The Sixteen-Strand Braid
 by Kiteman
Following the eight-strand braid, I thought it ought to be possible to create a sixteen-strand braid.
I was right!
Using the same loom, It makes a thicker, more cylindrical cord with a shallower helix.
Step 1: Starting.
I raided Kitewife's yarn stash, and found four complementary colours.
I cut two equal strands of each, then folded them in half and knotted at the fold, making sixteen individual strands.
Threading the strands through the loom, I arranged them in opposing pairs - two white strands opposite two white, two purple opposite two purple etc.
  • I only used this arrangement to make the steps of the weave clear, but the result looked rather good.
brooklynlord says: Jan 23, 2010. 9:34 PM
I'm kinda runnning out of stuff to make looms with....
My 8-knotched loom was 4 pieces of flat lego stuck together.....
Any idea of matierials (That can be worked by hand easly)?
Thanks in advance
eternalwind in reply to brooklynlordDec 16, 2011. 3:42 PM
you could use a paper plate tha's been cut down to size.
Kiteman (author) in reply to brooklynlordJan 24, 2010. 4:25 AM
Scrap card should last for at least one braid.
Somebody else says they use an old CD - cut notches with a hacksaw and sand off the rough bits.
Just about anything will do the job.
brooklynlord in reply to KitemanJan 24, 2010. 9:26 AM
What about the clay stuff that remains soft until you bake it? i think im going to use that...
Kiteman (author) in reply to brooklynlordJan 24, 2010. 9:35 AM
Polymer clay ("Fimo")?
That would work.  It would probably feel nice to use as well.
Lithium Rain in reply to KitemanJan 24, 2010. 2:04 PM
Also known as sculpey. Less expensive than Fimo IIRC.
Kiteman (author) in reply to Lithium RainJan 24, 2010. 2:15 PM
Thanks.
mkslocomb in reply to KitemanJun 22, 2010. 7:54 PM
kumihimo looms are made out of thick "foam" available at most craft stores... or just buy a kuhimo loom (at less than $10)
brooklynlord in reply to mkslocombFeb 8, 2011. 9:23 PM
Just lost my loom :(
Now I'm kinda stuck.....
Last time i used a round wooden disc i found at Michael's, a craft store.
I made the centre hole with a file, i spun it until it made a hole and widened it with the file then witha pencil.
I made the notches with a different file, and i had to widen those too.
Now that's lost, uhhh.........
callidore says: May 29, 2011. 8:00 PM
brother,
just pick up a round topped bar stool, in an unfinished wood store. put a 2 inch hole in the middle, with a cup shaped hole cutter drill bit, and then use an agle grinder to round out the edges, and voila. a professional mauri dai for cheap.
regards,
kevin
ttsgeb says: May 13, 2011. 12:12 AM
This is exactly what I needed. I've been trying to figure out what to do with the ends of the 48 strands of rope in a hammock I'm making, and this will nicely condense them into 3 large, but much more manageable cords that I can then turn into a laid rope and eye splice.
Thank you.
Kiteman (author) in reply to ttsgebMay 13, 2011. 9:26 AM
You're welcome - could you post a picture of the finished job?
ttsgeb in reply to KitemanMay 13, 2011. 10:17 AM
It's going to be a while before I'm to the point of having a finished picture, but I did a quick mockup of the ropes to make sure I have the braid figured out.
The rope is made with this same braid, except it's only 12 strands.
I'm going to have to make the braid a bit tighter on the final project, but I think I have the process down pretty well. I'm also able to do it a bit quicker because the loom can set on my lap, allowing me to use two hands to braid.
cammy1345 says: Mar 8, 2010. 4:45 AM
Hi there everyone,
I have used a plastic ice cream lid for Kitemans 8 slot disc. I wanted to use up strips of patchwork material. So I used a compass, blade knife,ruler and a paper punch. After cutting the disc from the lid, I cut a circle in the centre about the size of our old 2 cent piece (Australia). Then measured and ruled the slots. Cut 1cm slots then punched a hole at the end of the slot. This allowed me to use 3cm wide strips of material and the holes hold it in place as I go around. My idea is to coil the material rope up to make a colourful floor mat. So far it is working a treat. I just slip stitch a new strip on as I run out of strip.  I also roll the strips up and pin them so I don't end up with a tangled mess.
