Step 8Put it Together
Now is the moment you've been waiting for. Time to put this together.
- NES -
Installing the main board was as simple as tightening a few screws. I installed the power/reset buttons by holding it in place with some epoxy and hot glue. Then I put the controller ports stacked on top of each other and held in place by a generous amount of hot glue. I made sure the player 1 port was on top. The reason I used hot glue was that it is sturdy and flexible. That way it will stand up to some abuse from plugging and unplugging controllers.
- SNES -
This one was pretty simple. I tightened the screws to attach the main board. The power switch, reset button, and controller ports were already in place.
- N64 -
This was also pretty easy. Since the controller ports are part of the main board, all I had to do was tighten a few screws.
- PS1 -
The first thing I did was go ahead and attach the main board and power supply board with the screws. I put the controller ports in the same way as I did the NES ones, lots of hot glue.
The disk reader installation was next. My idea about the epoxy was a little tougher than I predicted, because I had to constantly spin my disk to make sure the epoxy hardened while the disk reader was in straight. For some reason, it kept trying to move around, so I had to push down pretty hard with one hand and periodically spin the disk with the other. After about half an hour, I took my hands away and flicked the disk a few times to make sure it would spin. Luckily my half hour was not wasted. It spins nicely!
Just in case, after I was finished, I applied more epoxy so that it shouldn't ever move again. This time I didn't have to help it harden in the right position.
- Gamecube -
Since I had already made the bracings and drilled the holes for the bolts, there wasn't much to do with this one. All I had to do was install it and tighten the screws. I also had to make sure those open/closed switches were pushed down.
- Xbox -
After installing the main board, I just had to install the other components. I was running low on epoxy, so I ended up using hot glue for a lot of the parts. I glued the power supply board, power/eject buttons, and the controller ports on the side. As for the cd drive and the hard drive, they were a little harder, but still pretty easy. I glued the hard drive onto the bottom of the cd drive. I then glued both of them to the back of the monitor case. Just in case, I put a small bracket in for extra support.
Now that all the systems are in place, I glued the video switcher onto the side with the buttons lining up in the middle of the holes.
(Sorry for the lack of pictures on this step, I got excited that I was almost done and forgot to stop and document what I was doing.)
comment
Add Comment
skittlespider (author)
says:
Add Comment
