3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Sprintronic - Clock with Laser Cut Case
If you have read Sky Mall magazine on a plane, then you have seen the inspiration for the Sprintronic clock.
This is a very easy, inexpensive, and quick project. The clock's movement is a standard battery powered quartz movement from an arts and crafts store. Its case is made of inexpensive 5 mm (0.2 inch) plywood. The face lens is a small piece of Plexiglas.
The case and lens patterns were cut on a laser cutter, however neither are too complicated to fabricate using a scroll saw and drill. The face lettering can be transferred using the toner transfer method when cut with a scroll saw.
A complete kit for this clock is now available at http://www.dougparadis.com/products-page/clock-kits/sprintronic-clock-kit/
Step 1Materials and Tools
Materials and Tools
Materials:
     1  -   Battery Powered Quartz Clock Movement. I have used movements
              sold under the labels "The Clock Shoppe" and "ArtMinds". The
              movement shaft should be sized for either 1/4 or 3/8 inch face thickness
              (you may need to adjust spacing slightly with washers).
     2  -  11 inch by 12 inch pieces of 5 mm (0.2 inch) plywood
     1  -  3 inch by 4 inch piece of Plexiglas or clear plastic
                   (I used 1/8 inch thick Plexiglas)
     2  -  Popsicle craft sticks
     1  -  Sheet of 110 weight (lb) card stock.
     1  -  #4 - 1/2 inch (3 mm x 12 mm) screw
     2  -  #4 washers
     1  -  #4 lock washer
     1  -  #4 nut
     1  -  Credit card size cold laminating pouch
TOOLS:
     Scissors
     Ruler
     Craft knife
     Glue (wood and super)
     2 small Clamps
     Sand paper
     Block of wood
     Access to laser cutter or scroll saw and drill
     Optional:
      3/32 and 3/16 inch hole punches
      Stain
      Finish (varnish or other)
      Mallet
35 comments
Aug 31, 2011. 7:04 AMjmitch77 says:
I created a clock like this concept last year and thought I came up with such an original idea! Noooo!! Ha ha!
I like the customization you did on the dials and box! Nice job! Well, I guess I won't enter mine in the contest since it's so close to yours, and you did a much nicer job!
My idea was to read the time from the left side with the numbers in line with the "pointer" as the time (8:45 in the picture).
Great job!
Feb 22, 2012. 1:47 PMjonpersonals says:
Like it ! bit of a steam punk look too.   It seems
A surplus  ,used Bike gear would work too.  Or most any gear over 12 teeth
Aug 30, 2011. 7:28 AMlaserline says:
I just added it to my favorites. I guess that definitely means it deserves (and got) my vote.
Aug 28, 2011. 5:19 PMpahosler says:
making the mins on the outside should be fairly easy... make a clear plastic disk with the mins on the edge, the hours will be on a disk behind them showing through the gap.
couldn't you reverse the movement by rotating the clock movement 180 degrees (put it in upside down) instead of trying to disassemble the thing and flipping the stator motor?
Aug 28, 2011. 7:46 PMpahosler says:
doh! you are right, not sure wtf I was thinking!
Aug 30, 2011. 1:36 PMTheOneTrueStickman says:
You were thinking correctly, just not on the right axis. :) If the movement is mounted to the front of the clock ("backwards", not "upside-down" - 180 degrees on vertical axis), then you're right, it will reverse the apparent rotation direction.
The disadvantage is the amount of space between the front of the housing and the dials is larger. Nothing one can't design around, though.... and then you could put a time adjustment knob right on the front!
Aug 29, 2011. 1:34 PMKaelessin says:
With a bit of finagling you could manage to put the movement in backwards (requiring larger dials) to reverse direction.
Aug 29, 2011. 4:57 PMjavajunkie1976 says:
Have you ever thought about putting a small lightbulb on the bottom of the arc so that the face can be read at night?
Aug 28, 2011. 10:35 AMsimplebeep says:
This is really cool, especially the fact that you can build it with a standard clock motor.
