Here is my latest project „The steampunked torch of progress“.
The idea to create this steampunked torch as a scepter of victorian progress came to my mind as I looked at some old pictures showing some allegoric statues (see next step).
All parts can be easily build together with only some screws and a little bit of resin.
For building the technical equipment I used this instructable: High-voltage-power-supply-for-Nixies-CFL-Neon-Glow-Bulbs
To get a short impression please watch this small video:
Now let us start with this instructable
Have fun
Yours Aeon Junophor
Remove these ads by
Signing UpStep 1: Historical background (short)
As a real steampunker I love this retro-futuristic style based in the victorian era (1837-1901) as you know. This is my favourite century with its technical inventions and new machines powered by steam and electricity.
In this time a lot of allegoric statues like the great statue of liberty had been build.
Also the new power called „electricity“ had its allegoric expression as you can see at this picture.
The torch, mostly used as a scepter of the goddes is a symbol of the technical progress which enlightens the darkness and brings wealth and hope.
These old pictures inspired me to create the Junophor steampunked torch of progress.
Visit Our Store »
Go Pro Today »
When you remove the socket of a flickering bulb, there is everytime a resitsor added at one contact. It´s value depends on the current weather it is 230 Volts or 110 Volts AC.
See picture1 as a sample.
The flash unit transforms the DC first to AC and than back to DC. That is the reason why there is a diode placed in the circuit. And that is also why you can get the High Voltage as AC as well as DC. It just depends on the place where you solder the wires to the bulb contacts.
See also picture 2
and this instructable of mine.
Yes this bulb is really shining very bright, because it runs with 3,0 Volts which is possible to do it with this AA-Type unit. But if it runs with only 1,5 Volts the glow lamp is also shining really bright.
Hope this information will help.
Be careful when working with HV:
Many greetings yours
Aeon Junophor
I thought you were talking about the common 120 volt flicker flame bulb that is used for decoration, you know the one that has the clandrabra style shape.
So I took one of the older ones I have sitting around and carefully removed the base,
and guess what it also has a small resistor, it's removal makes the flicker flame bulb work quite well on one of your HV units, it is quite difficult to get to since it is way up in the glass portion of the bulbs base, it was a useful surprize.
I have never removed the base of a flicker bulb, is there a resistor in it?
Also how did you get both plates to glow since the camera flash is a DC source,
did you short out the diode on the flash unit?
Nice project I was surprized to see how bright it is, good job
Bill.
It is me again because I forgot to tell you about the weight of the torch
It is about 450 Gramm (0.45Kg)
Greets
Aeon Junophor
The total length of the scepter is exactly 49 cm, means 29.29 inches.
The copper and brass tube measures 28.5 cm the bakelite part is about 6.0 cm and the brass top measures 14.5 cm.
Maximum diameter at the top is about 60 mm, minimum 27 mm.
Hope the numbers could help you
Greets Aeon Junophor
