Introduction: The SteamRoller Riding Contraption
Picture of The SteamRoller Riding Contraption
This a self balancing two wheel, two person vehicle. It self balances because the center of gravity is located below the center of the wheels.
Each rider controls one wheel. Pedal together and you move in a straight line forward or backward. Anything else is a turn including a spin in place by pedaling in opposite directions. I guessed a top speed of around 7mph would be a good start. I set the gear ratio accordingly. It was designed for kids around 5' tall, but it can easily handle taller. I am 5'6" and about 160lbs. I rode it with my daughter and it worked well.
This instructable details how to make a basic version. I designed everything in Pro/E. I have exported all the parts to DXF format so you can access with free software like QCAD. The drawings have basic dimensions for overall reference. They are 1:1 so you can scale off them or add additional dimensions. There are also PDFs too. I used my homemade CNC router so I added a lot of details that are not required. Need more info, detail, pictures...just ask.
The project took me about 16-20 hours over 3 weeks to build. A lot of that was design and testing, so it could take you less time. I had a lot of left over and found material that I used. If you started from scratch this could cost $150 to $200 to build. The bearings and drive train parts are the most expensive. I bought them at a surplus store. Hopefully you can find them cheaper.
The design worked pretty much as intended without any major problems. I did learn a few things along the way. I added "possible improvements" sections to each step that might make your version better and easier to build.
The working name is SteamRoller due to the steampunk look. The kids like Wheels of Doom and Portable Porch Swing. Does anyone else have any suggestions?
Step 1: Materials
Picture of Materials
Here is the basic list of parts. The dimensional lumber is estimated because I had enough scraps to cover that. I ripped the various sizes needed on my table saw from larger lumber.
Wood
(2) 4' x 8' sheets of 3/4" Plywood (I used BC Exterior grade)
(1) 4' x 8' sheet of 1/2" Plywood (I used BC Exterior grade)
(1) 2 x 4 x 6' pine board
(1) 1 x 6 x 6' pine board
Surplus Center Parts
(4) 7/8 4 Bolt Bearing Block (#1-205-14-4)
(2) 10' pieces .40 pitch chain (#1-1163-40)
(2) 11 tooth 7/8" shaft sprocket (#1-2123-11-D)
(2) 30 tooth sprocket. (#1-2123-30-4B)
(4) 7/8" dia. shaft collars (#1-2766-87)
(2) #40 Chain Connecting Link (#1-1087-40)
(4) 7/8" I.D. bearings (eBay)
6' of 3/4" heavy wall copper tubing
4' of 1" thin wall copper tubing.
(12) 3/4" 90deg copper elbows. (buy a bag/box of them...much cheaper)
(2) 1" copper end caps.
(2) 8" long 1/2" pipe (wheel Axles)
(2) 1/2" pipe flanges (mounts axles)
26' 5/8" I.D. Heater tubing
5/8" double barbed fitting.
1/8" NPT Schreader tire value
Step 2: Seat Contruction
Picture of Seat Contruction
I started with this section because the dimension for everything else scale off this.
I drew a 46" diameter circle on the garage floor in chalk and I worked with my 10 year old son to find a comfortable and practical riding position. I traced his body and measured for the seat dimensions.
Start with the seat sides. They are made from 3/4" plywood. Draw the pattern on the plywood and cut them out. Be sure you make a right and left hand version. Drill all holes as shown on the plans. I routed a groove into the sides to accept the seat parts, but this is probably not required and may be difficult to do by hand. The top bar is 1" copper pipe with end caps. I thought it would brace the side from bending in and give something to grab while getting in. I drilled flat bottom holes the diameter of the pipe caps about a 1/4" deep. I ran self tapping screws through the sides and into the cross bar to secure it.
Cut the (3) seat parts and the (2) cross members that join them together. Screw them together. Handle the seat carefully until is is bolted to the sides.