It'd be interesting to figure out a way to have the minutes dial show on the outer ring, rather than the inner, in order to make the clock more precise. It would also be interesting to reverse the direction, as per this instructable, to make it seem like the hand in the display window was moving forward rather than backward.
Anyhow, just a thought. This is pretty damn sweet as it is!
Aug 29, 2011. 6:50 PMsimplebeep says:
Indeed. My thoughts were a "maybe someday" sort of musing. I've worked with these clock motors and I understand how difficult it would be to get the minutes on the outside ring. Unless you used a transparency sheet...
Aug 28, 2011. 6:25 PMhandy157 says:
Moving the minutes to the outside of the wheel next to the hour would be easy but make it much more difficult to read the time. You wouldn't use the current minutes disc at all, but just use the disc that is mounted to the hour shaft. You would just have to make 60 little lines or dots between each hour and you'd probably want to mark the 5 minute increments to be less confusing. The size would make it very hard to read anyway, unless you made the entire clock much bigger. Then you would have a wall clock instead of a desk clock.
Aug 28, 2011. 4:32 PMjelmore1 says:
How about using overhead transparency sheets for the minute dial. Then it could overlap the hour dial all the way to the edge.
Aug 29, 2011. 6:51 PMsimplebeep says:
Oops! sorry, I hadn't read your comment before I posted mine above.
Aug 29, 2011. 10:41 AMdimtick says:
I really like the idea of this but not really the final outcome. I think there is a freedom and power that a laser cutter gives you. it would be cool to see something that really took advantage of the advantages the laser has over convential methods.
I've attached an image of a cardboard chair just to illustrate what i'm talking about. that is "out of the box" thinking. can you image trying to create that using conventional tools?
Aug 29, 2011. 11:09 AMzerobitjack says:
That chair would be quite easy to make with a scroll saw.
Aug 29, 2011. 1:28 PMdimtick says:
I think my post came out harsher than I intended.
I've done my share of scroll saw work and cringe, thinking about what it would take to cut about 50 identical pieces with those curves. It would take forever and I'd go batty before I got halfway. a laser cutter doesn't care if it's cutting a curve or a straight line or if it's on piece 1 or 50.
the chair photo is simply one example of looking at a problem differently and thinking about the oppertunities that a laser cutter brings.
Aug 29, 2011. 12:29 PMdebefree says:
Thank You for such a fine project and clear instructions
I "saw" the "dashtronic" influence at once.
This is going on my clock to do list..
Aug 28, 2011. 3:43 PMstienut says:
do you have parts and pieces for sale? I'm all over this!
Jim
Aug 28, 2011. 11:56 AMskylerskinner says:
So cool man, I have a steel watch made by Stauer that looks just like this... in fact, I'm sure you know that Stauer uses that signature fancy "S" that you have in the middle of your clock face.
Aug 28, 2011. 7:39 AMRedBinary says:
Having the end grains showing on front is a bit of a downer, but otherwise that enclosure is damn sexie!
Aug 28, 2011. 9:44 AMRedBinary says:
I was basing my comment on the pictures, though I think I might like the black epoxy, too! I will *definitely* have to try that on a bent-wood project that I am working on about now.
Aug 28, 2011. 8:31 AMbiloyp says:
Very nice job! Gonna have to try this one.
Aug 28, 2011. 7:01 AMExocetid says:
Very nice design.
Aug 27, 2011. 2:43 PMDream Dragon says:
Excellent project. Nicely documented. Thank you for sharing.
Aug 27, 2011. 2:26 PMjavajunkie1976 says:
Very classy look. I've always been in love with the design ever since I saw a similar wrist watch in a National Geographic magazine.
Aug 27, 2011. 11:47 AMfleirvik says:
Love it! I have had a similar idea to this for long and combined with the need of a clock at work, I now seem to have found what I was looking for! Thanks a lot!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:Doug Paradis
