Step 7Assembling the Case
Next place the clock on its side and carefully position the second side piece. You may need to adjust the position of pieces to make sure everything lines up. Use the palm of your hand to gently tap the second side into place.
After the sides, front, back, and movement mount are all attached, place the clock on its feet and align the top. Again use your palm to gently guide the pieces together. All the pieces should fit together snugly. No glue should be needed for the case.
Add Comment
