The SSPP ( Short Stroke Power Pistol)
994
Posted in PlayKnex
Introduction: The SSPP ( Short Stroke Power Pistol)
About: Your probably thinking that im nuts liking math but i like the challenge and i have a REALLY mathematical mind with almost no imagination so i like something that is concrete and that i know will be the same...
I was fed up with the knex pistols that would break the ram if you put on too many elastics.
So i decided to fix that problem. The answer was this. I have had no problem with two much power on this gun ( I have put 6 elastic bands on without it breaking.)
The gun has a 8 shot mag and a 80 feet range with three bands on it.
As a bonus this is one of the smallest pistols on instructables that has a decent range.
Just ask if you have any problems.
Some people don't believe that I got 80 feet with this gun. I really did I used raly strong bands
1. The pistol
Step 1: What You Need
1-2. The Pistol
3-4. What you need
5-6. close up on the handle\ barrel\ body
7-8. The trigger.
9. The ram.
Step 2: Making the Gun.
Just follow the pics.
Step 3: Adding the Elastics.
1. Put the elastics on the rod with the gears and spacers and stretch back to the orange connector on the ram
2. How far back the ram goes
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    35 Comments
    This does NOT get 80 feet with 3 #64's.  The trigger is up the gun too far and its got mag friction on it.  Maybe 50 feet at most.
    Other than that, You did a decent job, the only flaws were what I mentioned above.
    I dint say it got 80 feet with 3 #64's. i dont have any # 64's I only have elastics that are about double the size of the broccoli elastics. They're really strong.
    It got 80 feet on average against the wind with 3 of the elastics i have. as for the mag friction just use a really thin elastic.
    The trigger is too far up the gun to shoot 80 feet with 3 bands, no matter what type they are.
    I honestly got 80 feet with 3 elastics. The elastics are huge, they're 1cm wide and about 5cm long. I had them doubled back.
    I don't really care if you don't believe me, I know that I got 80 feet.
    Was this at a 45 degree angle?  Or flat?  If it was angled it would be SORT OF believable.
    You could get 80 feet easily with ONE of these bands. Though it would break the gun
    GOOD GOD WHERE DID YOU GET THAT!!!!!!
    I got it with a pair of snowshoes, it was used to hold them together
    It was almost a 45 degree angle.
    These are the bands that i used.
    Use an Oodassault pistol reciever, it looks weak the way it is.
    80ft? Really? That's too much for that. (Everyone over measures sometimes)
    When i test fired it i shot it at a 45 degree angle and got 75, 86, 72 and 81 feet  so i rounded it off to 80 feet
    So I'd say it shoots 40 feet flat with the same bands.
    Then you should specify that it was at a 45 degree angle. Otherwise people will keep giving you crap.
    The reason it can handle a lot of rubberbands is because it has a tiny drawback. That decreases power. But, it's cute. So, *3.
    Thanks.
    The power doesnt decrease porpotianlaly I got a farther range with this than i did with one of my other gun that had a full drawback.
    MeZak has a full drawback and it can handle 7 bands easily.
    looks tiny! and cool! 5*
    I'm still confused as to how this design makes it go farther. It doesn't have much pin draw.
    Also, it looks like I could snap it right in half.
