- The light shall not affect the "stock" look of the bike.
- The light shall operate only when it's dark enough to be effective.
- The light shall operate automatically when the bike is in use and for around 30-60 seconds afterward.
- The light shall blink to enhance visibility at night.
- The battery on the light shall last "indefinitely" when not in use.
- The light shall efficiently utilize the battery's power when in use.
- The electronics of the light shall be reasonably weatherproof -- at least enough that road spray will not affect operation.
Based on that, I made the following initial design decisions:
- The light will use an existing bike reflector to maintain the stock look.
- The battery type will be a 9V rectangular battery.
- The light will use 3 2-volt red LED's for a 6 volt voltage drop. This will additionally allow a 8.4V rechargeable battery to be used in place of the 9V.
- A wire-through-a-spring will be used to detect vibration indicating the bike is in use. The spring will wiggle when the bike is jostled, making electrical contact between the wire and spring.
- A capacitor discharging through a resistor will be used to time power usage on the light for 30-60 seconds.
- A 555 timer will be used to provide make the lights blink.
P.S. In case you're wondering, I used EAGLE (the circuit design package from CadSoft) to lay out the circuits.
Remove these ads by
Signing UpStep 1Make some initial design decisions.
However, even with 150 micro-amps all the time, a 9 volt battery with a capacity of around 540 milliamp-hours would last 3,600 hours -- about 5 months. I'd hate to install a brand new battery, use the bike a couple times, and have to replace it twice a year.
One option was to use a switch, but I wanted to make the light automatic.
But in reality, no more transistors are needed, the original circuit (without the 555) has enough transistors so that it can be made into a standard two transistor flasher circuit. For circuit ideas, see:
http://www.techlib.com/electronics/flasher.html OR
http://ourworld.compuserve.com/homepages/Bill_Bowden/page5.htm#flash2.gif
p.s. you might attract more people by making a catchier title
I had to go to your link to find out what it is.
You wrote "if it confuses you". Very funny. If I was confused, I wouldn't have complained would I? My circuit just wouldn't work.
Calling it "industry design" doesn't make it easy to read.
Instructables are for the average Joe's that doesn't work in the industry.
Hence the reason why I called it the Worst circuit diagram.
The typical symbolic representation of the 555 is http://www.kpsec.freeuk.com/images/555ast.gif
and this page is what typical 555 circuits look like. http://home.cogeco.ca/~rpaisley4/LM555.html#7
To use a 555 for a blinking circuit is overkill , a simple push/pull two transistor capacitor circuit would have done the job.
Average Joes should learn to communicate in the language of electronics if they want to exist in it.
Seems some other inconsiderate people are trying to comfuse you! Here's an example : http://www.instructables.com/files/deriv/FIR/FMX4/EO8EQHO9OEH/FIRFMX4EO8EQHO9OEH.MEDIUM.jpg
Honestly I've looked at hundreds of schematics and they're all drawn up this way pin numbers don't correspond with package outlines. Not that I have seen.
