The Smallest and the Brightest Flashlight Ever!
7,483
64
10
Posted
Introduction: The Smallest and the Brightest Flashlight Ever!
this is our new helper for camping,mountain climbing,reading and sailing.it's also very cheap and it costs under a dollar.
Step 1: What Do You Need?
1-1w power led
2-3.7V 350mA li-ion battery
3-li-ion battery charger board(optional)
4-power led lens and holder(5^ or 45^)
5-small on\off switch
Step 2: Hot Glue the Power Led to the Battery
Step 3: Hot Glue the Switch
Step 4: Solder Them All Together
then add the lens and hot glue all the thing together.
Step 5: You're Done!
now you are done and you can test the flashlight as i tested the battery will last about an hour so it's good for the size of it.
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    10 Comments
    The "Stars" That these LEDs come with are NOT the heatsink. Its just a means to screw onto an actual heatsink. Also, I can see that the heat of LED which is pasted directly on the battery has caused battery to swell. Please discontinue use or battery may explode.
    I think your title is a little misleading. I highly doubt that this brightest flashlight ever.
    thanks.i will edit the title.thank you
    Well, maybe it's the brightest to him (the author). Btw, I also highly doubt that the battery is Li-ion, it should be Li-po for that appearance.
    I mean it's the brightest to its size
    No over-discharge protection for the battery?
    it's dangerous to not current limit LEDs. You should be using a resistor in series with the LED.
    thank you.but my led is 3.7 volts,but if you use standard led you should use a 1.5 ohms resistor in series.
    Long life to your LED !
