3 Simple Ways to
Share What You Make
Other ways to share:
Mini Cyclone Bucket Dust Collector
by
steliart
Bench Lathe 3 in 1 (Lathe - Sander - Grinder/Sharpener)
by
steliart
A Precise Table Saw from an Electric Hand Saw
by
Phil B
Combo Miter Saw Station Lumber Rack
by
noahw
Tips and Jigs Part 1: Circular Saw Straight-Cutting jig
by
Pkranger88
Coolest crooked lamp table you will ever see
by
baustin
Support Bench Tools on a Workmate
by
Phil B
156,935
views
Related: small, workshop, Multi Power, Tool Bench, Drill Press, Disk Sander, Jig Saw, Circular Table Saw, steliart, Miter Gauge
Comments: 371
Rating: 5
All Steps Viewing
If the work will be too narrow to reach the pins on either edge of the table, you can use a 1x4 or other support to span the distance between the pins. Separate the pins by how much throw your bench end vice has, or increase that by setting up one side of the vertical board so that it will reach onto the bench a bit further.
Very nice project by the way.
Ian
When I made a table for my workshop at home I bought a 3 foot x 7 foot x 2 inch solid core door with out any holes in it from a recycling place. At one end on the side I mounted my wood vise the way you have done. I made the frame from 4x4's and put a bottom shelf in it and on top put 1x12's lengthwise on it then lay the door blank on those, lining up one end and one edge to be flush with the frame. Then screwing through the 1x12's into the bottom of the door blank. It was a cheap table for me to make and it is really solid.
I really like stuff a person can make for cheap that lasts a long time.
I needed one, so I made it, just as you have made your work table and shop.
When a person makes something like that, you get such a feeling of accomplishment form doing it yourself vs buying a table.
The last couple years my health has been so bad I haven't been able to get out into my shop, but hopefully I will be able to later this year. I built my bench in 1994 and it has never gave me any problems.
You can be really proud of yourself, you have done some really nice work using what you have had. KUDOS to you! You have put it together very well.
Ken
0430100635
