Step 3Cut displacer
iImage Information
This is pretty easy, pull out your foam board and compass. Using the top cut from the CD tower, span the compass from the middle to a fourth of an inch from the edge (2.25" to be exact). Draw two circles on the foam board (make sure to mark the middles!) and cut out. I'd suggest cutting the two circles roughly then use a jigsaw or the like to finish the cut smoothly. If you don't have one, the scissors will work fine.
Stack the two circles, then, using matching electrical tape, tape them together around the circumference. If you want you could glue them together, and it's not going to cause a problem.
So I pasted whole motor once again but nothing happend. The worst thing of all is I dont know where I’ve made mistake. I think that ancillary piston is OK. It goes very gently (if it goes more gently it wont be caulking anymore). I thing that the problem is in main (working) piston. Maybe it has wrong height ( smaller than half space which is made for piston), and it is made from styrofoam so that is not so good as well. It is a fact that it is really light. I had it made from hard paper before, but I thought that was so heavy.PS: The worst thing what pissed me off is that the motor dont want to work at all so I think that it couldnt ne working anyway. But I have no problem with caulktion.
Look on my pictures zerog.cz/engine pls