Place one chassis side on the ground with the inside facing up. Put the better side of the plywood towards the inside. Place the seat and screw strips in place. The screw strips screw to the sides and to the seat. Double check everything, then screw and glue the screw strips to the sides. Repeat this process for the other side. Make sure it will be an identical but opposite version of the first. Now screw and glue the seat assmebly to the sides.
Just in case some things have shifted a little during assmebly I suggest making a paper or cardboard test version of the center console, so you can make adjustments if needed. Be sure the pedal holes align with the sides. Cut two of these making a right hand and left hand version. Screw and glue to the seat. I put an optional cap/arm rest on this and a copper grab handle.
Install the pipe flanges and pipe pieces for the wheel axels. I used tee nuts.
Install the top cross bar. I used copper pipe, but anything strong in compression will work like a dowel rod.
Now find some way to take it for a test swing. I used (2) work tables as shown in the picture. Make sure it is strong and safe before you climb in.
Possible Improvements: The seat sits awfully low. Raising would give more clearance, but it might be tippier.
Attachements:
DXFs.zip 2D drawing of most of the parts
Drawings.pdf PDF versions of the drawings.
Steamroller.skp: Sketchup export of the 3D model
Steamroll_asm.zip. A STEP file export of the 3D model.
Step 3: Wheels
Picture of Wheels
The wheels should be as big as you can cut from the plywood. I made mine 46" dia. because that is the biggest my router could cut.
The bearings I got were are aligning. This means the bearing axis will tip away from perpendicular as need to align to the shaft. Therefore the wheel will not stay straight unless you put one on each side of the wheel. This will prevent the wheel from canting on the axis. If you can find a better cheaper solution, let me know.
Mark the center of the wheel. Use a bearing block to mark where to drill holes for the bearing mounting holes. Draw the diameter and cut out. I made some spokes to lighten up the wheels, and give visibility to the sides. They also help with the steampunk look.
I used a 1/4" radius bit in my hand held router to put a small radius around the both sides of the perimeter of the wheel. This allowed the tire to fit smoothly without sharp bends.
Mount a bearing block on each side of each wheel. Use a pipe to temporarily line them up.
Tires:
I used 5/8" I.D. x 3/4" O.D. black rubber heater hose. Lowes sold it from a spool, so I could get the 12+ feet per wheel as one peice. I cut a .25"-.30" wide strip out of the hose. I used the label on the hose as a visual guide to free hand cut with a box cutter. It cut easily in a single pass. It only took about 5 minutes per hose. Be careful not to cut the other side of the hose when cutting. I used some 5/8" long staples to tack this strip around the wheel. This will puff up the center of the tire and add some extra cushioning. I then wrapped the split hose around the wheel stapling it on each side as I went. I stapled about every six inches.
Tires: I spent a lot of time fretting over the tires. I was going to use 5/8" I.D. 3/4" O.D. heater hose in a loop joined together with a barbed fitting and a schrader valve. I tried a test version and it held pressure for the two week test period. I would need to make some cuts in the wheel to fit the valve and I would need to put some rim edges to keep the tire on. I was not sure how well it would hold up, so I went with the simpler method. I was afraid I would have to scrap the wheels if the idea failed.
Bearings. You could easily make your own bearing block out of 7/8 I.D. bearings and wooden blocks. They might actually be better because they would not be aligning.
Step 4: Pedals
Picture of Pedals
The pedals shafts are made from 3/4" thick wall copper pipe and 90deg fittings. The pipe has a 7/8" O.D. that works with the pedal shaft bearings.
Cut all the pieces and liberally flux all the mating surfaces. Put all the parts together to make sure everything lines up, is square and the ends that go through the bearings are on the same axis. I suggest cutting the center vertical piece last in case it needs to be adjusted in size. Keep all the pieces together while brazing. This will make sure they stay square while brazing and will reduce the heating time. I suggest placing an extra fitting on the ends to keep that piece on the same plane. Don't accidently braze those pieces on.
The outer diameter is slightly larger than the I.D. of the 7/8 bearings. I lightly sanded them down to fit though the bearings and shaft collars.
