Step 11Construction 5 - mouting
First - Attach the brackets to the base using screws. (I used a piece of scrap wood, I think it was part of a shelving unit once).
Second - This step may or may not be required depending upon how your tube fits in the brackets. During construction I found that the brackets were slightly larger than the ducting. To aid this, I used some scrap hosing and zip ties to put around the ducting, thus adding to the circumference.
Third - Finally, mount your Rubens' Tube inside the brackets. Tighten up the brackets and you should be left with a fairly stable setup.
At last! - Your Rubens' Tube is ready for action! Please read the safety notes before hooking up the propane and continuing.
Add Comment
