3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Prism: A Laser Synth-Guitar
Step 3The PCB
The PCB
  • last photo ←
I made the circuit board using the toner-transfer method. It's my new favourite method of making boards! It's faster than the photo-resist method, and it's easier to produce good results. Oh, it's also cheaper and doesn't produce as many waste chemicals.
I won't go through the whole process here, there are plenty of guides online. But, I'll go over the basics.
Start by printing out the PCB artwork. The toner transfer method requires you to print using a laser printer on glossy photo paper - use the smoothest, shiniest stuff you can get. The bottom artwork should be printed normally, and the top artwork should be a mirror image.
Cut a piece of plain double-sided copper clad board slightly larger than the artwork, and place either the top or bottom artwork with the printed side towards the copper. Be sure the copper is clean to ensure a good transfer. You may tape the artwork to the copper clad using heat-resistant tape, to prevent it from sliding around. Now, place the board on an ironing board with the artwork on top, and lay a piece of plain paper on top. Some photo paper contains plastic that will melt onto the iron - the plain paper prevents this.
Now, with the iron on the hottest setting (and no steam!) , press down on the board for a few minutes. It's not necessary to move the iron unless the board is bigger than the iron.
After a few minutes, remove the iron and place a heavy, heat-resistant object like a cooking pot or glass baking dish on top of the board. This will keep the paper pressed against the board while the toner cools.
When the toner and board are cool, peel off the photo paper. If you're lucky and are using photo paper like I have, it will peel right off leaving the toner securely adhered to the copper. Some photo papers may require you to lightly scrub off the paper under running water.
Now, note the four mounting holes in the corners. Drill a 1/32" pilot hole in three of them. Take note of which holes these align with on the second piece of artwork, and punch a small hole in these locations on the artwork with a pin. When you line up the second piece of artwork on the copper clad board, make sure these holes line up PERFECTLY.
To prevent the toner that's already transferred from sticking to anything, lay a plain piece of paper on the ironing board, then a piece of unprinted photo paper, then the board and remaining artwork. Apply heat with the iron as before.
When both sides are transferred, inspect the board carefully for any toner that didn't transfer, and for any other damage. Repair the damage using a black fine-tip Sharpie marker.
Etch the board in either Ferric Chloride or Ammonium Persulfate according to the directions on the bottle. Inspect the board regularly to make sure that the toner and any repairs are not being etched away. When the etching is complete, thoroughly wash and dry the board with a lint-free towel. The toner and Sharpie marker are easily removed using nail polish remover and a cotton ball.
The last step is to drill the holes. I used a 1/32" bit in my drill press. This step seems to take forever, but be patient and be sure to drill in the exact centers of the holes.
  • I may order a bunch of professionally-made boards from a boardhouse, at a cost of about $12 each plus shipping. If you're interested in a group buy, let me know! *
18 comments
Nov 9, 2010. 9:30 AMAndreonh says:
How glossy would the paper need to be because im wondering if i am going to need to buy some very glossy paper online?
Nov 16, 2010. 7:41 PMAndreonh says:
does it matter how long after i print it that i actually iron it onto our copper?
Dec 15, 2010. 10:13 AMAndreonh says:
using these exact instructions i did this "laser printer and all" and i ended up with a barely transfered ink. this is very strange... are you sure it doesnt need to be an inkjet printer
Nov 29, 2010. 9:51 AMAndreonh says:
another question... when printing from eagle do we need to make it mirrored or not?
Nov 19, 2010. 10:33 AMAndreonh says:
so my teacher wants me to ask if there is a difference between copper clad and copper foil... if you dont know its okay
May 27, 2010. 8:22 AMGreev says:
 This gets my vote for "coolest thing on the internets" - have you had many other takers for a group buy of those PCB's? I want in!!!
Jun 29, 2010. 4:32 PMcdousley says:
How much do you think it would cost on batchpcb? Also do you have the gerber files i could borrow if i ordered it? Thanks and cool project!
Jun 30, 2010. 9:23 AMcdousley says:
ok thanks if i can find an old guitar and some money i may work on this.
Oct 28, 2009. 6:13 PMelmarco38 says:
I really like your meathod of manufacturing custom PCB's you should do an instructable on just this step. im impressed
Sep 2, 2009. 8:44 PMBroly288 says:
Yes i am interested in a board but how will i get the board and pay for it???
Sep 4, 2009. 10:58 PMhal68k says:
have you looked at futurlec's site? they will print boards for you if you give them the schematics, the last time I used their service it was reasonably priced. I'd say it's worth not having to crayon out a pcb and soak it in acid overnight :).
http://www.futurlec.com/index.shtml
Sep 3, 2009. 8:06 AMBroly288 says:
Can you by any chance give me an estimate??
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
