3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Smallest Workshop in the World
Step 32. Disk Sander
2. Disk Sander
  • last photo ←
My very old drill was used to become my disk sander. Mounted under the table with a sanding wheel velcro attachment and a sanding table makes perfect job.
With the help of a friend we rewired the drill’s electrical functions and put everything in an electrical socket box. On and Off switch - Forward and reverse - Fast and Slow fixed speed - adjustable speed control, all functions run smoothly and it’s so handy (see picture below).
The sander’s table is attached with two threaded inserts on the tool-bench, bolds and wing nuts through the table to tighten it to the bench.
The sanding table has several functions, one is the use of a simple T-square for parallel sanding, has an angle guide for sanding miters and a circle sanding jig attachment for cutting perfect circles from very small ones up to 12 inches (30cm) diameter circles.
3 comments
May 2, 2010. 7:39 PMwhodatrat says:
 Hi The motor control used for the sander was icing on the cake. Any hint on how one would go about tackling this circuit ? Eg  what are the individual components?
Thank you
Michael
Sep 2, 2010. 4:46 PM2 stroke says:
why not put a zip tie n the drill trigger and splice a dimmer switch i the cord to control the speed
May 3, 2010. 9:51 AMharvey639 says:
 what does cw and ccw stand for?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
182
Author:steliart(Stelios L.A. Stavrinides)
Design Communications Graphic & Web Designer Photography NYIP, PSA ---------------------------------- Woodworking 3D CAD designs Photography Scuba Diving (PADI Assistant Instructor) Iconography Paint...
more »