The pedals are made from 2 pieces of 3/4" wood screwed together and drilled 1" dia. This will allow them to be replaced if they are ever broken.
Step 5: Gears and Chain
Picture of Gears and Chain
The gear sizes I liked were all available in 0.40 pitch chain. This is pretty beefy motorcycle style chain. I calculated a 3:1 ratio (three pedal revs = one wheel rev) for a practical top speed. This turned out to be perfect. I chose an 11 tooth gear for the the pedals and a 31 tooth gear for the wheel.
The chain comes in 10 foot lengths. I needed just a little over 5 feet per side, so I needed two lengths. If you want to save a few bucks you could change the design to use a few less inches of chain. It comes with one master link per piece. I would suggest buying a few more master links just in case you need them. I would also recommend getting a chain breaker.
I started out by placing the chassis on a couple of boxes to where the wheels would spin freely. This allowed everything to freewheel.
The first task is to mount the gear to the wheel. It is a bit tricky because the gear is about the same size as the wheel bearing blocks. I made an adapter plate out of 3/16" think aluminum. I used some 1-3/8" long standoffs to hold the plate away from the wheel. Be sure to allow access to the set screws on the bearing blocks after the gear is installed. I stood the gear off the plate with a nut and a washer to allow clearance for chain. Bolt this to the wheel centered on the bearing.
Install the wheel onto the wheel shaft. Slide it in until the gears are aligned. Wrap the chian around and measure the length needed. Break the chain then install it on the gears and put on the master link. Test everything and adjust as necessary.
Step 6: Finishing
Picture of Finishing
After a few preliminary test drives, I striped it down for finishing. I went with a mild steampunk look to complete the family of steampunk contraptions. See the family photo.
I used Cabernet stain which is a dark redish color. I used several coats of clear gloss water based poly varnish over that. I prefer oil based spar varish, but the water based stuff dries so fast I could complete the varnishing in one day. I added some extra brass fittings and polished them up with Brasso. I painted the pedals black.
For all wood screws, I found some with a iridescent yellowish color. I think the finish is called yellow chromate. I found them at Menard's. They almost look like brass, but are much cheaper and more durable.
When rebuilding, use some removable blue Loctite on the machine screws. They tend to rattle loose.
I plan on adding a large steam style piston to the side that will actually pump in and out.
Step 7: Brakes
Picture of Brakes
Nice picture huh...Yes, I wish....
I have not yet installed brakes. My concept was to get some bicycle calibre brakes and adjust the gap between the pads to work on the wheel gear adapter plate. So far it does not really need brakes. It stops easily using the pedals and a few emergency stops have been done Fred Flintstone style by putting both feet on the ground.
Step 8: Riding
Picture of Riding
I was worried about how people would mount the thing, but it is not an issue. You just kind of crawl in. It helps to have someone steady it, but it is not required. With someone's weight way forward the nose contacts the ground and this keeps things stable.
The physics work like this: The pedals allow you shift the center of gravity (CG) of the porch swing forward or backward. The wheels then rotate to return the CG to normal. Climbing hills or getting started on soft ground will require a greater shift before it will roll. This can get a little scary (but fun) as your feet start to point to the sky. New riders might need a push if they get too stuck.
Some small kids who stretch to reach the pedals or don't have much weight behind the axels tend to rid very low in the front and may tend to bounce the nose. I added a little box to the top of the back of the seat. This allowed me to add and remove a brick or two of ballast to get the nose up as needed.
Coordination to go straight is not that tricky. Either rider usually adjusts a little to correct the heading. It is fun to watch kids riding for the first time working out the coordination. Some kids tend to just stop pedaling and freeze when they don't know what to do. This of course causes the thing to immedaitely pirouette on that wheel.
It occured to me that this would be relatively easy to motorize with some wheel chair motors. A joystick with some relays could control it. I think I will keep mine old school though.
Gabriel Bauer (author)2016-01-07
Wow! Nice!
