3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Project Alligator
Step 3Mechanical Assembly (Jaw Movement)
I decided against the crank mechanism because it would have been more complex to stop the crank mechanism at the right spot. The jaws were to be moved by a wire mechanism. The wire was to be wound on a shaft connected to a motor. The motor gets started by the motion detection mechanism. When the jaws would have completely opened it trips a limit switch, which reverses the direction of the motor. The jaws would close because of the gravity. However, release of the wire would make it close in a controlled fashion. When the jaws would close completely, it would trip another limit switch to stop the motion or reverse the motor if the motion was being detected again. I found this great website specializing in the old surplus material. I bought about $50 worth of the material from http://www.surpluscenter.com .
A 17 RPM motor was perfect for the winding mechanism to open the jaw. I decided to use a 10lbs fishing line instead of wire. Connecting a shaft to the motor was a challenge. The motor had a small shaft with 5/16" in diameter. With some advice from the railroad newsgroup, I decided to drill a small hole on the motor shaft. For the long shaft, I used a hollow brass tube from the local hobby store, whose internal diameter was 5/16". I drilled a through hole on the hollow shaft. The hollow shaft was inserted on the motor shaft aligning the three holes. A split pin was inserted through these holes making t a permanent extension. I inserted a long 5/16" bolt (With its head cut) into the hollow tube to make it strong. Believe me; this simple 'thingamajig' took me more time than it should have. Designing the electrical circuit was fun and one of my strengths.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kabira(Ashish Kumar)
I am electrical engineer by education and a software engineer by profession. I am always interested in building electro-mechanical models. The Instructables site is ideal for people like myself to le...
more »
