3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Singing Keyboard Prank
Connect the musical element from a singing greeting card to the caps lock LED on the victims keyboard. Now each time they press the caps lock key the music plays (and quite loud too).
This is a great sleeping prank -- It might be found on the first day, or several weeks from the implementation. It's the perfect prank.
Difficulty: Easy, but involved. (ability to solder and use a multi-meter helps)
Disclaimer
If you decide to do this prank, understand that it could be a career-limiting move if it is done on your boss and/or somebody without a sense of humor. I would also recommend experimenting with a dummy keyboard that you don't mind destroying first.
Why Caps?
True, most people don't use caps lock very often, if ever, but unfortunately not many other keys are linked to an LED. Also most keys are only pressed momentarily, which would require a more complicated circuit to work effectively. The num lock LED turns on and off several times during boot time, so that's out which only leaves the caps lock as a viable solution.
Vote
If you like this instructable, please give it a vote.
Origin of this Project
This was originally posted on on my blog (before KipKays video):
http://blog.mozmonkey.com/2006/april_fools_hack/
Step 1Setup
Setup
To start youll need, of course, several musical greeting cards. Hallmark stores usually have a section dedicated to these cards. Youll also need these tools and supplies:
1. Screw drivers (Phillips and a wide slotted)
2. Needle nose pliers
3. Soldering iron + solder
4. Thin wire (22 gauge works well)
5. NPN transistor
6. Electrical tape
You can get all these from your local RadioShack.
I bought a CoolHeat soldering iron for this project due to its great portability. If you get one of these be sure to purchase at least 2 replacement tips since theyre brittle and WILL break during normal use.
37 comments
May 22, 2009. 4:52 AMjames.mcglashan says:
y not just use the scroll lock key as a switch to power a usb as a hidden usb that can be turned of using the keyboard and also off using a led dont put this on the site i will do it.
all in the key board
only another hidden usb hack lol
May 22, 2009. 4:53 AMjames.mcglashan says:
the first with an on off switch lol using a led and evan without the led part...
May 22, 2009. 5:35 AMjames.mcglashan says:
who thinks it would be nice
May 22, 2009. 5:36 AMjames.mcglashan says:
i would need somethink like more batterys if wireless if not wireless then i need a hub who knos how to make a hub for a wireless usb thingy
Aug 8, 2009. 9:01 AMyobwoc says:
you have way
way way way way
way way way way
way way way way
Aug 8, 2009. 9:02 AMyobwoc says:
way way way too many replys to yourself
Jul 8, 2010. 8:00 AMRedgerr says:
i lol'd
Sep 7, 2011. 6:11 PMndreschel says:
Sames :P
May 25, 2011. 12:07 PMshellback says:
Fantastic prank! Thanks!
My boss's keyboard has been playing the funky chicken song for the last year and a half.
He thinks it's a virus.
Aug 12, 2009. 11:24 PMDELETED_McDonalds825 says:
(removed by author or community request)
Oct 15, 2009. 4:01 PMmason0190 says:
mhm, he'll do that.
Oct 13, 2009. 1:46 PMSGplayer says:
 bwahahahaha! now everytime someone clicks caps they hear " mother i come bearing a gift. its in my diaper and its not a toaster"
hilarious
Sep 24, 2008. 9:40 PMshmuki says:
my caps led flashes on start up too
Aug 8, 2009. 9:09 AMyobwoc says:
then your victim will have to listen to, "he-... hey-.he-......hey now, your a ro-... hey now, your a rock st-... h-....... hey now, your a rockstar. get the show o-... XDXDXDXDXDXDXDXDXDXDXDXDXD
Apr 26, 2009. 11:46 AMtotos says:
another way to undo the prank:cut any of the controlling wires and make a switch at the bottom of the keyboard, then connect the ends of the cut wire to the switch, label the switch as "caps music" and give the victim an option to choose to either leave the music or to turn it off.
Mar 24, 2009. 3:26 PMheadcrab says:
Cold Heat Is Rubbish i used it in a really exspensive project lol it didnt say on the box that it would fry everything! there goes a $70 circuit
Mar 1, 2009. 4:50 PMmg0930mg says:
Cold heats suck. Ok, good other then that.
Mar 22, 2009. 5:24 PMmman1506 says:
cold heat went bankrupt . the coldheat glue guns nice
Mar 23, 2009. 6:40 PMmg0930mg says:
Is it, didn't want to purchase anything after that crappy soldering iron. :R
Feb 27, 2009. 11:10 PMDeviantgeek says:
i think he did not want it removed so he would be forced to use the shift key... or else!
Jan 3, 2009. 1:01 PMMillawi Legend says:
Cool!
Oct 30, 2008. 3:22 PMIW5 Industries says:
i have the same keyboard
Apr 3, 2008. 10:49 PMcraig3 says:
Hey man, thats the same drill i have. May be a bit slow but its got some torque on it ai?
Apr 3, 2008. 6:16 PMPocketSized says:
Very nice prank. You've got my vote.
KipKay has plagiarized ideas before, so I'd find it no surprise if your claims were correct.
Talk crap for money! It’s easy!
Apr 3, 2008. 5:44 PMjoejoerowley says:
Dude, thats bogus. I really respected kipkay. makes me sad. Nice instructable!
Apr 3, 2008. 3:23 PMA good name says:
This is one hundred percent copied from kipkays "Musical keyboard prank" DO NOT VOTE FOR HIM. On the other hand, vote for me :D But, if Kipkay's entered by now, just don't bother to vote for me, cuz he'll win :(
Apr 3, 2008. 4:58 PMGorillazMiko says:
Hahaha, awesome! This is like Kipkay's though.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jgillick
