3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Real Bullet Necklace or Earring
NOTE: The author is not in any way responsible for any harm anyone could possibly cause upon themselves, anything, or anyone else by doing this process.
Taking a real bullet, removing flammable parts, and reassembling into jewlary peice that can be hung by necklace or attached to an earring
Step 1Taking the bullet out of the casing
Take any bullet, preferably center fire rifle cartridges are easier because they have a larger surface to grab onto. In this process i use(d) a 5C Collette to grab onto the bullet face. I then used a small channel lock wrench to twist and pull up on the casing. *be sure to not pull all the casing all the way off, or gunpowder will spill all over your work surface* I then placed the half dissembled bullet in a ziploc bag and finished pulling the bullet out of the casing by hand allowing the gunpowder to spill into the bag. *it is advisable that you dispose of the said gunpowder in a responsible manner*
26 comments
Mar 23, 2012. 3:31 PMGASSYPOOTS says:
take a shotgun shell. shoot it. do that with about 15 more. pop the pins out(metal circle with a depression on the other metal circle) and put them on string :D
Nov 30, 2011. 10:56 PMgunman94 says:
Can this be done with something as heavy as a 14.5x119mm R round? I bought it at the Salvation army, and I think it would make a cool necklace, if I can figure out how to string it.
Nov 3, 2011. 1:47 PMbiffula says:
you can spray some wd40 into the emptied out cartridge to 'neutralize' the primer if you dont want to damage it. Just let it sit for a good while.
Apr 27, 2010. 6:55 PMHmOnGbOi says:
aye how did u take off the primer off
Sep 28, 2011. 4:47 AMlpdunwell says:
aye read the instructable [insert insult here]
Jun 27, 2011. 5:10 PMerehwon says:
That's the best way to pull the bullet. As long as you're not working a load that requires a crimp (lots of straight wall cases for example) a kinetic puller like that works great. Plus it has the added benefit of doing no damage to the bullet itself, catches the powder and doesn't mar the case. Those pullers will work with a variety of case sizes as well.
Jun 23, 2011. 10:01 AMDieCastoms says:
I made several necklace pendants when I was 14 for some friends.
Instead of "firing" the primer, I removed the bullet much the same way as you have done and then placed one or two empty shells at a time in an electric skillet.
Stand the primer-end right over where the burner is with the primer against the skillet.
I put an empty can over the shell because I was worried about it bouncing around like popcorn.
I turned the skillet on and after only a few seconds, the primer would "cook off."
This leaves the primer intact and nice looking with no dents from a firing pin.
Then I drilled a hole through the shell from side to side. This makes it obvious that it is not fireable.
I put a key-ring through the holes and mounted the slug back in with a tiny bit of superglue.
Covering the whole thing carefully in a coat of clear nail polish or other laquer finish will keep it from tarnishing or getting a petina and will also protect the wearer from let or other harsh elements in the metal.
Aug 19, 2009. 3:12 PMjacob5680 says:
I used to make these all the time, I simply use casings with primers that have already been fired, and I make my own bullets, but that may be out of the question here...
Great Instructable, tho this step may be iffy by some. as you pointed out. =P
Feb 11, 2011. 5:28 AMbpfh says:
Except your own home made heads are molded lead and not copper FMJ... Not the most healthy thing to have rubbing against your skin...
May 18, 2010. 12:53 AMFrogzard101 says:
it costs $400,000 to wear these earrings...for twelve seconds!!!!!
Sep 4, 2010. 2:43 PMcowscankill says:
Haha, I am Heavy Weapons Guy
Nov 28, 2009. 8:17 PMMrMystery96 says:
After making a few of these, would using the leftover powder in some small fireworks constitute disposing of said leftover powder in a responsible manner? I love sarcasm...
Oct 22, 2009. 4:21 PMDurkaDurka says:
When you fired off the firing cap, did it make a loud noise? or even a noise at all?
Aug 19, 2009. 3:15 PMjacob5680 says:
a trick for this is to take a cotter pin ( split pin ), stick it through, and use a flat screwdriver to spread it inside the casing. =P
Jun 19, 2009. 9:11 PMpop2012 says:
great instructable. you should do a more detailed version for the stone necklace.
Jan 29, 2009. 4:57 PMFurball_Fidelis says:
Very cool instructable...I have quite a few bullet casings in one of my dresser drawers...what else could I use to fill in the hole to make it look like a bullet? right now i have an idea of turning them into valve stem caps :3
Dec 24, 2008. 1:03 PMMattrox says:
These are mine I made their small but cool.
Sep 13, 2008. 5:07 PMbumpus says:
Very cool instructable! I do suggest to add a bit more light to your photos, perhaps a few micros. I've done this a few times, once resulted in a detention for wearing it to school.. I do not advise doing so.. :D 4.5/5 stars!
Sep 13, 2008. 5:49 PMSunbanks says:
It makes me sad that I wouldn't be able to wear this to school :(
Sep 14, 2008. 8:13 AMthewoodcarver says:
Most ranges will let you take empty brass to reload or to make these ..just ask ...they will even sell you the lead or fmj to fit ....there is a hammer to remove the bullet screw bullet into one side and hit the other on a hard surface bullet and powder end up in the hammer I have one and think it is called a bullet puller ....you can find a range in your area that may buy these as key chains ....I sold many in .50 AE and .50 BMG and some bullets that are no longer factory loaded ...just a bit hard to get brass for a .38-56 or .45-120...use a clear crystal and tell everyone it is a ice bullet ...good job on them please wear your glasses when doing and stay safe
Sep 13, 2008. 5:59 PMikoda says:
I just have the bullet shell. No bullet. D:
Sep 13, 2008. 6:20 PMi make shooting things says:
get puddy, clay, glue, some medium that you can shape and paint it copper or silver or gold? then just shove/glue it in that's what id do.
Sep 13, 2008. 9:17 PMikoda says:
Cool, I think I'll try that. Thanks.
Sep 13, 2008. 8:41 PMhg341 says:
now i just need ammo...(good job!!!)dont think me dad would like this
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:redwiltingrose
