What does a used can of soup, old PC speaker, and propane equal ? A "Pyro Jam Can" of course! Inspired by a Rubens tube that I built the "Pyro Jam Ca...
Once you have the flame adjusted simply hook up any audio source and watch the fire dancing start! Thanks for checking out this ible. If you have any...
Step 5: Hook up and adjustment
Drop the speak in the speaker box.
Attach wire leads from speaker to amplifier PCB board.
Cut the end off of the helium rated balloon and stretch the closed end over the open end of the can.
Drop the can into the speaker box.
Attach hose to the barb and secure with a hose clamp.
Place unit in a open, well ventilated area.
Slowly open the regulator. YOU ONLY NEED TO OPEN IT EVER SO SLIGHTLY.
Light the can.
TURN GAS OFF IMMEDIATELY IF FLAME BURNS OUT AND WAIT FOR ROOM TO CLEAR OUT BEFORE REIGNITING.
Adjust flame to about an 1 1/2". You may need to experiment. To small of a flame and it will burn out. To big and you wont get much of a response.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
