loading
Step 4: Building for testing
The biggest issue here is that I decided to go full out to the 110VAC version. In retrospect, I should have just used a standard 5v supply and run cords to the SSR. However, I went this way, and a good amount of time was spent making sure that I didn't electrocute myself on exposed wiring.
You can pick up the same case at any home improvement store. I took a Dremel to the front panel to make the cut outs. I'm ashamed to say that I was sober and yet the cuts came out that badly.
So, how do you test this? Having a massive smoker in your house may not be convenient. I used a small Tiffany lamp. Tape your thermocouple above the bulb and maybe throw a cloth over it. This will make debugging the PID loop that much easier.
Nice job on the smoker. I have been muling over the smoker idea for awhile myself. One think I really would like to have is the capacity for cold smoking. I notice the Bradley that someone mentionned does that. Most commerically bought smokers I have seen have done hot smoking.<br><br>But, the price of the Bradley is $500. I am wondering whether it is really worth it, or whether you would be better just throwing together some kind of box with an entry for smoke in it? I'd appreciate any comments or suggestions<br>gouthro
Cold smoking is pretty straight forward... I even think there's a Good Eats episode that talks about it. A hot plate with a covered cast iron pan of saw dust will billow smoke. Put that in a box with some aluminum dryer ducting and a fan and you will get a cool smoke out. You can pretty much smoke anything in a plastic bag with some holes poked in it at that point.
I tried the <a href="http://smokedprojects.blogspot.com/2012/09/my-first-project-since-moving-back-to.html" rel="nofollow">Alton Brown flower pot smoker plus PID control</a>. So far so good although I've heard the electric burners need replacing quite frequently.
I pretty much understand that part of it. But, where I am stuck is on the stove part. I don&quot;t want to buy a stove just for this. I am not sure I ge the 'covered' cast iron pan idea. How does this work?<br>thanks Gouthro
Oh, well, there's no stove, just a hot plate. I picked up my last hot plate at the good will for $6. You can get them new for about $20 at a big box store.<br> <br> My old smoker generator that got used in this rig (pre-controller) was a cast iron pan filled with wood that I covered in a disposable aluminum pie plate (poke some holes in it). The pie plate was on there to keep the wood from getting enough oxygen to catch fire, so it would just smolder. So you take those two, and put them in a cardboard/metal/ceramic box with a fan to blow out the smoke through some long-ish tubing to cool the smoke, and inject that into your smoke chamber.<br> <br> The Good Eats episode is available on You Tube, and the <a href="http://www.youtube.com/watch?v=O0v6wUZ5RFY&feature=related">second part</a> shows the process around 1:50.
I finally saw the link to the video in your post. Had a look. I am sure i will get something going<br>thanks G
Thanks for the reply. I looked at Good Eats video but the one I saw had him constructing a hot smoke smoker. I looked around though, and found some other things. One possibly useful one for me was someone using a Weber kettle bbq as a firebox. A flexible tube goes from that to whatever the smoke box is. That may be fairly simple for me to set up. Otherwise, as you say, I imagine I could use pie plates.<br><br>Joe
Do you need a higher or lower temp for fish? What kind of temp range do you get with this controller? Will this enable it to get hotter than 250? I dont like my brinkman because ideally i would like it to get to 300 or so for the first hour for the chips to burn then back it off to around 230 for the rest of the cooking time. Is it possible to get the unit hotter than 250?
what does this exactly do? can u please mention the controller required?
This is a great way to bring some flavor to otherwise bland TOFU!<br>You haven't ignored vegetarians, you just didn't know how many would appreciate this for things like Tofu and BBQ roasted vegetables. Great invention for foodies, keep it up.
Wow! I love this! You did an awesome job here. I've been working on an AVR based PID controller for sous vide cooking, and I'd be very happy if mine looked half as sexy as yours! <br><br>One question I have is what on-board power supply you used? It looks like you just combined a transformer and rectifier, and left it at that. Is that enough? Can you suggest which parts you ended up using? Thanks so much, I'd love to give this a shot!
Nothing fancy for the power supply. It's a 120v-&gt;9v transformer, bridge rectifier, 100uF cap, and LM7805 regulator on the board. The power wiring has a circuit breaker and a MOV for protection as well as the power switch.<br> <br> If done today, I'd go with a <a href="http://www.mouser.com/ProductDetail/Supertex/SR037MG/?qs=sGAEpiMZZMvHdo5hUx%252bJYpwlGSu9PEdF">Supertex SR037</a> to get the voltage. It's cheaper to put it and associated parts than deal with the transformer, and the board space would be much smaller.<br> <br> Sorry I don't have the part numbers... I seem to have lost the BOM for the build.<br>
The derivative is a measure of the rate that the temperature is changing not just how much. The method that you describe to calculate the derivative will be fine as long as you sample at a constant rate (essentially your delta time will be incorporated into your derivative gain), though it will fail/behave funky if your sample rate is changing. Dividing the temperature change by the time between samples would help to prevent potential problems.
Very true. And if I could actually tell how much time had passed, I might have been able to factor that in. The Integral component had the same set of issues, but the 1-2% variation in loop calculation time never really affected anything; the time constant is over 2 minutes. <br><br>The time between samples is roughly constant and the errors did average out after a while. The derivative gain was not a huge portion of the gain on this system so it got the shaft in terms of care taken to make sure it performed adequately. If I was tuning PID loops for Galvos, it would be a different story.
Excellent work. I've been mulling over smoker designs and products for a while now. You may be interested in <a href="http://www.bradleysmoker.com/">these smokers</a> as well, for inspiration for a future upgrade.
Those look great... I'm looking to make a more portable rig as my condo is tiny and there's just no real point in filling the smoker over here. Carting around a smokey steel can filled with lava rocks is also a royal pain. I liked the portable rig they had there with the Mylar/insulation soft box combo. I might want to take a stab at it.<br><br>Thanks for the link!
I'm in a similar situation. The &quot;load-it-turn-it-on-and walk-away&quot; factor is what really intrigued me, plus the low-temp smoking capabilities. Hams, bacons, sausages, etc, etc. I'm willing to buy the wood-chip-cakes, if I can DIY a feeder/burner mechanism. The enclosure will be no problem, I'm thinking junk fridge, or cardboard box.
About This Instructable
41,303views
113favorites
License:
Bio: Letting my EE degree go to waste while I build an IT business
More by dafonso:Kick Trigger to RockBand/Guitar Hero Adapter The Smoke-O-Tron Home reflow SMD soldering
Add instructable to:
