacitor bank, a hard-wired LFO generator (based on an XR2206 reference design from the datasheet) and a hard-wired "sync" circuit based on a 555 timer. Oh, and a Sharp Infrared rangefinder to control the pitch.
So how does it work?
Well, I mentioned before that the output frequency is controlled by an input voltage. The three input control voltages, Coarse (the range finder), Fine (a trimpot on the board), and LFO are all mixed together and converted to a current (taking the place of a potentiometer). This current, along with a capacitor from the capacitor bank, determines the frequency produced by the XR2206.
Normally you'd only use a single fixed capacitor, but I wanted each laser "string" to select a different frequency range. The Prism accomplishes this by having each laser trigger a phototransistor, which in turn controls a comparator. If the laser is blocked, the phototransistor turns off and the comparator goes low. This causes a solid state relay to turn on, connecting its corresponding capacitor to the XR2206's capacitor input. When no lasers are blocked, no capacitors are connected and the oscillator produces a frequency above the audible range.
To control the pitch, I used a Sharp infrared rangefinder. You've probably seen this used on autonomous robots, and perhaps some theremin-type instruments. This neat little device measures objects between 10 and 80 cm away, and generates a corresponding analog output between 2.4V and 400mV, respectively. This voltage swing is quadrupled with a simple op-amp on the board.
The desired output waveform is selected by turning a rotary switch, that selects between the sin/tri output and the square output. The frequency and amplitude is the same no matter which waveform is selected.
The skew knob causes the triangle and Sine waves to skew - that is, they get chopped up and lean to one side or the other. For instance, the triangle wave can be made into a ramp for a slightly different sound. The effect is even more pronounced with the sine wave, which goes from a nice clean sound to very harsh and metallic.
The LFO effect can be varied by turning a knob, and turned off by pushing the knob (a very clever design, if I do say so myself!) Its effect can be varied from a slow rise and fall, to a nice vibrato, to a high pitched trill sound.
The Sync only affects the Sine and Tri waves. It is also controlled by a rotary knob, and can be switched off. Each time it transitions it causes the main VCO to reset, chopping up the sound in interesting ways.
There are also a few more on-board trimpots, used for tuning the output waveform. These are only touched once when the Prism is first constructed.
The Prism can be plugged into any regular guitar amp, or it can be modified to control a separate synthesizer setup.
A separate power supply is also needed, that produces +15, -15 and +5V. The lasers are driven by a 3V regulator that "spoofs" the voltage the lasers are expecting.
374 comments
1-40 of 374next »
Apr 13, 2012. 4:36 AMtejask says:
can i gt the schmatic circuit diagram of the circuit above
Mar 22, 2012. 8:10 PMpblanscet says:
Wow, man. You got skillz!
Aug 5, 2011. 7:18 PMccowsert says:
About how much in total, minus the guitar, does this cost to build? i'm interested in making one as a senior project for school. And is there somewhere i can find the parts list?
Aug 5, 2011. 7:40 PMccowsert says:
my bad, i hadn't read the comments far enough
Nov 15, 2011. 8:31 PMrenavspainatal says:
News?
Nov 21, 2011. 9:54 AMrenavspainatal says:
I imagine how frustrating it is.
I hope you can find someone to help you so you can upload the instructable.
I think I'll wait for the next one then. =)
Sep 18, 2011. 5:00 AMgr3ml1n says:
Whats the word on this alternate build?
Nov 9, 2011. 12:57 AMM4industries says:
This is AMAZING!
I want someone to play "Derezzed" by Daft Punk on this beauty. Or even better, interface it with a solid state tesla coil!!!!!!
May 3, 2011. 9:22 AMMax "the bassist" Pratt says:
I love the project, and i'm not sure if anyone has called you out on this, but it is a bass, not a guitar, 4 strings!!!
Thats all, i would love to make one though
May 12, 2011. 7:50 AMMax "the bassist" Pratt says:
well measure for me the scale length (from the two points the strings touched the bridge and nut.) If it is 34 inches, it is a bass, also it should have about 20-24 frets. Tuning does not matter, because you can tune any instrument to achieve any tone you want.
A bass guitar is just the term for an instrument with all of those qualities, and it is really just a name.
Please do note however, that you do not play "chords" in the same was as you would for a guitar. A bass is one note plucked at a time, however sometimes one can play the octave of a note at the same time as the original to achieve the correct tone.
May 12, 2011. 7:55 AMMax "the bassist" Pratt says:
One other thing, your "victim" included standard P-Bass pickups in the hum-bucker layout, also a thumb rest below the strings. Both of these are used in basses, not guitars
Apr 27, 2011. 10:29 AMscrpn17w says:
I was just curious, what exactly do the connectors in the schematic hook up to? I am currently bread boarding this project and have no idea what to connect each of the plugs to.
Apr 27, 2011. 2:13 PMscrpn17w says:
I meant what do the "jp" plugs in the schematic get plugged into? Specifically jp3, jp4, jp5.
Apr 27, 2011. 7:35 PMscrpn17w says:
Also, what does the "Thermal Connection" note in the schematic mean?
Feb 28, 2011. 12:51 PMtheunexpector says:
Is it me or those schema and part list do not work, it ask me witch program I want to use to see it, have an idea guys?
Feb 18, 2011. 7:34 AMMax "the bassist" Pratt says:
You would destroy such a beuty!!!!!
Just kidding nice project, might work on a variation as a side project =D
Jan 22, 2011. 5:40 PMyoungcustoms says:
I cant seem to open laserguitar.brd, laserguitar.sch, & prism parts list! Can U help me out?
Jan 24, 2011. 2:21 PMyoungcustoms says:
Sorry, I still having trouble with these!
Jan 2, 2011. 9:05 AMArtXander says:
Great man!!
Nov 9, 2010. 9:30 AMAndreonh says:
How glossy would the paper need to be because im wondering if i am going to need to buy some very glossy paper online?
Nov 16, 2010. 7:41 PMAndreonh says:
does it matter how long after i print it that i actually iron it onto our copper?
Dec 15, 2010. 10:13 AMAndreonh says:
using these exact instructions i did this "laser printer and all" and i ended up with a barely transfered ink. this is very strange... are you sure it doesnt need to be an inkjet printer
Dec 2, 2010. 1:22 AMDarwinfish says:
This is awesome. Makes me wonder what else this tech could power. Take a piano with a broken soundboard, some lasers... hmm... make that lots of lasers...
Dec 1, 2010. 4:13 AMPie Ninja says:
I wonder if I can get the lasers mounted horizontally, rather than vertically. Also, you've probably been asked this multiple times before, but how much do all the parts come to?
1-40 of 374next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
