3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Solar Garden Light: adding the Flash
In the previous attempt to increase the output from a basic Solar Garden Light (SGL), publishedhere, we quickly reached a limit: the brighter we make the light, the quicker we deplete the battery, or more properly, the charge we can obtain from the sun during the day.
The solution was apparent: make a flashing SGL. Not only is it much more readily noticeable, and hence, more effective against would-be intruders; it also conserves battery power, so that the battery will last a long time.
The difficulty was designing a circuit that could be made from easily obtainable and inexpensive parts. The result is a simple flashing circuit using only ONE transistor, powered by a single rechargeable battery.And, a simple enhancement of 2 parts will more than triple the light output.
And it is effective - after 4 days of storm & rain, with only the rechargeable from the old light, it's still going strong.
Step 1The circuit
The circuit
The material you will need for the light:
R1,R2,R3,R4: 1.5K-ohm resistor
C1: 470uF (micro Farad)
C2: 1nF (.001uF) or 680pF for 2 x orange or red LEDs
D1,D2: 1N4148 or 1N914 (any low-power signal diode)
Q1,Q2: BC337 (do not substitute!)
T1, made from 3 pieces of thin, insulated wire each 8ft (2m5) long
Solar cell, 1.2volt battery, LED, casing: from old Garden Light
The hi-lited components (Q2,R2) are optional, but will greatly increase the brightness.
The basic circuit is a Joule Thief which is designed to drain the charge in C1 to light the LED. This causes the LED to flash. After that C1 has to recharge through R3, which takes about 3/4 seconds, at which point the cycle repeats. The optional parts increase the power to the LED, and make the flash longer as well.
This circuit is also unique in that not only will it switch off the flashing when the battery begins to charge; it will also turn the light back on to avoid overcharging the battery.
10 comments
Oct 27, 2011. 8:49 AMhehinckley says:
Would that design work for making an LED flashing sign?
Mar 28, 2011. 7:08 PMdezignable says:
I would like to make the flashing LED(s) light up fiber optic strands (encased in something like concrete) that spell out a name or address. Will 30 AWG wire-wrap wire work as well as 32 AWG wire-wrap? I would like to buy no more than needed (8 feet) if possible, but can't find a source for 32AWG wire-wrap.
Jul 4, 2010. 3:03 PMsasaa says:
in some communities, red and/or blue flashing lights are used to signify a crime or emergency. TRUE don't use red lights!
Jun 8, 2009. 1:15 PMralegg says:
Do you have a video of it in action?
Jun 8, 2009. 9:48 PMralegg says:
very nice!
haha, I just went to your site and realized I had been there before to read about your fake flourescent, keep up the good work!
Mar 13, 2009. 6:35 PMwierd idiot says:
Well that's a flash circuit you got there. :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:qs
