3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The SteamRoller Riding Contraption
This a self balancing two wheel, two person vehicle. It self balances because the center of gravity is located below the center of the wheels.
Each rider controls one wheel. Pedal together and you move in a straight line forward or backward. Anything else is a turn including a spin in place by pedaling in opposite directions. I guessed a top speed of around 7mph would be a good start. I set the gear ratio accordingly. It was designed for kids around 5' tall, but it can easily handle taller. I am 5'6" and about 160lbs. I rode it with my daughter and it worked well.
This instructable details how to make a basic version. I designed everything in Pro/E. I have exported all the parts to DXF format so you can access with free software like QCAD. The drawings have basic dimensions for overall reference. They are 1:1 so you can scale off them or add additional dimensions. There are also PDFs too. I used my homemade CNC router so I added a lot of details that are not required. Need more info, detail, pictures...just ask.
The project took me about 16-20 hours over 3 weeks to build. A lot of that was design and testing, so it could take you less time. I had a lot of left over and found material that I used. If you started from scratch this could cost $150 to $200 to build. The bearings and drive train parts are the most expensive. I bought them at a surplus store. Hopefully you can find them cheaper.
The design worked pretty much as intended without any major problems. I did learn a few things along the way. I added "possible improvements" sections to each step that might make your version better and easier to build.
The working name is SteamRoller due to the steampunk look. The kids like Wheels of Doom and Portable Porch Swing. Does anyone else have any suggestions?
Step 1Materials
Materials
Here is the basic list of parts. The dimensional lumber is estimated because I had enough scraps to cover that. I ripped the various sizes needed on my table saw from larger lumber.
Wood
(2) 4' x 8' sheets of 3/4" Plywood (I used BC Exterior grade)
(1) 4' x 8' sheet of 1/2" Plywood (I used BC Exterior grade)
(1) 2 x 4 x 6' pine board
(1) 1 x 6 x 6' pine board
Surplus Center Parts
(4) 7/8 4 Bolt Bearing Block (#1-205-14-4)
(2) 10' pieces .40 pitch chain (#1-1163-40)
(2) 11 tooth 7/8" shaft sprocket (#1-2123-11-D)
(2) 30 tooth sprocket. (#1-2123-30-4B)
(4) 7/8" dia. shaft collars (#1-2766-87)
(2) #40 Chain Connecting Link (#1-1087-40)
(4) 7/8" I.D. bearings (eBay)
6' of 3/4" heavy wall copper tubing
4' of 1" thin wall copper tubing.
(12) 3/4" 90deg copper elbows. (buy a bag/box of them...much cheaper)
(2) 1" copper end caps.
(2) 8" long 1/2" pipe (wheel Axles)
(2) 1/2" pipe flanges (mounts axles)
26' 5/8" I.D. Heater tubing
5/8" double barbed fitting.
1/8" NPT Schreader tire value
144 comments
1-40 of 144next »
Dec 25, 2009. 10:55 PMFred82664 says:
Admin on this site must be smoking Meth this should of made in the top five of  09. it did make it as 13  out of 50  still not bad ! but still yet it should be in the top 5
Oct 2, 2011. 4:40 PMilpug says:
agreed. except for the meth smoking part. i dont think they do that.
Aug 14, 2011. 10:25 AMlouis.m says:
What about "Weird Wheeler" as a name?
Aug 14, 2011. 9:46 AMrichie_114 says:
Awesome! I made something similar (3 wheeled) several years ago, nowhere near as cool though!
Aug 14, 2011. 8:22 AMehudwill says:
Great design!
Jun 26, 2011. 1:26 PMmr_rigo says:
This is really cool and very nice wood project.
For the one person version we could use a a V- belt drive with a Variable speed pulley to change the speed of one wheel, so we can control the direction by adjusting the pulley.
The V-Belt variable speed pulley are not expensive and it is available for a range of torques and dimensions.
Jun 23, 2010. 7:35 PMjeffconnelly says:
I wonder if there could be some sort of geared steering system for single rider use... I may have to research this...
Jun 23, 2011. 11:01 AMspudman says:
You could use an individual brake on each wheel and put a diferental between them.
May 18, 2011. 5:13 AMrustymia says:
we had to design the bike of the future for my science class, and this is almost the exact same as my design, except mine was a little taller and was only one person. The pedals werent attached to the axle directly, the go to a differential, so to turn you would pull a brake lever or handle, and it would slow down the tire.
Your design is AWESOME!!
May 13, 2011. 9:14 AMyggdrazil says:
So so cool! And beautiful as well!
