The Rubens' Tube: Soundwaves in Fire!
The Rubens\
What could be more entertaining than fire and good music? How about fire that will dance to that music? The following will not only cause flames to pulse to a beat, but it will also allow you to see different wavelengths of audio frequency. The following is my first Instructable, and my entry to the Instructables Science Fair contest.
In addition to documenting the build steps to create something called a Rubens' Tube, I'll also go over some of the basic concepts and science involved with sound waves.
From the moment I discovered what a Ruben's Tube was, I wanted to build one... and considering I was in a physics class at the time, there couldn't have been a better excuse than extra credit.
Update: I'm thrilled to see that this Instructable's become popular, and I'm more than happy to have people build on the project, but please respect the Creative Commons BY-NC-SA license.
Step 1What is a Rubens' Tube?
What is a Rubens\
Heinrich Rubens was a German physicists born in 1865. Though he allegedly worked with better remembered physicists such as Max Planck at the University of Berlin on some of the ground work for quantum physicists, he is best known for his flame tube, which was demonstrated in 1905.
This original Rubens' Tube was a four meter section of pipe with 200 holes spaced evenly along its length. When the the ends are sealed and a flammable gas is pumped into the device the building pressure will have only one route to equalize. The escaping gas can be lit to form a row of roughly even flames. Upon introduction of a loud speaker to one of the sealed ends, standing waveforms can be seen in the flames.
Within the Rubens' tube, as soon as gas is ignited generally uniform flames will be seen. This is because there is very little pressure differential between any given area of the space inside the tube. Once sound is applied from one end, pressure will change within the tube. Should the sound be an easily measurable frequency, the wavelength will be visible in the series of flames, with the highest flames being where condensation is occurring and the lowest where rarefaction is occurring.
They can also be used as an incredible visualizer for music.
(Note that I've muted that audio intentionally, as I don't own the copyrights to the music being used in the clip, and I'm not sure what the Instructables policy on "fair use" is. Searching on Youtube or Metacafe for "Rubens Tube" will show you several videos with music.)
137 comments
1-40 of 137next »
Oct 13, 2011. 6:01 AMshahrukh shajahan says:
is it possible to do this rubens tube by using lpg...pls send me wetr it can b done by using lpg to my email id shahrukhextreme@gmail.com
Nov 6, 2011. 8:30 AMfrollard says:
Just remember, propane goes down (heavier than air) and it fills the tube first. This is important so you don't get a fuel-air mixture INSIDE the tube before you light it. It's the only reason it doesn't explode.
Dec 27, 2011. 11:23 AMPennyroyal69 says:
my rubens tube doesnt light up on the top, but instead lights up inside the tube, and i have to turn off the propane supply immediately to stop the fire. do u know why that happens, and for how long should i allow the propane to build up inside the tube?
Dec 27, 2011. 5:20 PMPennyroyal69 says:
The rubens tube in question is a 5 foot PVC tube, 2.5 inch in diameter, with 3/32 inch holes half an inch apart starting one foot from the beginning of the tube and ending one foot from the end of the tube. Instead of attaching the other end of he tube directly to a speaker, i taped a diaphragm onto it. The gas enters the tube through two tubes each drilled into the tube at the non-diaphragm end of the tube, placed on each side of the tube.
So far i have taped the holes and then allowed the propane to build up for two min then four min. At two min, the propane lit up inside the tube, but at four min, i did have flames on the top, but they were very small, and i had to ignite every hole individually. i havent tried allowing the propane to push out of the tube yet, as i ignite it as soon as i pull of the tape.
Dec 28, 2011. 1:10 PMfrollard says:
You need to cover most of the holes and fill the gas VERY slowly so it fills and displaces the lighter air -- as soon as you smell gas coming out you should be good. You never need to 'build up pressure' inside the tube. covering all the holes will just result in a fuel-air mixture and stressing the diaphragm. Imagine if you will that you have a tube filled with oil and you want to displace it with water...go slowly and all the oil should be pushed out before any water hits the holes -- same buoyancy/stratification effect here, just with different fluids.
Again, turn on gas long enough to displace air, so that only gas is coming out of the holes. Don't hurry the priming process because it will cause turbulence in the tube and that will MIX the fuel and air, a VERY dangerous combination. (read: explosive)
You describe the fuel entry as 'far from the diaphragm. It should be as evenly spaced as possible to make the gas input equal across the tube.
Dec 7, 2011. 10:40 PMBeerBellyJoe says:
Great instructable! I wanted to make a smaller version for a class project. Could I make it with a 1" dia copper tube and a small speaker? Also does it have to be really long? Could I make it less than 2 ft, or will the sound waves not form correctly? Thanks!
Nov 3, 2011. 9:54 AManjaliv says:
i am really thank full to you...........it helps me a lot....
Jan 16, 2009. 7:58 PMbugulagak123 says:
If I will prefer to use one location for gas source (the other end of the tube) will it work? and what is the best material that I can use to ensure airtight seal?
Jun 10, 2011. 9:19 AMrangua says:
I saw a video on youtube of a guy that did it like you want it. http://www.youtube.com/watch?v=HpovwbPGEoo
He mentions that he made holes with half inch increment (i think thats the difference between the first hole and the last one (?)) to get an even sized flame..
Oct 29, 2009. 6:07 AMgenericanonymity says:
Using the either end of the tube for fuel delivery would probably produce an unevenly filled chamber. If you use just one source, it should be closer to the center of the tube, as suggested.
May 23, 2011. 2:40 PMHoudinipeter says:
I didn't do a great job cutting the tube to a good length, if i can cover the hole well will it matter?