MEEEEEEEEEEEEEEEEEEEE (author)2014-07-12
did someone already buy it?
astral_mage (author)2014-03-15
have u thought abut puting a tiller on so 1 person can control it
Coachfrank (author)2013-08-14
My dad has two antique 54" steel hay machine wheels taht I am going to try to use for this.
ecsaul23 (author)2013-03-27
This looks like sooooo much fun. totally awesome!
thechocolatist (author)2013-03-22
Wow! Really great! Thank you for the Inspiration! That would be great for my little kids :-)
Ricram2 (author)2012-11-01
Hi ! soo i saw your steampunk design and i think is awesome .... would you mind if i try some different style for the design ?
Fred82664 (author)2009-12-25
Admin on this site must be smoking Meth this should of made in the top five of  09. it did make it as 13  out of 50  still not bad ! but still yet it should be in the top 5
ilpug (author)Fred826642011-10-02
agreed. except for the meth smoking part. i dont think they do that.
louis.m (author)2011-08-14
What about "Weird Wheeler" as a name?
Nuonaton (author)2011-08-14
Awesome! I made something similar (3 wheeled) several years ago, nowhere near as cool though!
bdring (author)2011-08-14
It is still going strong after two years!
I am looking to clear it out of my garage. It takes up too much room. If someone in the Chicago area wants it, make me an offer.
The kids are going to be a little upset :-(
ehudwill (author)2011-08-14
Great design!
mr_rigo (author)2011-06-26
This is really cool and very nice wood project.
For the one person version we could use a a V- belt drive with a Variable speed pulley to change the speed of one wheel, so we can control the direction by adjusting the pulley.
The V-Belt variable speed pulley are not expensive and it is available for a range of torques and dimensions.
jeffconnelly (author)2010-06-23
I wonder if there could be some sort of geared steering system for single rider use... I may have to research this...
spudman (author)jeffconnelly2011-06-23
You could use an individual brake on each wheel and put a diferental between them.
rustymia (author)2011-05-18
we had to design the bike of the future for my science class, and this is almost the exact same as my design, except mine was a little taller and was only one person. The pedals werent attached to the axle directly, the go to a differential, so to turn you would pull a brake lever or handle, and it would slow down the tire.
Your design is AWESOME!!
yggdrazil (author)2011-05-13
So so cool! And beautiful as well!
It's looks like something you would need to wait in line and pay to ride. The worry-wart in me is afraid of any little fingers or arms going into those spokes. Perhaps a little netting or wire would prevent that?
Keep building cool stuff!
kyle brinkerhoff (author)2010-12-31
good job! hey all i have to suggest is make some sort of steel reinforcment that has spokes on each wheel that would meet up and be connected to where the wheel connects to the shaft, i noticed alot of warping between the wheels and the chassis. but still an awsome way to get around!
I noticed the flex too. Maybe thicker axle and perhaps an extra ply or two when making the wheels? Hrm, maybe even a mud guard and make the axle held on both sides?
And yeah, still awesome even with the flexing.
I'd love to do a single seater version, hand cranked. Would then fit in bike lanes and also be suitable for disabled use as a bonus. I can almost see it but the models I've tried to generate in the PC so far suck.
Plus a hand cranked idea adds the option of hybrid human/electric - batteries under the seat for stability
Kasm279 (author)2010-07-11
I wonder what the neighbors think of all the crazy inventions rolling down the street xD
JKibs95 (author)2009-07-08
the legway's scary older brother...
theburn7 (author)JKibs952009-07-12
TRU DAT
dragonsniper (author)theburn72010-06-24
lol
pie R []ed (author)2010-03-20
I love this! I will probably build one over the summer. one thing that I might change would be the two person part. I figure with the right gear box and some hand levers it could be converted to work with the same two wheel pedal powered design but could be much more efficient and could turn without the second person.
sniffydogs (author)2009-06-04
This looks like something Government Motors might be interested in.
