3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Prism: A Laser Synth-Guitar
Step 2The Circuit
The Circuit
Everything is contained on a single 3x5" double-sided circuit board. I designed the schematic and PCB in Cadsoft Eagle, but unfortunately the size is above the limits of the free version. You can still view the files, but you can't edit them without at least the student/non-profit Standard edition.
Feel free to experiment with component values, but be aware that some of the values are rather specific, and changing them too much will adversely affect the operation of the circuit, potentially causing damage to components on the board or to devices connected to it.
All of the "external" controls - the ones that are used by the musician on a regular basis - are connected to the board using header connectors. This is optional, but I do recommend it since it makes troubleshooting and assembly easier (or possible, in some places!)
At first I was going to design my own power supply, but then I found a nifty pre-built power supply with exactly the specs I needed. It's a little pricey at $60 but I think it was worth it. Who wants to mess about on something trivial like the power supply? The Prism was designed to run on +15, -15 and +5V, though it may work just fine on +12, -12 and +5V, which means you could use a modified computer power supply. I haven't tried it though, but it certainly wouldn't harm the circuit.
21 comments
Apr 13, 2012. 4:36 AMtejask says:
can i gt the schmatic circuit diagram of the circuit above
Feb 28, 2011. 12:51 PMtheunexpector says:
Is it me or those schema and part list do not work, it ask me witch program I want to use to see it, have an idea guys?
Oct 6, 2010. 10:37 AMAndreonh says:
Hello! i am having trouble finding the ic10 on the parts list for sale please help me if you are willing =D
Oct 7, 2010. 9:41 AMAndreonh says:
Also im wondering about item c22 because the 3u3 value is new to me or is it a typo... please clarify... and finally i am wondering about the quantities of the parts in the parts list
Oct 7, 2010. 10:00 AMAndreonh says:
IC1 XR2206 XR-2206 DIL16 exar 1
IC6 XR2206 XR-2206 DIL16 exar 2
im confused on if this means i need to get three of them or if i only need two? or what part of it means the quantity
Oct 8, 2010. 9:46 AMAndreonh says:
also i am having a LOT! of difficulty with the pinheads because my teacher is telling me that i need
"http://www.mouser.com/Search/ProductDetail.aspx?R=22-28-0042virtualkey53810000virtualkey538-22-28-0042" this im not sure about... i am partially new to this so i will probably have a lot of questions
Oct 8, 2010. 10:00 AMAndreonh says:
well im wondering is there another thing thats less complicated or more basic that would do the same job with a little less complication?
Oct 8, 2010. 10:39 AMAndreonh says:
the soldering directly sounds really easy too mess up... im moderately confused about this board but if it replaces jp 1-14 ill get it
Oct 11, 2010. 10:19 AMAndreonh says:
okay =)... sorry i know im probably getting annoying but also
r33-r40, r58-r60
Oct 12, 2010. 9:22 AMAndreonh says:
im having trouble finding the right ones
Oct 18, 2010. 9:25 AMAndreonh says:
okay nevermind... i got it handled... but i need to know where you found you short lasers because the only ones ican find online are way too long
Oct 28, 2010. 10:04 AMAndreonh says:
thank you sir for all of you help =) i finally have the partlist and board ordered... but i will say that figuring out how to turn the brd file into gerber files was quite ridiculous! haha
Jan 26, 2010. 5:36 PMDrPizza777 says:
i have eagle, but the BRD and SCH downloads download as unusable temp files. what do i do?
Sep 3, 2009. 9:24 AMBroly288 says:
Do I have to make thes images black and white to transfer them seems like a stupid question but i need to know
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
