We have an infant mobile (Tiny Love's "Symphony-in-Motion" with remote) which plays annoying-after-the-Nth-repetition electronic versions of classical music fragments, at either high or low volume. Since our daughter really enjoys watching the mobile, the obvious solution to our annoyance was to install a mute switch.
Remove these ads by
Signing UpStep 1Parts and Tools
A subminiature SPST three-position switch. My lab has a drawer full of C&K 7203 switches, which is actually SPDT. For a slimmer SPST version, order the C&K 7103 (pictured) for a few bucks from Mouser, Allied, DigiKey, Jameco, or your favorite distributor. This switch has three positions -- the middle one is open-circuit, just what we want for blessed silence.
Triangular screw bits. Our mobile's case has some, really weird "security" screws with triangular recessions in the caps. I ordered a set of four bits from McMaster-Carr Industrial Supply (items 5941A11 through 5941A14).
A soldering iron, solder and flux. You will need to know how to solder already.
| « Previous Step | View All Steps | Next Step » |
What I've appreciated most about the site is how smooth and simple they've made the interface. I had documented my crib modification as a straight HTML page (using Emacs!), and turning it into an I'ble was quite easy. That gave me the incentive and desire to use I'ble to document other projects (and to complete projects in order to document them!).
The positive feedback and support of the membership here has helped as well.
I mean, recently I started to read The Great Design: Particles, Fields, and Creation - by Robert K. Adair (have you seen the book?). But it is a little intense for me at the moment. I really need to brush up on my math skills again (not that I ever had any real skills in mathematics).
Why do all of these toys make so much noise?
The built in switch from TinyLove was a three-terminal two position, with ground on the center pin, and separate leads for high- and low-volume on the two end terminals. I replaced that switch with a three-position one, with the leads connected to the terminals in the same way. The center position of the new switch is off; the left- and right- positions correspond to the same high and low volume as before.
