In our physics class, as an addition to the the already abundant car projects we had already received, our teacher assigned yet another involving hot wheels and rockets. Hence the "rocket car", which was was made to go through a series of photogates, or speed measurement devices, so that the velocity (or average speed) of the car could be found. With the data from the photogates, we calculated the acceleration and velocity of our hot wheels cars, which ended up going faster than you'd think. However, we didn't use just one photogate, but 5, so the instantaneous speeds could be used to calculate the acceleration.
Unfortunately, our class ran out of time, and not all of our data was saved. However! We did want to post our most entertaining (and slightly dangerous) lab for all you instructables fans to see. =)
The data for my team is posted in thr last step.
Remove these ads by
Signing UpStep 1Modifying Your Hotwheels Car!
After you get your car(s), figure out where you're going to punch some holes into the thing. If you're thinkin' "WTF what holes?", it's ok. On the track, which you'll build later, there are going to be two lines of string running down the track to stablize the car as it runs down the track. These holes are where the string is going to run through the car. So get a drill, and cut a hole wherever you think makes sense. The position of the hole WILL be different depending on the hotwheels.
After the holes are made, then get either a straw, some thin tubing, or even the shaft of a plastic pen. Then insert it into the holes you just made. Just for clarification, you'll need two tubes for the TWO holes. I didn't really specify in the previous paragraph so I'm doing it now. YOU WILL NEED TWO HOLES AND TWO SHAFTS OF TUBING. The tubes should be about 2 inches long, a little longer depending on the length of your car, but it shouldn't vary too much. You may have to adjust the size of your HOLES according to the size of the tubing you use. So when all this is figured out, get your yer'self a hot glue gun and go crazy on that hotwheel! Make sure the shaft of tubing is VERY secure, cuz' you don't wanna have it moving too much during your actual runs.
O K, now that you have your tubing in order, it's time to attach the rocket! You can pretty much put it anywhere you want, as long as it's facing the right way, and it's ON the car. We used A-E rockets, so refer to the picture above if you haven't heard of the rockets and need a visual representation. Make sure the rocket is facing the right way, and by "right" I mean with the hole facing the back of the car. Other than that, do whatever you feel is best. After you pick WHERE you want your rocket to go, then you can either zipt tie it to the car, or hot glue it, which works pretty well. However, the glue may melt from the heat of the rocket, so the zip tie might be a good idea for extra support. Depending on the height of the car, a zip tie may not work, as it might hit the ground before the wheels do, which is (obviously) bad.
So there you go....ze car iz dun.
*Making a second car is reccomended. Just in case ;)
comments
Add Comment
qwertyboy
says:
Add Comment