Good job Kiteman keep it up :) Cheers Janey
BWP says: Oct 3, 2008. 2:01 PM
I thought I understood it but the video does make it much easier to understand ... and nice music with it too lol. BWP :o)
Kiteman (author) in reply to BWPOct 3, 2008. 2:18 PM
It's called Just Take Five.
thatkidej in reply to KitemanSep 21, 2009. 9:54 PM
  • "Take Five" by the Dave Brubeck Quartet
strmrnnr says: Jun 21, 2009. 9:31 AM
Did one up this morning out of 22AWG mag wire. 16 - 14 inch strands came out as a 1/4 diameter braid 7 1/2 inches long. I just twisted and super glued the ends. It ids not as smooth as the yarn, but it is pretty.
Kiteman (author) in reply to strmrnnrJun 21, 2009. 12:40 PM
It is - thanks for sharing it! Did you use a wooden loom?
strmrnnr in reply to KitemanJun 22, 2009. 9:57 AM
Acually I used the plastic lid from a 5 gallon water bottle. I had one here and thought that the vertical sides would be better for the wire. I will make a good wood loom someday though. I always liked this type of thing and it is easier to carry in your pocket them the old wooden thread spool with the nails in the end. They pass the time well when sailing.
Kryptonite says: Feb 4, 2009. 9:37 PM
Wow, there's a Kitewife? ...This is cool to know there's a family of Kites...
Kiteman (author) in reply to KryptoniteFeb 5, 2009. 11:31 AM
There're four of us altogether.
Kryptonite in reply to KitemanFeb 5, 2009. 9:56 PM
Only four? What about grandmother, and grandfather kite. Not to mention brother & sister kite. At the rate you're going you're nearly extinct! Oh no, this is terrible... no more kites.
Kiteman (author) in reply to KryptoniteFeb 6, 2009. 3:45 AM
There are only four of us in the house, and we're the only four in the family who would recognise the appelation Kitesomething as being linked to us.
puffyfluff says: Oct 2, 2008. 5:19 AM
My, you seem to have a large knowledge of making cords.
Kiteman (author) in reply to puffyfluffOct 2, 2008. 11:11 AM
Not really, I just seem to have the knack of sharing what I do know.
Sunny124613 says: Oct 2, 2008. 4:57 AM
ooooh pretty!I would do this but I seem to have lost my magical touch with yarn and sring
Lorem says: Oct 1, 2008. 12:13 PM
Wooow , very nice, I just hope you can make a video.. no matter how many times i´ve tried.. i just don´t get. it.. hehe :P Thank you..
Kiteman (author) in reply to LoremOct 1, 2008. 3:45 PM
OK, video's in the pipeline.
Lorem in reply to KitemanOct 1, 2008. 7:22 PM
Thaaaaanks... Now i finally see it... thank you!!!!!!
gmjhowe says: Sep 27, 2008. 1:44 AM
nice work kiteman, that actually looks really good, im tempted to try the same but with a length of leather thong.
Kiteman (author) in reply to gmjhoweSep 27, 2008. 4:05 AM
Oh, cool. You ought to start and finish it with a metal cap of some sort (is ferrule the right word? Or an aglet?) Oh! Make it with a small neodymium magnet in each aglet/ferrule as a fastener!
gmjhowe in reply to KitemanSep 27, 2008. 6:39 AM
you know, i might just do that!! magnets would work a treat! *adds to list of projects to do*
BEAST14 says: Sep 26, 2008. 4:41 PM
What is the easiest way to get it to stay as a bracelet, how do you get it to stay together?
Kiteman (author) in reply to BEAST14Sep 27, 2008. 3:53 AM
Just knot the end when you finish - the knot slips through the loop at the start, and simple friction holds it all together.
LinuxH4x0r says: Sep 26, 2008. 6:49 PM
Nice!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