It's looks like something you would need to wait in line and pay to ride. The worry-wart in me is afraid of any little fingers or arms going into those spokes. Perhaps a little netting or wire would prevent that?
Keep building cool stuff!
Dec 31, 2010. 1:55 PMkyle brinkerhoff says:
good job! hey all i have to suggest is make some sort of steel reinforcment that has spokes on each wheel that would meet up and be connected to where the wheel connects to the shaft, i noticed alot of warping between the wheels and the chassis. but still an awsome way to get around!
Feb 24, 2011. 6:43 PMDatabanks says:
I noticed the flex too. Maybe thicker axle and perhaps an extra ply or two when making the wheels? Hrm, maybe even a mud guard and make the axle held on both sides?
And yeah, still awesome even with the flexing.
I'd love to do a single seater version, hand cranked. Would then fit in bike lanes and also be suitable for disabled use as a bonus. I can almost see it but the models I've tried to generate in the PC so far suck.
Plus a hand cranked idea adds the option of hybrid human/electric - batteries under the seat for stability
Jul 11, 2010. 12:55 PMKasm279 says:
I wonder what the neighbors think of all the crazy inventions rolling down the street xD
Jul 8, 2009. 8:14 PMJKibs95 says:
the legway's scary older brother...
Jul 12, 2009. 12:26 AMtheburn7 says:
TRU DAT
Jun 24, 2010. 7:43 PMdragonsniper says:
lol
Mar 20, 2010. 12:40 PMpie R []ed says:
I love this! I will probably build one over the summer. one thing that I might change would be the two person part. I figure with the right gear box and some hand levers it could be converted to work with the same two wheel pedal powered design but could be much more efficient and could turn without the second person.
Jun 4, 2009. 5:43 AMsniffydogs says:
This looks like something Government Motors might be interested in.
Jun 5, 2009. 5:47 AMjeff-o says:
Yeah, except the Puma is a totally lame electric wheelchair with a windscreen. The SteamRoller is awesome!
Mar 20, 2010. 12:35 PMpie R []ed says:
agreed
Jan 12, 2010. 8:11 AMDeusVult911 says:
For Non-Eccentric bearings.  Try this place.  There a bit cheaper but you will have to use larger shaft diameters.
http://www.thebigbearingstore.com/servlet/the-4-dsh-Bolt-Flange-Bearings-cln-Set-Screw-Locking/Categories
Dec 24, 2009. 10:25 PMcorsi says:
what was the diamiter of the 30 tooth sprocket. i can't find 1-2123-30-4B on surpluscenter.com
Oct 7, 2009. 4:18 PMoOKing HunterOo says:
What was the total cost of this project?
Aug 13, 2009. 8:53 AMsir-zeke says:
this is completely Epic!
Jul 28, 2009. 10:11 PMsuperant10000 says:
HAHAHAHAHAHA PERIOD CLOTHES >.<
Jul 21, 2009. 2:49 PMcryophile says:
Do you think it's possible to add a transmission so you could have variable speeds? What I'm thinking of is something similar to what they have on mountain bikes. Also, I would like to see a rack-and-pinion steering setup, but I don't know if you could make the contraption that complex. I'm probably asking for too much. I'm going to have to try to build one of these.
Jul 8, 2009. 2:33 PMcorsi says:
When you say surplus center what kind of store was it and what was the name of the store. I need to find all the "tricky" thing first the other stuff is easy to find
Jul 13, 2009. 6:44 PMcorsi says:
thank you. you were right the surplus parts are alot
Jun 17, 2009. 1:23 PMdeemax says:
How do you install the pedal gear, shaft collar and bearing into the wood? I've never used these before and am not sure how everything stays in place.
Jun 27, 2009. 3:18 PMdeemax says:
Awesome, thanks again.
Jun 17, 2009. 1:27 PMdeemax says:
Is it difficult to find the perfect spot for the wheel axle in order to maintain the right balance, or will it balance automatically as long as the center of gravity is anywhere beneath this point?
Jun 27, 2009. 3:15 PMdeemax says:
Thanks! That shelf for extra weights is a great idea.
Jun 4, 2009. 12:34 PMcorsi says:
awsome this will be the first thing i make in woodshop nest year. i already have people ready to ride it down the hallways of the school when it's done
Jun 5, 2009. 5:45 AMjeff-o says:
Just make sure you can get it out the door!
Jun 23, 2009. 9:25 PMcorsi says:
Don't worry we have one of those big loading doors plus the outside doors are huge this will so make me in the yearbook
1-40 of 144next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
95
Author:bdring
