3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Smart, Stealth LED Blinkenlight
Step 7Build bracket to mount circuit and battery holder.
As most people know, a 9V battery fits quite well inside a 35mm photographic film canister. I decided to use that as the weather-resistant battery holder. I fit things roughly in place around the back of the reflector and built a metal bracket by drilling some holes in a piece of thin steel. One was in the center and large enough to allow the reflector mounting screw to pass through (1/4"). I drilled two more 3/16" holes on either side, spaced fairly evenly. I just wanted a few points I could mount things.
I drilled a 3/16" hole in the side of the film canister toward the bottom. I used a #10-32 screw, nut, and washer to mount it. I cut a small hole with a hobby knife to feed the wires from the battery snap and set it in place.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:jolshefsky
