3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Smart, Stealth LED Blinkenlight
Step 8Add LED's to the reflector.
Add LED\
  • last photo ←
In the reflector I selected, there is a white plastic backing behind the red-colored reflector lens. There is a gap between the two pieces so I drilled 3 holes for LED's which don't extend into the red plastic.
Then I did some experiments, wiring up an LED with clip leads and a resistor to supply around 20mA of current. What I found was the reflector material worked in reverse too, so most of the light from the LED was reflected back onto the white background. I didn't like this so I drilled further into the red plastic to remove the reflector pyramids and allow the LED light to get through. This worked great.
Then I went to wire them up. I determined that the flat on the LED shell indicated the wire on the LED that is the cathode or negative terminal. I carefully placed all the LED's in the 3 holes so the flat was on the same side then wired them in series. Between two of the LED's I needed a jumper so I decided to slip in the 100-ohm R4 current-limiting resistor instead. I tested the circuit but found it wouldn't light up. It turned out that one of the LED's had the flat on the anode, so one LED was installed backward. Once I corrected that, all 3 LED's lit up nice and bright.
I soldered on red and black wires to indicate positive and negative, respectively. I added some glue to seal the electronics from the weather and let it sit.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:jolshefsky
