3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Smart, Stealth LED Blinkenlight
Step 6Build the main circuit board.
  • last photo ←
So here's where I get into that Manhattan-style board construction. I picked up some scrap copper-clad board from a local electronics surplus place (they were apparently trimmings from larger sheets). I liked that they were very thin and light meaning they'd be easy to cut. I snipped out a small square about big enough to hold the components. I figured I could cut it further if necessary. Nonetheless, I drilled a couple 3/16" holes so I could mount it with #10-32 machine screws.
Then I made some contact points. I don't own a metal punch but I do have a nibbling tool so I used that. I cut out little square contacts from another piece of copper-clad board.
The first thing I wired up was the vibration switch. I drilled a hole that was just as big as the solid copper wire. It was a tight fit and I had to tap it into place with a small hammer. At least I knew it was solidly in place. I soldered it to the board. Then I took the spring set it over the wire and marked a few dots where the spring touched along its radius. I selected four snippings of copper board to go around the wire and glued them in place, copper-side up. Then I set the spring in place and soldered one point on. I wanted to make sure everything was going well so I got out the meter and confirmed that the spring and center wire were isolated and that they could make electrical contact.
For the 555 timer I decided I'd use a socket. I never did Manhattan-style board construction before and I didn't know how much heat I'd be applying to pins (it turns out to be not much more than through-hole soldering). I had a piece of copper breadboard, reused from a former project, and I cut out an 8-pin piece. I bent the socket pins outward and flat then soldered them onto the breadboard, surface-mount style. I glued the breadboard to the main board. I set it up so pin 1 was toward the edge of the board because there were far fewer connections to make on that side.
I started with resistor R7 that goes from pins 8 to 7 on the 555. I bent the leads and cut them so they were approximately spaced correctly and soldered them on. I then added a pad a short distance from pin 6, gluing it in place. I did a similar bend with resistor R5 and soldered it to the IC pad to the new pad I just made.
I continued doing this until I had added all the components. I stopped briefly to test the capacitor-timer/light-sensor circuit and it worked fine.
1 comment
Aug 17, 2011. 6:23 PMbio88 says:
nice - but why the hot glue and then the metal squares and then spring. Agreed it looks nice but you could have omitted the squares I'd think.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:jolshefsky
