Step 4Nerdy stuff - measuring sound.
As mentioned in the last step, sound is a vibration, we measure the frequency of this vibration in hertz (Hz), which is the number of cycles of the vibration per second. Wikipedia tells us that "The frequency (f )is equal to the speed (v) of the wave divided by the wavelength (lambda) of the wave".
So in other words - frequency = speed / wavelength or:
f = v / lambda
To find the wavelength, we use basic algebra - multiply by lambda and divide by f to get.
lambda = v / f
To test this we can take the sound wave used to demonstrate the device in the video as an example (360Hz), and use or rough speed of sound for v.
lambda = 257(m/s) / 360Hz
This gives us a value for lambda of about 0.71 meters. Which should be close to the distance between the peaks of the flames. Though the actual measured value may differ from what is calculated given the above mentioned scenarios.
Note - for some reason the lambda symbol keeps turning into this when I save "Ãý»". So I've replaced the symbol with the word "lambda". I apologize for any confusion.
Special thanks to user cposparks, who found an error on this page when it was originally published, I've since made best efforts to correct it.
Timings will vary based on the volume of the tube and the gas output, and this is a potentially dangerous situation. Without knowing more specifics of your construction, I hesitate to say give the above a shot. But again, that's where I'd likely start to troubleshoot the issue. Please take every precaution possible.
So far i have taped the holes and then allowed the propane to build up for two min then four min. At two min, the propane lit up inside the tube, but at four min, i did have flames on the top, but they were very small, and i had to ignite every hole individually. i havent tried allowing the propane to push out of the tube yet, as i ignite it as soon as i pull of the tape.
Again, turn on gas long enough to displace air, so that only gas is coming out of the holes. Don't hurry the priming process because it will cause turbulence in the tube and that will MIX the fuel and air, a VERY dangerous combination. (read: explosive)
You describe the fuel entry as 'far from the diaphragm. It should be as evenly spaced as possible to make the gas input equal across the tube.
It's been three years (to the day!) since this Instructable was published, and unfortunately, I no longer have the device, so am unable to go back and check for confirmation, one way or the other. However, your observation's very astute, and I've started to do some research on the issue, though have found conflicting reports. As soon as I've got things figured out one way or another, I'll update the Instructable to reflect that - though until then I'll put a disclaimer on the top of this page.