May 2, 2011. 6:04 PMsundet says:
Does anybody have some good resources on modelling a Rubens tube? I have a pretty good background in mathematics. I'd like to make a tube and use it for many hours at a time. I also do not want to get blown up. What have you all tried for getting good seals on the ends and where the gas goes in? Has anybody tried attaching fins to the tube or a fan to dissapate heat? My guess is that the diaphram would be less likely to break if it were exposed to less heat.
Feb 12, 2011. 3:17 PMTrigonography says:
You know what would be neat? To separate a musical piece into its component instruments, and then play each instrument through a separate Ruben's tube. That way each tube will be showing the music cleanly. Of course, getting them all to start simultaneously might be an issue. So maybe a better idea would be to have live musicians play their music like they do on stage. It'd be a poor man's Trans Siberian Orchestra show!
Aug 5, 2008. 9:04 AMwolfmanofTX says:
Would it be possible to attach some sort of heat resistant nozzle to each hole, and do you think this would allow extended run times?
Nov 30, 2010. 8:49 PMtinstructable says:
you could add 2 circular heat sinks used for capacitors to cool the ends by the ducting and then for the holes, somehow adding a graphite ring like an eye hook around each hole. Graphite has a very hight melting point.
Aug 20, 2008. 8:39 PMinstructing tables says:
Would this work with a curved tube? Like a circle or a like a horizontal wave? That would look really awesome if you could really perfect this.
Sep 10, 2008. 6:34 PMdiskfurnace says:
I don't think a curved one would work well if at all because of all the waves bouncing off the walls. And it wouldn't be like a stethoscope because a stethoscope transports the waves through rubber, whereas this set up transports the waves through air thats in a tube. So they are very different concepts
Nov 1, 2010. 6:28 AMjustjimAZ says:
Thanks so much for this! I made one for my Halloween party and everyone loved it. Don't know if the videos will load, but a friend recorded some with a cell phone.
I had trouble with the flame height at first, but giving enough time for the propane to build up helped. It also helped to raise the propane source higher than the tube - though far behind the flames, of course.
Strong, low piano notes or driving bass seemed to get the most effect, and higher notes had the least effect.
Managed to keep everyone entertained for 12 minutes!
Nov 1, 2010. 6:24 AMjustjimAZ says:
Managed to keep everyone From 4 to 65 entertained for 12 minutes!
Aug 28, 2010. 4:27 PMvonkeswick says:
We tried constructing one of these (almost exactly as described) but couldn't get the flames to hold. It seems that the gas pressure from the standard propane + nozzle kit simply isn't high enough. Everything is fully sealed, and I tried doing it with very few holes (maybe ten) and it still couldn't keep them all ignited, let alone steady. Any suggestions?
Aug 4, 2010. 9:13 PMcposparks says:
Were your experimental measurements similar to your theoretical measurements? I ask this because the speed of sound is 340 m/s in air but the sound waves are being created in a medium that is composed of propane. The speed of sound in propane is ~247 m/s. This would significantly change the theoretical wavelength for an arbitrary frequency.
May 26, 2010. 11:11 AMsci5 says:
We have thoroughly enjoyed this project!  I have found some things work and others need improvement. We used a thicker pipe than we wanted. We found it in the fencing area of our local hardware store. It was a fence post. I recommend using the thinest pipe you can find. We drilled our holes 1/2 inches apart. I recommend drilling them 3/4 in to 1 inch apart. We sealed every other hole up. One end can be sealed with a pvc pipe-cap. Make sure to use Teflon tape on the pipe before sliding the cap onto your pipe. It can also serve as the fuel source by drilling a hole for the propane fitting. The other end can be sealed with any latex rubber you can find and some ordinary rubber bands. It is better to make sure to leave 6 to 10 inches on both sides to not allow your ends to get to hot. We used 7/64 drill bits. A few might break. I recommend using a smaller drill bit if possible. The 7/64 will work though.
sci5 is our physics teacher.
sm and bj the hallmonitor
May 26, 2010. 11:49 AMsci5 says:
Thanks for all the info you have put up.  It helped me a lot with my tube.  My only problem was I put the propane injector and speaker at opposite ends.  Making the gas not evenly disperse throughout the tube.  The best way to install your injector is in the middle or to have multiple injectors.
JaketheSnake
May 26, 2010. 10:57 AMsci5 says:
The rubens tube is such a fun project!! I found that mine worked better when the gas hookup to the tube was in the center of the rube rather than on one of the sides.  With it in the center, I had to have latex coverings on both ends of the tube....just had to make sure the latex wasn't too close to the holes where the fire was coming out!
Aug 15, 2008. 1:47 AMaj619 says:
hey sorry if this is a bad request but could someone maybe make a video of a system of a down song going through one of these please it would be greatly appreciated
Apr 15, 2010. 12:35 PMjelly teeth says:
absolutely!!
Feb 25, 2010. 5:55 PMSilverdragon066 says:
 my pipe is a 1 inch diameter copper pipe about 4ft long.. would it work?
Apr 6, 2008. 10:59 AMagitate says:
I'm just curious, Can you only use single sound waves or can you actually hook up music to the rubens tube?
Jan 5, 2010. 4:47 PMsphproject says:
I've seen some youtube videos of people hooking up music to the rubens tube. :)
Nov 24, 2009. 3:00 PMPyrotechnic-Robot says:
 These are so cool!
I made one of these a few years and it is so intresting on how the flame height represents the audio wave.
Who doesn't love fire! good Instructable.
Nov 24, 2009. 1:20 PMChikara says:
gotta get my pyrofriends together.... so we can build one! great instructable!
Oct 28, 2009. 2:41 PMjam BD says:
really pretty effect =D
1-40 of 137next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:yourtvlies
