The Shrapnel Spreader K.T.B (Knex Time Bomb)
6,432
22
211
Published
Introduction: The Shrapnel Spreader K.T.B (Knex Time Bomb)
About: Favourite games are LittleBigPlanet2 and Gran Turismo 5. Favourite music genre is drum and bass, but my current favourite song is Gorillaz - Clint Eastwood. I mainly build replicas of godly cars on LBP2. Su...
Check my Sipriani Rifle too!
This is the first ever knex time bomb on the site!
It has a range of 3.5 ft.
The timer is about 22 seconds with two 64# rubberbands tied together.
Pros:
-strong bottom
-block trigger system
-pretty good range
-can keep up to 23 white rods in the spreader
-uses a firing pin
Cons:
-spreader isn't strongly attached to the bottom
For short:
It's a recommandable time bomb.
If you have any questions or problems please contact me on my orangeboard.
Step 1: The Trigger Stopper
This part is for stopping the trigger from blowing the spreader of the top.
Step 2: The Timer
you can make the wire as long as you want
one 64# rubberband is 6 to 8 seconds on the timer.
Step 3: Bottom (stand)
This part is the support for the spreader.
The engine is the blue one out the Starburst Spinner Set.
Step 4: The Spreader
this part is required since it holds the white rods that need to be shot.
Step 5: Trigger Track
This part is for letting the trigger go straight so it won't pull the trigger in a weird direction making the trigger shoot away.
Step 6: Putting Together
pic 1: Trigger stopper + Bottom
pic 2: put them together
pic 3: Spreader + Bottom
pic 4: put them together
pic 5: Trigger Track + Spreader
pic 6: put them together
pic 7: Timer + Bottom
pic 8: put it in
pic 9: Timer holder + Timer
pic 10: put it in
Time Bomb Completed
Step 7: It's Done!!!
So you've built yourself the Shrapnel Spreader K.T.B.
have freaking much fun with my knex time bomb!!!
The best shrapnel: white rods
    • Flowers Challenge
      Flowers Challenge
    • Microcontroller Contest
    • Outdoor Fitness Challenge
    211 Comments
    Hello Nederlandse sprekers, spreek ik het geen Nederlands maar ik ben slim
    You just said: Hello dutch speakers, speak i the not dutch but i'm smart. LOL! xD
    dank u, zijn u het Nederlands of doen u enkel speek de taal
    I don't get the sentence... You said and translated: Thank you, Are you the Dutch or do you only (Don't even know if "speek" is correct nor, existant) the language But i think you mean this: Thank you, are you dutch, or do you just speak the language? Answer from me: Yes i'm Dutch but, i can speak English, a little bit German and, even a bit French. But i come from Holland :P
    You speak german?!?! Me too!
    A bit but not that much, i can speak my original language which is dutch, and english best :D
    i speak martian,    0-0
    plutonian:
    $%^*((_^££*)+^$£@*-+TYIP$^*)_ ( that means hello)
     my own language is dutch, english is almost as good as my netherlands, second comes french,  thats really bad and sad -_-... third comes german and fourth comes spanish
    zeg als gij toch zo goe nederlands kunt zeg me dan es waarom ge dat wiel gebruikt hebt? das toch helemaal overbodig,of zit ik verkeerd?
    Nee, da's om het elastiekje op de as te houde zodat hij er niet vanaf glijdt. :P
    oh ja en dat probleem dat het niet goed aan het ondersteuningsplatform vasthangt heb ik een oplossing nl: 1 de 4 (2 aan elke kant) bovenste gele connectors vervangen met witte 2 oranje connectors aan de spreader op de blauwe staafjes juist naast degene die al vastzit aan het ondersteunigsplatform 3 zoeken welk staafje tussen de oranje en gele connectors past 4 opgelost!
    euh kweenie hoor maar zit het elastiekje niet aan die grijze connector vast?
    ich mag Deutsches. es hat Lose gute Beleidigungen.
    You just said: I like German. it has lots good (I don't know the last word). I Am currently learning german in school
