Been a woodworking enthusiast is not enough especially if you don’t have a place to work and you leave in an apartment court.
In my case not only this was the issue but also I had no budget and space for big machines, so I came up to do the impossible for me.
I leave in Nicosia - Cyprus and woodworking it’s not at its best here. The woodworking accessories they sell here are very basic and everything is mostly oriented on the cabinet makers. Even a simple miter track I need to import from UK or USA, most of my things are from there, as for wood... Oak - Beech - Swedish pine - low quality plywood - cheep-boards and MDF that’s mostly all you can get and there price is ridiculously high.
Everything was design by using Google Sketch-up which I believe it has been proven to be a valuable tool to woodworkers.
The sketch-up general view image shows the whole idea in detail. Also I will provide detail photos of the whole project built.
So at my open air parking space which I have in my building there’s a small storage room with dimensions a bit more than 5X5 feet (1.6X1.6 meters). In that space I decided to keep my workshop and work openly in my parking area.
The problem is that you can spread things around in that parking space but everything has to be stored and locked safely when you are done as well as to clean to area.
Fortunately my neighbors had no problem with me doing so, but I am also been careful running the power tools only at selected hours.
I decided to build a multi power-tool bench 59X20 inches (1.5X 0.5 meters) which will fit into my storage room and hold simple hand tools that will allow me to build any woodworking project I want. Made out of 2X4” and 2X2” for the body, plywood for the sides and an 3/4 MDF top laminated with Formica for better strength.
The tool bench holds 5 major tools, drill press, sander, jigsaw, circular saw, router with a lift device and the possibility for a lathe (later addition).
It also has a vice, 5 small drawers (one for each tool’s small accessories), under storage space, and 8 electrical sockets with wiring. The bench sits on 5 casters with stoppers so that it can easily roll into and out of the storage room.
You will also noticed that there is an angle cut on the bench design, that was done so that it will allow me some space to pass through into my storage room even when the bench is inside it.
I am aware of that jig/router lift idea; I have even design couple of ideas/designs based on it. The router I am using is not a fixed base one but a plunge type and the idea was that you may need to easily take it out and do some hand work with it. That was the logic behind it at that time. As to the easiness of using a scissor car jack (a good one), believe me it’s so easy and accurate that you want believe it unless you try it.
But yes, your point is very good and I am sure that someone will implement that on such a multi bench.
Thank you for your input.
Thanks for visiting and comments.
Go for it.
Any motor that falls into some sort of criteria I described above will do.
Good thinking :)
If the work will be too narrow to reach the pins on either edge of the table, you can use a 1x4 or other support to span the distance between the pins. Separate the pins by how much throw your bench end vice has, or increase that by setting up one side of the vertical board so that it will reach onto the bench a bit further.
Very nice project by the way.
Yes you could mound the grinder on the workbench too, but the grinder is not something I need often and I prefer to keep the top of the bench as free as possible.
If the Drill Press and Grinder have similar bases, you could simply exchange them as needed, but I gather that the drill press gets a lot more use.
thanks for visiting
My question, is how did you get started before you had the bench and tools mounted? It is the old problem of you can't build it till you have it.
Again, thanks for your inspiration
Brian in Brazil
Well everything depends always with what is available to you or near you. So as they say to build a bench you need a bench :-)
In my case I had a couple of saw horses and with a piece of a kitchen top it served me as a bench to work on. I also got a large piece of polystyrene foam board and used it on the floor to cut the plywood top in approximate size with my handheld circular saw and a straight wood clamped as a guide, then I cement glued the Formica and trim them together to its final size. No need to say that everything was well planed before I started.
I would like to give a link to watch a video of a similar method and I believe it will be clear to you on how to start. It’s from Fine Wood Working and the video you need to watch is “How to build a Workbench”.
http://www.finewoodworking.com/getting-started/season-two.asp
If you need more help you can always ask me here.
Regards
Stelios
Can you give us more details on your sled? Even some close up pictures would be great.
Sorry but the only thing I can’t give away is the sketchup files, besides it won’t do you any good because the design is based to fit my storage place and maybe yours needs to big bigger or smaller. I think that the photos can give a clear idea. If you worry about the bench joinery, then what I can tell you is that the legs are made with two 2X4s so you just interlock them. If you need any help you may ask me anything you like.
Thanks
