3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Simplest Rechargeable Battery Circuit (and save the planet too)!!!
Hallo to all.....
The idea came to me when i was ready to replace a battery cell in my alarm clock next to my bed. Even i am using the last 5 years only rechargeable batteries of the most types i considered how many battery cells people around the world throw away in a simple move like that i did now.....How meny disposed battery cells thrown away in each household? Who knows? But what if we had a rechargeable system to recharge batteries when the device is connected to an outlet and when we will need the battery (In a black out) this will continue working the device.So first we will have power continuity, second we will save money buying and dispose all the dead batteries, and third under normal conditions we can rechargeable any type of battery we like. My next question to my self was that this kind of circuit must be simple, cheap, realible, and easy convertible to recharge any battery cell and giving power to a device at the same time. SimpleEhhh????
So i tried to recall my studies from university and i reminded a very simple circuit which actually recalls all the science of electricity and every 1st year stuedent knows well.
Materials..... Cheap and Easy
>>4 diodes of 1N 4001 type for making the bridge which conncects to the transformer
>>a transformer 2x6 if you want to recharge batteries from1-6VDC or 2x12 for devices up to 12VDC (input 220VAC europe output 2x3,2x6,2x12 choose your one)
>>a 1000uF Capacitor, using it as a filter and elevator of the power
>>a Relay (6VDC if you will give power from 1-6VDC or a 12VDC if you like to recharge a 12VDC battery)
>>a resistor of 33 or 39 Ohm /5W (5W is ideal because the resistor cool down faster)
>>a diode of BY251
>>2 rca female for chassis
>>2 rca male
>>a prototype card or a perforated card, no PCB needed
>>a nice box for the battery recharging docking station appx12cm X 5cm X 3 cm ( in this box you will try to fit a transformer, the basic circuit , cables, the battery nest and your spirit! :D
All materials costed to me 12euro (15USD) The most expensive is the transformer.
Lets go now at the circuit design and i will explain to you....
Step 1Explaining of the Circuit
Ok....now lets go to explain all theese Chinese things!
first of all the circuit is well separated is two sections the power supply on the left (green line) with the battery pack and the outline with the purple line
We take the transformer (220V europe make the calculations over Atlantic reader) and we connect it in a formation of diodes called bridge.This circuit is what a first year student learns and remember it for ever. Its the simplest circuit to achieve best reults, cheap and realible.Ok, if u like to transform from AC to AC again then the circuit remains the same u change the diodes of type 4402, 4403, 4002, ofcourse the transformer and the appropriate relay working in AC. The capacitor of 1000uF value is a filter and a choke to elevate the power. Connect the diodes to the capacitor and then this one at the line of the relay. Then the + pole of the device gets to the switch of the relay. At the + pole of the device we attach a diode or a BY251 and a resistor 33Ohm of 5 Watts (we prefer 5watts so the resistor isn't get hot when it works and cools down faster)
You will not need any PCB. Take a protorype or better a perforated card and just place the materials and do the connections. No particular attention needed (of course take all the precautions when using high voltage such as 220VDC are able to fry you in seconds and send next to your anchestors for ever)
from the + and - we will take line and we will drive it to 2 RCA female (chassis) The one male RCA connected here goes to the charge the battery and the other goes at the device where we will place a fake battery
17 comments
Jan 24, 2010. 7:11 PMphillipewu says:
I have a question about the circuit - what is the purpose of the diode and the resistor in series? Is this to reduce the voltage from 12v to what is required by the battery?
I want to charge a NiCd power pack from a radio control toy and I think the voltage is 7.2V. I also have a power supply from a junked computer which I think can supply 12V. What type of diode and resistor is required?
With this type of circuit can the battery become overcharged? If so what what is the safe charging time?
Thanks for any help.
Sep 21, 2010. 2:58 AMdrbill says:
You need that diode to prevent a switching power supply from tripping to 'off' when charging batteries and the resistor current limiter for charging to take place safely.
Sep 21, 2010. 2:55 AMdrbill says:
Charging happens when the relay is energized and the power comes in from the right side surrounded in Purple. Probably a switching power supply or other regulated (or not) DC supply. If you put a tap in there, when the power went off the batteries would supply the load making a slow UPS.
This circuit needs work though to do that.
A circuit very much like this one was written up in QST Magazine and it is used to provideemergency power to Ham Radios when the lights go out.
73's
Sep 4, 2010. 7:10 PMprofpat says:
HI Agis, sorry for the late comment, just read this today, question, what is the purpose of the relay? how does the battery charge? i dont see any connection from the bridge rectifier going to the batteries? i guess i am missing something!
Sep 5, 2010. 6:53 PMprofpat says:
Thanks for the reply! will figure it out somehow!
May 31, 2009. 10:03 PMchefbrian says:
i have a 120vAC-9vDC adapter, how could i use this to charge a rechargable 9v battery? would a simply attach the positive lead on the charger to the positive lead on the battery? that's what the diagram seems to do.while charging, will it continue to power the battery operated device? also (stupid question probably) does an LED work like a regular diode, as a "one way valve" for current?
Nov 25, 2008. 3:26 PMColonel88 says:
...(uh, what is this?) I just hooked up a power supply with a battery and boom let there be light.(or more correctly, electrons!!!
Jan 11, 2009. 11:51 AMNarNar says:
You mean photons.
Feb 3, 2009. 4:30 PMNetReaper says:
told...
Dec 15, 2008. 4:16 AMdbunting says:
how do you prevent the battery (NiCad, NiMh for the most part) from lossing its Zero Point due to "over charging". You know, that irritating point where you left the battery in the charger for so long it no longer holds a charge. Did you do anything to combat that?
May 24, 2008. 12:17 PMtech-king says:
your linear power supply is not that good. i lacks any form of regulation, a serious problem with dc devices and chargers. a 12 volt and 6 volt zener diode would work well. also, most linear power supplys use 3000 uf filter caps to power dc devices.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:agis68
I like to invent and modify things. When i was 13 i fixed my dad's old Lancia Fulvia motor. I builded my first mod PC in 1991 using a mobo builded in a VCR box. I am first using all my inventions. I l...
more »