bdring (author)sniffydogs2009-06-04
Yes, someone said this is the Steampunk version of the G.M./Segway Puma.
jeff-o (author)bdring2009-06-05
Yeah, except the Puma is a totally lame electric wheelchair with a windscreen. The SteamRoller is awesome!
pie R []ed (author)jeff-o2010-03-20
agreed
DeusVult911 (author)2010-01-12
For Non-Eccentric bearings.  Try this place.  There a bit cheaper but you will have to use larger shaft diameters.
http://www.thebigbearingstore.com/servlet/the-4-dsh-Bolt-Flange-Bearings-cln-Set-Screw-Locking/Categories
corsi (author)2009-12-24
what was the diamiter of the 30 tooth sprocket. i can't find 1-2123-30-4B on surpluscenter.com
oOKing HunterOo (author)2009-10-07
What was the total cost of this project?
sir-zeke (author)2009-08-13
this is completely Epic!
superant10000 (author)2009-07-28
HAHAHAHAHAHA PERIOD CLOTHES >.
cryophile (author)2009-07-21
Do you think it's possible to add a transmission so you could have variable speeds? What I'm thinking of is something similar to what they have on mountain bikes. Also, I would like to see a rack-and-pinion steering setup, but I don't know if you could make the contraption that complex. I'm probably asking for too much. I'm going to have to try to build one of these.
corsi (author)2009-07-08
When you say surplus center what kind of store was it and what was the name of the store. I need to find all the "tricky" thing first the other stuff is easy to find
bdring (author)corsi2009-07-08
www.surpluscenter.com
corsi (author)bdring2009-07-13
thank you. you were right the surplus parts are alot
deemax (author)2009-06-17
How do you install the pedal gear, shaft collar and bearing into the wood? I've never used these before and am not sure how everything stays in place.
bdring (author)deemax2009-06-25
The bearings are not as thick as the wood. Drill a hole the outside diameter of the bearing with a spade or forstner bit only as deep as the thickness of the bearing, so you have a flat bottom hole. Then drill through about 1/4" diameter less than the outside diameter of the bearing to create a step about 1/8" all the way around. The bearings should press fit into the wood and sit on the step created. Use some tape to build up the diameter if it is not a press fit. The collars prevent the pedal shaft from sliding laterally in the bearings. Put a collar against the bearing on each side. You could actually use the gear as one collar if your steps are setup to install the bearings from the gear side.
deemax (author)bdring2009-06-27
Awesome, thanks again.
Is it difficult to find the perfect spot for the wheel axle in order to maintain the right balance, or will it balance automatically as long as the center of gravity is anywhere beneath this point?
bdring (author)deemax2009-06-24
I drew it in chalk on the floor and estimated the CG. Some small kids use a pillow behind them so they can reach the pedals. This shifts the CG forward, so I added a little shelf behind the seat to add weight. So far one 10 pound-ish brick does the trick. Big adults with higher CG tend to ride with feet high, but it works fine.
Thanks! That shelf for extra weights is a great idea.
corsi (author)2009-06-04
awsome this will be the first thing i make in woodshop nest year. i already have people ready to ride it down the hallways of the school when it's done
jeff-o (author)corsi2009-06-05
Just make sure you can get it out the door!
corsi (author)jeff-o2009-06-23
Don't worry we have one of those big loading doors plus the outside doors are huge this will so make me in the yearbook
robprimeau (author)2009-06-21
Well done, I've seen your earlier works, but I think this one is the best so far. It looks far easier to ride this one, plus its a social activity to ride on it. Do you let the kids enjoy this one a lot?
Atomman (author)2009-06-20
It is difficult adjusting the wheels, but really awesome Instructable!
BuilderLoon (author)2009-06-19
Please Answer ASAP... How much did this cost in GBP?
About This Instructable
46,857views
419favorites
License:
More by bdring:iPad ChairThe SteamRoller Riding ContraptionSteampunk Segway ( Legway )
Add instructable to:
