3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Stirling Engine, absorb energy from candles, coffee, and more!
Step 2Cut CD tower
Cut CD tower
This step is pretty easy, measure an inch from the top of where you'll make the cut and mark. With the CD case I'd suggest filling it with CD's up to the point where you're making the mark, take it slow, and use that as a guideline for drawing all the way around.
Now, for a really nice pretty cut, I used a drill press and a cut off wheel and was able to make a very level cut just by spinning the case (see pictures) HOWEVER, this isn't needed, a saw will work just fine, that's why you need to make sure you mark level all the way around the case. It helps a LOT. Also, cut the top off last, it'll provide support and make it a LOT easier to cut.
4 comments
Mar 16, 2009. 12:11 PMAlterman says:
Does this part have to be plastic? If I use metal or another heat conducting material will the machine still work ?
Jun 12, 2010. 6:29 PMadledoux says:
The displacer cylinder needs to either be made of a non-conducting material (plastic, glass, rubber, etc) or have a non-conducting spacer separating the upper section from the lower section if you use conducting materials (metal) to make the cylinder. The fundamental idea is to have distinctly separate "sides" of the cylinder, one to collect energy, and one to disperse it, in a manner that is controlled by the position of the displacer, in order to facilitate the contraction-expansion cycle of the enclosed gas.
Jun 11, 2009. 7:09 AMgaspa says:
about 1 inch?
Jun 11, 2009. 7:06 AMgaspa says:
how much high is it finally? i cannot understand it from your photos.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
54
Author:thecheatscalc
